376
OK..finished flight LICC-LIRF, excellent performance, sans the AP in the A330 which would not follow route after about half way thru the flight. I just hand flew it with heading and altitude inputes then hand landed.
But the X-LIFE is simply amazing!
SUPER job on this Mr. R
Tomorrow my time will do a more complex flight and change some settings. Dinner with wife then relaxation with her wink
Dinner is on me when you come to LSZH
377
cmckjodi wrote:
Just a suggestion here. I read about program crashes and other problems and of course, these things do happen. As an avid user of X-Life I can understand people becoming upset when there is a crash, especially those that are new to using it. Yes we are asked to post our logs here when there are problems, so then the proper information can be gathered by the JAR team. That's excellent it's great that this can be done! My suggestion is to implement a trouble shooting page here on this forum so that users can look up possible causes of problems based on information gathered by JAR so far from text logs and different problems. The team could post some quick solutions to common CTDS (crashes) and users can post how they had and fixed certain problems within X-Life. Just the other day I told someone on this forum to update to the latest 4b version. His problem was easily solved and he has traffic moving at his new airport. Result a happy X-Life user. My point is that if there is a page on the forum for trouble shooting problems and crashes within X-Life, the process of solving them might be smoother and happier.
This is the page for Bata issues you post your log.txt and bbox.txt here and your crash reports here!
I need the testing done first and foremost so X-Plane gets the best plugin we can deliver.
and splitting thing up is not how we do things then the issues get lost and hard to keep track of  Period !
JAR will sub-devide the subject matter when neededs as he already has in the different versions of Bata X-Life, so you are just re-hashing what is already being done.
And yes you might have to do some reading through the excess posts just like the one you just posted Because you are trying to change something that is not necessary yet...
378 (edited by tommy0204 2016-05-12 17:22:09)
Hello!
i installed V1.1b5  ATC Func Crash ?
379
Seems like yes. need time to repair... FIXED now! Please use the same links to reinstall plugin.
380 (edited by Dazven 2016-05-12 20:58:36)
Hello, so I am encountering quite an issue of which I am not sure if it is related to EADT's x737 or X-Life. Anyway I am using X-Life Deluxe and the x737 v5 as my aircraft. While contacting Delivery through the ATC menu of X-Life and requesting clearance I have encountered a problem with setting my altimeter. ATC tells me that I need to set my QNH to 1017.00 while ATIS says I can use inches as well at 30.06(Tried both, closest I can get with HP in the x737 is 1017.02) yet despite that when I request clearance my pilot says the QNH is "1013"(Which is incorrect from what I set it in the plane). Is there a workaround to bypass such as I am unable to use the ATC feature at the current moment?
381 (edited by ilankrt 2016-05-12 21:21:37)
Test flight with the newest version v.1.15b
X-Plane/X-life stocked and I had to "Force Quite"
This happened after I finished programming my Flight Plan and ATC wind opened.
I clicked on ATIS and after on DELIVERY for radio check and then it freeze...
(usually until now I got X-Plane ATC text and Voice parallel to X-Life ATC text, maybe a conflict between the two?)
382
XLD read current baro from X-Plane standart dataref and compare it with realweather info from NOAA servers. Sometimes X-Plane not set real baro and you may try just enter 1013 on Atc init stage.
383
Please redownload beta. i just post beta 6, cause beta 5 have error (my bad, sorry).
384 (edited by captbullett 2016-05-12 23:28:09)
Permanent link to actual release
Permanent link to actual more fresh beta
http://www.jardesign.org/x-life/download/xlifeb.zip
As soon as we post release candidate, we should say what all planned functions for version 1 are done. All we need - make XL stable with current set of functions. Parallel I work on ver 1.1 but too earlier to say any exact about it. Please post all your useful notes right here. I am dont know date of 1.0 release (as usual) - will see, will see.
All principles remain the same - please post you ideas for improvements, post what you like/unlike? post your log.txt + x-life.dmp if Crash happen.
Coupon code - JARD-NPOB-RWKU  will give you 50% discount from list price, if you buy product at this development stage and from official product page.
If you prefer use “Bluebell XL” traffic AI library (need at least vet 1.1 beta 6), please download 3 files from
http://jardesign.org/forum/img/m/22/t/p1aiikfio2qnomj024f1tn6u163.jpg
So, now, i just continue coding. Cheers!
Where is B6 I just downloaded B5 two times now.. But this seems to be the right version to work so please look at the JPG and you will see the BlueBell started along with the //*Green Message //
Attachment icon Screen Shot 2016-05-12 at 7.23.15 PM.jpg 325.6 kb, 150 downloads since 2016-05-12
385
http://jardesign.org/forum/img/m/508/t/p1aijtcg2d1fob1ch617qb10ms1ivq3.png
It is wired to see such a lot KLM aircraft in ZBAA tongue, but this is a great plugin. BTW, is the engine reverse animation have not been done now? I find not reverse on A320 landing.
386 (edited by pic 2016-05-13 09:34:39)
OK, full report as promised.
I realized that the original DL was wrong, and checked here and, yes, had to DL X-Life again. This time it was Beta 6 and before I mention bugs, this plug-in is again to another level of genius.
So, my first flight was with JAR A330 from LICC to LIRF and no problems except for the plane itself which would not follow route after I did a DIRECT, so hand flew it into Rome.
I then switched planes at LIRF (IEXG 737) and did an xlife route to LFMN. This is where a reoccurring problem arose: No sound coming from atc, just instructions in atc window. This happens with any ac when doing multiple flights in one go.
Also, the FM car and TUG do not work with the 737 so I temp removed it for both flights.
I attached all necessary files for your forensic investigation wink
Finally, I cannot tell how much I appreciate and love this work of genius! Whatta diff this makes in xplane.
ciao,
di Luigi
387
Since the last update, the radio check is 999.99
Is it normal ??
388
Hi Mr. JAR, since I've been on beta team for xlife since day one, and you never asked for any money for the deluxe, I felt obliged to buy it anyway as a way to say "thanks", and since it's probably remote that you'd ever get to LSZH for my dinner offer to you wink
Thanks again for a GREAT tool for xplane!
389
stenu wrote:
One question: Why X-Life does not utilize the 1204 parameter of apt.dat of ATC taxi routes indicating hold short points, but instead requires hold short point to be one line segment away from the runway? It makes possible to put hold short points further away from runway, which is often necessary. It can also limit the hold short for arrivals or departures only if required.
For example:
1202 41 40 twoway taxiway A
1204 departure 03,21
1204 arrival 03,21
Means that the line segment between points 41&40 denotes a "restricted" area which you can't enter before the tower gives you permission for it (runway 03/21 is free).
-J
I don't understand what is the gain of your purpose?!....
My purpose is to avoid re-inventing the wheel. When there is already a way to denote the hold short point, why do it differently? Using the standard way would reduce the amount of  work patching the existing airport routes.
I've done considerable amount of work in patching the routes to work well with FMcar in the past, following the WED guides on how to make ATC taxiroutes, now X-Life sets new rules and I have to start all over again...
-J
390
Thinking about what could be one of the next steps of development, I got an idea about making the approach much more exciting and precise.
At the moment situation, flying on approach, I open often the RADAR screen to see if there are some other AI aircrafts on same route to land on same runway. Then I enhance or reduce aircraft speed according to my estimation about distance to the aircraft ahead and time until exiting runway. This is very unprofessional.
Instead it will be efficient to get ATC warning/advice like : traffic ahead xxxx kn at distance xxxx nm, so the pilot can stay at safe distance during landing.
Only sometimes and in the last minutes before landing we can see on PFD screen the diamond of the aircraft ahead and sometimes in the horizon its  position in the sky with only its FL indication. I would like to discuss this idea to see if there are some regulation that we can implement in a simple manner into ATC, so we can handle our approach according to the incoming information. This can avoid us from GA, saving time/fuel costs and make out landing under more near real....
(Going now to test the latest X-Life 1.6b version)
391 (edited by captbullett 2016-05-13 13:40:09)
Now, I have only had one maybe two GA in the whole time I have tested the X-Life plugin and I started from the beginning of the process 18 months ago when JAR ask me to start testing on the MAC Version X-Life it was also the first version that came out before, PC so, 'PIC' and I were two of the first public Beta testers I do believe.
You are the only one that keeps asking for the developer to make big changes to his plugin so my question is why,
is it so, you can talk about it on your blog and tell people you helped JAR and the X-Life well It's just wrong. If you want to talk about the XL and how all the Beta testers have done a good job making the XL good and how it's improving with the addition of the Bluebell aircraft then thats something to blog about but include everyone not just what you did! This is not about you this is a team effort and this is why I have my attitude you must include everyone that is working on the project if you are going to blog about it on your own website.
Nevertheless, the spacing is such now if you have the plugin set-up right your spacing will be right and you won't need to fly a GA (Go-A-Round.
Ps, the last GA I did I had no issues with the GA I was able to go to FL50 and then use the "blue line" in the flight plan on the JAR A320Ne then contact ATC and have them tell me to contact tact Approach when I had the ILS established, and then I was able to land within I would say 15 min of the GA...
392 (edited by captbullett 2016-05-13 13:46:24)
stenu wrote:
For example:
1204 arrival 03,21
-J
-J
Have you looked at the rules and Yes the patch-work is the only way to add the taxi-ways to existing custom Scenery airports and this is the rules for putting in the taxi-ways.
http://jardesign.org/forum/viewtopic.php?id=1670
Thank-you,
Hi All,
Been doing a little testing of the beta.
Flying from EGCC to EGLL at FL190.
I do not know if it is just this flight but the change over on ATC from APP to CTR was at TOC, FL190.
Would it not be better to change from APP to CTR passing FL100 and set QNH to standard 1013.
Also is their any way to set which airlines are used or is it just random.
Tom.
394
Log.txt please,
bluebell wrote:
Hi All,
Tom.
I am not understanding the last question , but the first question the weather, and Qnh is set one by the NOAA, or the weather generator and then the US or EU will tell you which QnH or it should work like that there is still a bug in the system still I believe,
in the US it is 1013 set up still and you have to adjust to the airport which you can get on your XP map.
and then-you for the Bluebell aircraft...
Good evening.
Faced here with what the TU-154 Felis prompt delivery - "Pilot: SOCHI Delivery ,JAR123, Stand T29, T154, with information Charlie, QNH1014, request clearance" and in response get "ATC: JAR123, SOCHI Delivery, Wrong QNH, set 1007". IN ATIS QNH1008. The altimeters were set at QFE pressure and QNH and the situation has not changed. Still in my query QNH 1014. The log file is applied.
Добрый вечер. Столкнулся вот с чем, ТУ-154 Фелис запрашиваю Delivery- "Pilot: SOCHI Delivery ,JAR123, Stand T29, T154, with information Charlie, QNH1014, request clearance", а в ответ получаю "ATC: JAR123, SOCHI Delivery, Wrong QNH, set 1007". В ATIS QNH1008. На высотомерах выставлял давление и по QFE and QNH ситуация не меняется. Все равно в моем запросе QNH 1014. Лог файл прикладываю.
397
Please, check your mapping to you Joystick or keys and see where your reverse is mapped to, then report it here.
bluebell wrote:
Hi All,
Tom.
I do not think you understood both questions.
Last question: Are the AI aircraft random generated based on gate size.
Other question: 1013.25 mbars or 29.92 inHg is the standard pressure set by all aircraft above 10,000 feet around the world. Approach ATC should hand-over to Center before or at this height. This is so ALL aircraft fly on the same setting above FL100. When contacting Approach during arrival the local QNH from that airport will be given by ATC based on local weather.
399 (edited by tangsoodn 2016-05-13 16:51:54)
I had the same issue until I figured what's going on. Use the top BARO that's part of the MCP (just left of the COURSE knob). The BARO in the center is the standby (IFSD). ATC uses the main.
400
Is it normal ??
This depend of .dat file freq
