master_pilot wrote:
Hi, excelent job with A320neo! I'm from Chile, sorry for my english. I have some problems with the MCDU, when i select F-PLN, DEPARTURE or ARRIVAL, in any case, i don't have the INSERT> option! And when i select a SID or STAR procedure, RWY, etc, everything is in ambar color, not green..What can i do?? PLEASE HELP!!
The first thing that  to do are to put airport in to botton INT ( es. EDDM/EDDF)
Next you selected a SID or STAR  you must push botton on the right MCDU(insert).
When you see at Discontinuity click on ,  and confirm
ANA916 wrote:
fix the auto brakes for the second leg please!
I feel, you are not use brake pedals after landing, but park brake?
I have one trigger on my joystick that is assigned to "toggle brakes regular effort" and is always using it when landing.  I can't assign hold brake right and hold brake left to one trigger. Is there a work around to this problem.
If you have the python interface for XP then download the progressive braking script. It has two extra braking assignments which are much more realistic for all aircraft
WOW thank you! everything is working!
I can't clear a discontinuity  with V2.6r2, worked fine with V2.6r1
can you please send a log.txt and we can help you then since, you probably need to up-date your nav-data send that data to you need to be complete so we can help you ok,
Thank-you for your help,
Hi, I'm experiencing some errors with Navigraph NavData...
Some procedures are not available on the arrival page...if I select for example a LICR arrival, no LOC/DME procedures are available, only VOR. Same with LOWI: no procedures available (only LOC/DME here)...
108
I am again facing a X-plane CTD, when repositioning the A320 to a different location or runway with the 2.6 r2 release.
I am also seeing a flywithlua crash when I load this plane at startup.
Hi, one suggestion,
can you put in a320neo the button to send and receive messages to crew like a330?
110
Hi, I 've noticed a strange issue present sicen previous versions: when you are in rainy conditions and you don't set the ignition selector in the right position as you call the before takeoff checklist starts a sound loop "engine mode selector" impossible to stop and you have to abort flight.
111
Yes there is new issue of this aircraft and 1605 nav data incomplete data.
I've found a situation, where a F-PLAN discontinuity cannot be cleared.
The route is EDDV SID WRB UN850 NATOR N850 TITIX UN850 TRA M858 SRN UM858 VOG STAR LIMJ
Initial departure runway was 9L and SID was WRB2Y, but ATC told be to change to runway 27C. Then it was not possible to clear the occured F-PLAN discontinuity .
Please check the video: https://youtu.be/1jGT4JV3qbo
113 (edited by olafsc 2016-05-21 22:14:03)
Updated R1 to R2 by replacing the two files as this post indicates.
3 Issues
1.) When Taxi over ca 45 knots on the ground plane goes into flight mode and announces flight Level 0000 and gets all confused. Plane should allow high Speed taxi
2.) Managed Approach, in Approach mode with dual AP. Plane does not Decel, Approach Phase did not activate at Decel waypoint, no Speed reductions also at flap deploy. Altitudes work fine but Speed reductions do not work at all.
3.) Took off again after a landing, and flew in managed Speed, selected heading and alt 3000, Athr, Thurst clb. Plane went into overspeed to Level flight , over 360 knots despite managed Speed.
114
I've ever had UFMC that use with other planes...i'm sure that it is not the problem
I have x737fmc, and I've noticed that if I remove the plugin, the A320 stops crashing.
115 (edited by Mad Mat 2016-05-26 08:35:04)
small graphic bug: the windshield de-icers (i suppose...) are visible from the outside only on RIGHT side:
http://jardesign.org/forum/img/m/1025/t/p1ajm357rl5tb1i9i1dgv46ipqe3.jpg
116 (edited by Mad Mat 2016-05-26 08:44:31)
Another small graphic bug (that I corrected by myself): the EMERG EXIT LIGHTS switch is not backlighted when the rheostat is rotated; I attach the corrected texture file.
Before and after image:
http://jardesign.org/forum/img/m/1025/t/p1ajm3h813ts91giuqlr6n59pv3.jpg
http://jardesign.org/forum/img/m/1025/t/p1ajm3h8135qv1cpu3rs1aetvdq4.jpg
117 (edited by captbullett 2016-05-26 11:51:12)
the x737 UFMC need to be in the right place (File) is it ? //*custom Data File///
So, like a log.txt could resolve the issue but yet again there is an issue and no log.txt and the issue could be resolved way or the other and very quick.
118 (edited by laohu314 2016-05-29 15:44:39)
Had a successful flight KSFO KSAN with some glitches:
The flight plan from ATC is most of the time unusable.
@JAR, would it be possible to tie in simbrief.com to get realistic flight plans?
Also, the FL for final approach is often too high and the glide slope cannot be caught automatically without descending below what ATC prescribes.
Finally, I get a lot of these in my log. What is that?
[SASL ERROR] Error updating avionics: [string "/Users/HW/Desktop/X-Plane 10/Aircraft/320neo_..."]:0: attempt to index a nil value
Many thanks!
119
you can use simbrief and download the IVAO/IVAP format. Rename the file to .txt removing the nomber at the end and edit it leaving only DEPARTURE SID ROUTE (with no data apart the name of the waypoints and airways) STAR DESTINATION
Example (LFSB to OTHH I planned today), the format is the same for A330 and A320:
from this:
[FLIGHTPLAN]
ID=XPI0023
RULES=I
FLIGHTTYPE=S
NUMBER=1
ACTYPE=A332
WAKECAT=H
EQUIPMENT=SDE3GHIJ2J3J5M1RVWXY
TRANSPONDER=LB2D1
DEPICAO=LFSB
DEPTIME=1445
SPEEDTYPE=N
SPEED=0479
LEVELTYPE=F
LEVEL=370
ROUTE=DCT ELBEG Y715 LENGI DCT TRA UN491 DEGES UN871 MADEB UN606 ELMEM UL607 VEKEN Y177 EBITI P735 VBA M19 TUVAR UM19 ETIDA/K0876F370 Q9 RIXEN/N0475F370 L605 BAG UL601 KTN R785 ZELAF DCT TRF P559 KOBOK UT659 ROSAN DCT
DESTICAO=OTHH
EET=0528
ALTICAO=OEDR
ALTICAO2=
OTHER=PBN/A1B1C1D1O1S2 DOF/160529 REG/IXAIR EET/EDGG0001 LSAS0007 LOVV0017 LIMM0030 LOVV0031 LIMM0038 LJLA0039 LDZO0050 LYBA0109 LBSR0129 LTBB0204 LTAA0218 OSTT0305 OJAC0329 OEJD0338 OBBB0457 SEL/XITA OPR/XPI RMK/TCAS
ENDURANCE=0646
POB=228
to this:
LFSB SID ELBEG Y715 LENGI DCT TRA UN491 DEGES UN871 MADEB UN606 ELMEM UL607 VEKEN Y177 EBITI P735 VBA M19 TUVAR UM19 ETIDA Q9 RIXEN L605 BAG UL601 KTN R785 ZELAF DCT TRF P559 KOBOK UT659 ROSAN STAR OTHH
120
Absolutely perfect flight from KSAN to KPHX.
Finally figured out what the problem was with these sharp turns onto final approach. I had not chosen Transits and Vias properly.
This time I did and everything was perfect. Line-up and final approach FL, just great.
I did ignore the ATC STAR suggestions and chose another one, though (according to simbrief.com), same runway and no problem.
I did see a couple of these again in my log...
What a pleasure flying the A220neo and X-Life!!
121
from this:
[FLIGHTPLAN]
ID=XPI0023
RULES=I
FLIGHTTYPE=S
NUMBER=1
ACTYPE=A332
WAKECAT=H
TRANSPONDER=LB2D1
DEPICAO=LFSB
DEPTIME=1445
SPEEDTYPE=N
SPEED=0479
LEVELTYPE=F
LEVEL=370
DESTICAO=OTHH
EET=0528
ALTICAO=OEDR
ALTICAO2=
ENDURANCE=0646
POB=228
to this:
Yes, I'm doing this but wouldn't it be great if XL ATC did it automatically. I don't know how it puts its routes together currently but using simbrief routes and SIDs and STARs with the proper Transitions and Vias would be awesome
122
Cool fix Mad Mat,
Would you please share with us how you fixed it.
Many thanks!
While we are talking little issues, I'm finding that pulling and pushing buttons on the FCU doesn't show the physical movement of the button as it does in the A330. Is it just my system or are others seeing the same thing.
If so, how could that be fixed?
124
Cool fix Mad Mat,
Many thanks!
I simply edited the texture using one of the illuminated buttons on the same texture, putting the lit and the non-lit texture one over the other to align correctly the light. By the way, you can download the updated texture from my post!
125
Mad Mat wrote:
Cool fix Mad Mat,
Many thanks!
Thank you Mad Mat,
I'm afraid you are assuming too much on my abilities. Unfortunately, I don't know anything about aircraft building and how to manipulate textures. I also wouldn't know how to get the texture from your post even.
Maybe JAR will fix it sometime.
