Re: How to Create ATC-taxiroutes using WED. Rules, features.
newmind wrote:SirOTheOne wrote:i have tried it many times in several version on LZIB, but every time i got a CTD
versions:
1. name it like the main runway -> CTD
2. name it like the taxiway -> CTD
3. one point before runway -> CTD
4. two points before runway -> CTDi don´t know how you did it, to get it working without CTD
a hp is a point, ONE point before runway, or is there another definition (algorithm?)
I´m also a developer and app designer on objC, c++ and other languages, but creating atc routes doesn´t work like it should (look at video and other how to´s)
ps: it´s frustrating to build atc routes for airports without success -> only CTDs and i don´t know why
on some airports it works perfect, other airports (with complicated taxi- and runways) are the hell to build routes
Tried your version of LZIB for 1 hour but no CTD...(i'm on win10 x-plane 10.45)
anyway the holding points have some trouble in many airports!!!
I'm using the red line as suggested in the picture but in that way the planes stop at the HP but then freeze waiting for an aircraft that doesn't exist.as you see at LZIB the hp on rwy 33 is not correct (uploaded version, that you have tested) - so i changed the routes between hp 33 and the rwy to the version as you did it -> CTDs
I've modified the hp at rwy 31 (i guess not 33)...it works for me. The planes stop at hp and succesfully take off - no CTD!!
