cmckjodi wrote:cmckjodi wrote:Thanks Fearlessfrog, I just thought something was needed here for the community. Hopefully this will make it easier for folks to understand how to create gate "pushbacks" and the importance of the Gate Editor. I for one did not know how it's function is so important to getting traffic to move in X-Life. I think as more people start to get the hang of taxi routes you will see many more airports become "verified"
If anyone has more questions about X-Life and making ATC taxiroutes post your questions! I may make a more in depth video on how to make Taxiroutes for beginners using WED and X-Life.
You might also want to mention:
1) Ramp starts need to connect completely with a Taxi Route (not Taxi Line; these are different in WED), i.e. the Taxi Route Start Node is placed into the tiny + in the Ramp Start icon.
2) That direct connection needs to be in the same orientation as the ramp start
3) Make sure that the size of the aircraft (as set in Gate Editor) is such that
a) aircraft don't hit each other when moving into or out of their stand and
b) that they are not interfering with other traffic along a Taxi Route
