Topic: a320neo JARDesign ver 2.6 r2 WIN/MAC 64 bit
After long beta-test period and release ox X-Life we back to aircrafts right now..
1.WHAT NEW?
+ FlightPlan strunning fixed
+ AirFMC issue fixed (pls. reinstall it plugin)
+ track lost after apply DIRTO fixed
+ improve blackbox info functions
+ minor bugs fixed
r2:
+ altitude calculation on Final fixed
+ Vias drawing for some airports fixed
2. HOW TO INSTALL
- be sure, that you use X-Plane 10.42-10.45 (64 bit only, MAC 10.9-10.11 or Windows 7-10)
- copy unziped “320neo_JARDesign” folder to ..\X-Plane 10\Aircraft\ folder
!!! To update r1 -> r2 need replace only One file:
../X-PLANE 10/Aircraft/320neo_JARDesign/Custom Avionics/sys_mcdu/mcdu_fpln.sec and mcdu_acstat.sec
3 UPDATE YOU NAV DATA WITH FRESH CYCLE (if needed)
v.2.6 use NavData from
../X-PLANE 10/Custom Data/GNS430/navdata/ folder
..X:/X-PLANE 10/Resources/GNS430/navdata/
- “a320/330 Native format” or (the same in fact)
and put new cycle to ..X-PLANE 10/Custom Data/GNS430/navdata/ folder
DOWNLOAD:
http://jardesign.org/a320/download/inst … v2.6r2.zip
