Topic: X-Life ver 1.0 (rc1, r1, ++)
Permanent link to actual release
Permanent link to actual more fresh beta
http://www.jardesign.org/x-life/download/xlifeb.zip
As soon as we post release candidate, we should say what all planned functions for version 1 are done. All we need - make XL stable with current set of functions. Parallel I work on ver 1.1 but too earlier to say any exact about it. Please post all your useful notes right here. I am dont know date of 1.0 release (as usual) - will see, will see.
All principles remain the same - please post you ideas for improvements, post what you like/unlike? post your log.txt + x-life.dmp if Crash happen.
If you prefer use “Bluebell XL” traffic AI library (need at least vet 1.1 beta 6, 7, 8), please download 3 files from
http://jardesign.org/forum/img/m/22/t/p1aiikfio2qnomj024f1tn6u163.jpg
So, now, i just continue coding. Cheers!
Hi Eugeny,
i am testing already rc1 - looks great
but what means exactly gate, stand, cargo, hangar - what are programmatically differences in x-life
small bug - see pics
air canada 322 was landed and then waiting for EL AL 924 (fokker 50) on approaching runway
cargo - for cargo aircrafts
hangar - inside hangars
gate - near terminal
stand - at apron
Is there a difference between "normal" aircrafts and cargo aircrafts in x-life?
Would cargos only stand on cargo stands? Or is there no difference
Cargo not use for traffic this time, but i plan use it in future.
Gate/Stand use well.
OK; rc1, Wonderfully Excellent! Here's to a 100% Perfect flight:
LFMN-LIRF
JAR A330
LFMN SID SODRI A3 NORKA A3 SUDAS UL127 CAPCO A3 MIRSA L127 ELB M729 GILIO STAR LIRF
all logs fyi
THANK YOU Mr. R!
smile
Ok, thanks! If No CTD happen - may not publish logs and damps! Thanks for report!!!
Hi Eugeny,
I have the same problem:
OpenSceneryXpath NOT find
How do I fix it?
OpenSceneryX is installed on my system.
Lehis wrote:
Hi Eugeny,
How do I fix it?
The problem what you just rename it to Custom Scenery/LIB OpenSceneryX/
Need original name, sure.
Lehis wrote:
Hi Eugeny,
How do I fix it?
Thanks )
Hi Eugeny,
I am back on the map! disconnected Saitek throttle, started X-Plane. then connected throttle and made a new calibration.
Started X-Plane for new and X-Life rc1 and engines run normally !
I made a test flight EETN - ENGM. NO CRASH
ENGM: ATC calling for FollowMe car didn't work. On the map I saw the car on other airport end. Calling via "on map" works.
BTW, Strangely enough, I didn't recognized any change or new functions.... (maybe because it was late at night..)
hello,
Very good plugin, I think the planes take off at too low range (~ 15 seconds).
Tried the RC1. Really not bad. But:
• is it the plugin, or me, at LSZH and LFPO I was waiting for 12mins. for DEP on HP, because of a landing aircraft in 25km distance! Waste of time and fuel wink Our boss at SWISS would kill all the controllers wink
can you try different settings (in X-Life settings) in the timing of runway time as 1 and 1/2 mins this is the setting I use and if you take to long at the gate starting things it can effect the timing so I would try some more of the same route and with different settings also do a back route to get the computer use to the route.
some of this is trial and error and only you can do the testing on your computer because of the specks on the computer build.
i hope this helps you to understand the nature of how this plugin works its tuned to your computer...
Ps, please keep me posted and I will work with you to get it fine tuned...
16 (edited by Acei 2016-04-01 17:09:16)
EGLL to EIDW.  Went perfect until I was on final.  I got a traffic warning which was showing just above me on the display.  However, I couldn't see anything with exterior view.  Seemed to be a phantom plane.  Got a GA even though there was nothing there.
http://jardesign.org/forum/img/m/683/t/p1af9cmm4g1rqoqik1sbf4fmgfd3.jpg
17 (edited by captbullett 2016-04-01 18:20:54)
did you turn on the Aircraft show button that displays the position on all aircraft in X-Life, and for the aircraft in the air sometime it will just display a little black dot until it is finished loading. This might take a few mins. to populate.
Thank-you for the work you are doing,
brian
Ps, yes I do see a white marker on you FD ... so it look's to be behind you and should not have been an issue ... and what did the radar reading give you as far as position ?
Hi Brian,
It was originally showing in front of me, then just above/below me and then behind.  I didn't turn on the XL radar.  I will think of that if it happens again.  This is real UFO stuff!
waiting for 12mins
Wow! I will talk to ATC smile Need think about it.. may be need change some in code..
Is it possible to highlight active tab (ATIS, GROUND, TOWER, etc) and show frequency on ATC panel? And may be hide dialogue from inactive tab (freq), as it is done with ATIS tab?
21 (edited by ilankrt 2016-04-01 21:25:00)
From now on we are flying with traffic around us. You have to use the radar screen, first to see the other aircraft around you and second while descending to calculate distance to other aircrafts that are in front of you descending to the same RWY.
On my flight today I saw on radar a small aircraft  on the other side of the runway also on landing course just before I got ATC warning "abort landing". The small aircraft is seen on my ND but you can't know at what level and if it intends to land... . It seems you were in the same situation....
See image (RWY 19L - on the right side looking on screen you will see the other aircraft in red just before landing)
I think that the ATC panel is working well. You get frequencies when you are asked to change from APPR to TOWER to GROUND etc.
23 (edited by ilankrt 2016-04-01 21:47:08)
Just finished successfully a test flight from ENGM to ESSA.
In both sceneries traffic frequencies are working perfect without "logical failures".
ATC FollowMe car appears as it should.
Got a lot of air traffic around airports - that is real X-Life!
I had to abort landing and fly a GA. Is it possible in the future to program ATC giving vector(s) to catch again ILS ?
On ND of the A330 I can see the ILS approach fix but not on FMC waypoints ???
24 (edited by captbullett 2016-04-02 00:39:22)
Yes, it is a good ideal for ATC to give Vector(s) to catch ILS on any aircraft in X-Life for a GA ...
I did a GA and got lost after I got vectored off for a GA and had to go to external view to get my bearings ...
Had a similar problem. I used the local map view to fly a back leg, turn and line up manually. It's OK if the weather is good. With yesterday's high winds I crashed sad
