1 (edited by vatech 2016-05-24 16:10:56)
Topic: KPHX - Phoenix Sky Harbor USA {2 VERSIONS}
For payware (5 star) KPHX - Phoenix Sky Harbor International airport by Nimbus Simulation.
http://store.x-plane.org/KPHX-Phoenix-S … p_399.html
http://jardesign.org/forum/img/m/2234/t/p1af6u5n037001enovi7j7oid73.jpg
http://jardesign.org/forum/img/m/2234/t/p1af6u5rld1b3e54210uq15gi1tdm5.jpg
When you start FMCar and/or X-Life next time, KPHX files will be autodownloaded to your /Airports/ folder.
The 'KPHX - Phoenix Sky Harbor' by Nimbus Simulation includes static aircrafts on parkings and gates, but, due to the arrangement of the objects in the scenery we can't remove them, and we have no rights for adding the changes, or editing files of the scenery. We requested to Nimbus Simulation create a additional scenery without static aircrafts, but in current time, the only one solution exists, it's use the stands and gates without statics. However we created a data files that includes all gates (if in future will be created additional scenery without statics), and noted the places with static aircrafts in Gate Editor.
Please note, that files on server for KPHX will be changed from freeware version to paware from Nimbus Simulation. If you wish to use payware version with traffic, but before used freware version, you must change the data files for KPHX manually, because X-Life don't overwrites files automaticaly.
2 (edited by vatech 2016-03-31 18:04:08)
Re: KPHX - Phoenix Sky Harbor USA {2 VERSIONS}
For freeware (5 star) KPHX - Phoenix Sky Harbor International airport.
http://forums.x-plane.org/index.php?/fi … rnational/
http://jardesign.org/forum/img/m/2234/t/p1aev1gunj179lu4d1uo95hc1c9n3.jpg
http://jardesign.org/forum/img/m/2234/t/p1aev1h5uho7n19mvonm1c69hhu5.jpg
The 'KPHX - Phoenix Sky Harbor' includes the functional 'No static' scenery in the 'KPHX - Phoenix Update 1.02.zip', so don't need to create the separate 'No static' scenery for it. You will find a 'Nostatic' scenery in  \KPHX - Phoenix Update 1.02.zip\KPHX - Phoenix Sky Harbor Intl\Alternative files\Static_Aircraft_off\. Download it from 'X-PLANE.ORG' site with link above. Just copy the 'Earth nav data' folder to you KPHX Scenery folder with overwrite. It will remove the static aircrafts where it need.
