Topic: KPHX - Phoenix Sky Harbor USA {2 VERSIONS}
For payware (5 star) KPHX - Phoenix Sky Harbor International airport by Nimbus Simulation.
http://store.x-plane.org/KPHX-Phoenix-S … p_399.html
When you start FMCar and/or X-Life next time, KPHX files will be autodownloaded to your /Airports/ folder.
Static aircraft in the scenery:
The 'KPHX - Phoenix Sky Harbor' by Nimbus Simulation includes static aircrafts on parkings and gates, but, due to the arrangement of the objects in the scenery we can't remove them, and we have no rights for adding the changes, or editing files of the scenery. We requested to Nimbus Simulation create a additional scenery without static aircrafts, but in current time, the only one solution exists, it's use the stands and gates without statics. However we created a data files that includes all gates (if in future will be created additional scenery without statics), and noted the places with static aircrafts in Gate Editor.
Please note, that files on server for KPHX will be changed from freeware version to paware from Nimbus Simulation. If you wish to use payware version with traffic, but before used freware version, you must change the data files for KPHX manually, because X-Life don't overwrites files automaticaly.
