Hi JAR,
I did a short test of X-Life. So far it worked good with my PC setup. And I think this plugin has a very high potential. A few things I would suggest:
Avoid X-Life aircraft overlay static aircraft of the scenery (e.g. EDDN scenery). Or use only scenery without static aircraft.
Make the ATC giving acoustic commands via COM radios with the corresponding frequencies.
Also, some basic interaction with ATC, like requesting change of FL, would be a real improvement for X-Plane.
If you could realise this, I would pay good money for your plugin.
