- I am creating airports in WED for default X-plane. (Gateway upload)
- Using Latest X-life with serial
- Airport completed and now i am crating ATC taxiroutes by using WED
When i enable the addon all plane spawn succesfully on gates. Problem is they never move and stand still at their gates. All gates created according to their real life properties.
1) I open X-plane 10 and load scenery with a GA aircraft
2) I turn on X-life
3) From the deluxe menu i click ATC icon and open the list for feedback.
Now;
At the list
AC0 is appears as my aircraft. When i enter 0 and click select X-life shows the nodes for its route. But why? It is the aircraft i selected.
AC1 shows no purple arrows. AC2 and others shows purple arrow correctly, but without route (Green Arrow Nodes). Tried reinstall and free version all the same. Is there solution where i can see what cause this issue so i can fix it?(like step by step log?)
Log.txt only shows error "0:01:16.238 E/NET: Download failed with error: 6 for URL http://aviationweather.gov/products/nws/winds/?area=all&fint=06&lvl=lo" altough i have active internet connection with real weather selected.
Btw, ATIS RW and X-life RW differs. I also get "not compatible with X-life" error. If i create test taxiways (1 rw and 2 taxiways nothing more addon works fine)
UPDATE 16.Mar.2016 :
Problem seems to be about Settings slider in X-life (Gate Density, Traffic Density and Interval)
