526 (edited by Ayki 2016-03-16 10:08:32)
- I am creating airports in WED for default X-plane. (Gateway upload)
- Using Latest X-life with serial
- Airport completed and now i am crating ATC taxiroutes by using WED
When i enable the addon all plane spawn succesfully on gates. Problem is they never move and stand still at their gates. All gates created according to their real life properties.
1) I open X-plane 10 and load scenery with a GA aircraft
2) I turn on X-life
3) From the deluxe menu i click  ATC icon and open the list for feedback.
Now;
At the list
AC0 is appears as my aircraft. When i enter 0 and click select X-life shows the nodes for its route. But why? It is the aircraft i selected.
AC1 shows no purple arrows. AC2 and others shows purple arrow correctly, but without route (Green Arrow Nodes). Tried reinstall and free version all the same.  Is there solution where i can see what cause this issue so i can fix it?(like step by step log?)
Log.txt only shows error "0:01:16.238 E/NET: Download failed with error: 6 for URL http://aviationweather.gov/products/nws/winds/?area=all&fint=06&lvl=lo"  altough i have active internet connection with real weather selected.
Btw, ATIS RW and X-life RW differs. I also get  "not compatible with X-life" error.   If i create test taxiways (1 rw and 2 taxiways nothing more addon works fine)
UPDATE 16.Mar.2016 :
Problem seems to be about Settings slider in X-life (Gate Density, Traffic Density and Interval)
527
Looks like xlife does not respect it's own plane size in gates editor.
the ATC just guides me to a "prop" class stand with the jar A320 :-)
little bit too small for the plane...
http://jardesign.org/forum/img/m/552/t/p1adtp4aev1jk29i111709kt1e123.jpg
Acei wrote:
Beta 9.1.  Getting CTD just after XP loads.  Using the JAR A320.
Thanks for logs and dump! What airport was? Are you have a stable CTD in this airport with XL?
529
Hallo JAR
is it possible that there is a conflict between Sound Maxx and Blue Sky Star I installed (resp. X-Life sound)?
Only one way to check this - delete one of this plugin / another plugin
BUT if your default sounds a320neo work well with Sound Maxx, BSS should work well too, cause they are use the same sound plugin.
530
It was EIDW.  I'll try again at a different airport.
531
Hello.
Loaded into the airport EDDM, turned on the plugin, flights not planned, wanted to see how the traffic works. After some time x-plane crash.
532 (edited by captbullett 2016-03-16 02:27:35)
2) I turn on X-life
Now;
At the list
This is going too be a Skype issue that JAR is going to need to talk to you directly about most likely.
thank-you for your help,
Today i will try to create it step by step.  First i create runways, then TEMPORARY taxiways. I will try to find the step when AI halts. smile
I will also check one of the supported airports and see if anything wrong with the addon. I will prepare my report and write here. Thanks for your support.
534
Here are all required files :
Use of 9 and 9.1 version
Start in EIDW to EGLL
X-plane crashes when I click on "generate" when creating flight plan .
A320 JAR   (Happens with all aircrafts)
Attachment icon bbox_log.txt 109 b, 176 downloads since 2016-03-16
535 (edited by Ayki 2016-03-16 10:14:24)
Checked with LTAI (Supported Airport) and here is the results. (with 9.1b)
- None of the traffic moves. Aircraft 0 still appears as my aircraft. Aircraft 1 cannot be seen, Aircraft 2 and more can selected and seen only with Purple arrows, no green arrows and they never move. (Using Beta 9.1 with Serial supported at Beta 8)
- Reinstalled addon, using free edition. Since it is not deluxe edition i cannot see aircraft list and use the menu.
- Enabled addon, AI Traffic Working fine, if i register again with serial supported ( J.A.Romanov gave me big_smile ) addon again stops working (no AI movement).
ABOUT:
"0:02:51.862 E/NET: Download failed with error: 6 for URL http://aviationweather.gov/products/nws/winds/?area=all&fint=06&lvl=lo"
- Has no effect on AI traffic, when i select departure info Addon succesfully report departure runway and taxiways route to it.
UPDATE:
X-life AI traffic again stops working if i move sliders to  Air Traffic Density %150, Stand Busy %90, Interval 1 minute.
If i never touch the settings slider X-life works fine at supported airports.
NOTE: without the key.reg i cannot able to register again, says e-mail error (it is correct one)
Final UPDATE 16.03.2016 12:10 (UTC +2):
Registered by using key.reg file.  X-life working beautifully.
Reason behind the problem looks like Settings slider in X-life.  (Traffic density, Gates density, Runway interval)
536
that was AMD OpenGL driver error, as I check via damp.
537 (edited by addisonadolf00 2016-03-18 07:23:44)
Thanks for solving this problem beta 9.1 Is good... smile smile
Ivr solutions
*****Hey********
538
Another successful flight.
SSG784
Aerosoft EDDL to Aerosoft EGLL
Flight plan entered manually
EDDL SID MODRU Z717 GOBNO UZ717 MAS UM617 SOGRI UL608 DENUT UL610 RAPIX L610 LAM STAR EGLL
539
I reinstalled my AMD drivers.  I got a little further this time, but still getting a crash when trying to create flight plan from EIDW to EGLL.
540
be better check this via skype. My skype j.a.romanov Please contact if possible!
541
Test Flight  EDDH - EHAM - LOWI, using A330 on iMac27
1 no crash but fps falling dramatically on approach.
2 EHAM: ATC advice to ILS  landing on RWY 04 . This RWY has not ILS and is too short (2014ft).
Need to correct: First of all the program should recognize ILS RWY on every airport.
                         Second I chose landing on another ILS RWY (36L at N wind). Program need an "IF" loop
                         to recognize programmed RWY on FMC and if it is not the ordered (04) to change parameters
                         to the chosen one (36L). Otherwise after changing RWY ATC becomes useless.
Need to correct: X-Life aircraft on stationary pseudo aircraft not looking good.
3 LOWI : ATC advice to ILS landing on RWY 08. Again RWY has no ILS (same problem).....
need to correct: It happens quite often also at LOWI, that after leaving the RWY another X-Life aircraft stands on my way,
                        although it is not a holding point for take-off (in the middle of RWY distance)
Question: Is it possible the radius of the aircraft traffic over the airport to extend further on?
After 2 crash events on the same route I tried out some changes and discovered that the installed plugin RTH was probably the cause. Anyway after deinstallation 2 successful flights.....
Refreshing METAR (actual weather) during flight with A330 cause aircraft to pitch down left and roll over sinking rapidly to the ground! Fortunately, I flew at high level and keeps the nerves, to get the plane back under control.....
542
The same thing happens to me (see previous posts #507 and #534 ).
Awesome. Another successful flight.
Aerosoft ATR 75-500
Aerosoft EGLL to Aerosoft EIDW
EGLL SID CPT L9 STU M17 VATRY STAR EIDW
I now have 3 favourite plugins.
X-Life
g2xpl
Ultra Weather XP
544
Aerosoft ATR 75-500
X-Life
g2xpl
Ultra Weather XP
glad to see we have the issue solved now it take team work on this type of software ...
Aerosoft ATR 75-500
X-Life
g2xpl
Ultra Weather XP
Hi Brian -- Yes absolutely.
In my language --- "Vele hande maak ligte werk" (lots of hands makes work easy).
Cannot wait for sound with X-Life. It will most definitely then be the very best plugin available.
546
After my tests i have found out the problem. I have attached a screenshot.
http://jardesign.org/forum/img/m/2249/t/p1ae1s038bsdp13ln1vjcja9veh3.png
X-life AI Works, if Airport gates/stand busy (%)  selector is at max this point (marked as red line in the ss), or lower.  If i increase % beyond that red line, AI never moves.
547
If you sett % too hi, for some airports, ATC cant calculate route, or cant find empty gate for needed aircraft type
548
and you welcome to skype j.a.romanov
549
Another great flight.
Aerosoft ATR
Aerosoft EGLL to Aerosoft EHAM
EGLL SID BPK Q295 CLN l620 REDFA STAR EHAM (Cycle 1603)
Two small little niggles.
At EGLL I ended up in front of a 747 (had to taxi through it -- attached pic)
I got runway ILS runway 36L at EHAM, but 36L does not have ILS.
550
Test flight b.9.1 LSZH - LFML A330 iMac27
Hi JAR
no crash, Nice flight and for the first time I saw another aircraft on the same route just over me - great!
LSZH: traffic ok. One aircraft on same taxi way didn't stop and went through my A330...
LFLM: Appr to RWY 13L as it should be.  I got in trouble because difficulties to change FMC programming (to discuss under A330)
Nice airport, but full with static aircraft and poor traffic on taxiway (airport gates busy 75% and JAR add-on installed).
Question: in the thread I opened in X-Plane.org, there was a complain that X-Life isn't working on several airports. Are we at this stage restricted to use X-Life only for airports on your Map ? (perspective..)http://jardesign.org/forum/img/m/1591/t/p1ae27j4i61tu97srh2735u7lm3.jpg
