1 (edited by Homer.Simpson 2015-03-14 10:20:04)
Topic: airberlin (D-ALPH) updated
Well I did an overhaul to all my repaints and add some more detail. Because of that I started new topics for each Livery.
airberlin livery for the A332. In real life airberlin uses the A332 equipped with PW engines:
http://jardesign.org/forum/img/m/10/t/p19gbri01o181fcnd7o2m0oje3.png
http://jardesign.org/forum/img/m/10/t/p19gbri01o16jkbftbjqnbna794.png
Now with window frames:
http://jardesign.org/forum/img/m/10/t/p19gbri01on27qfb17ju1b4gnpk5.png
New gear door placard:
http://jardesign.org/forum/img/m/10/t/p19gbri01o190e1dvr1ofbtmgqcj6.png
Now with "Bumbers" on the AFT doors:
http://jardesign.org/forum/img/m/10/t/p19gbri01odg213sng03jmh14gg7.png
Real life picture:
http://www.planepictures.net/netshow.php?id=1280802
Enjoy flying it ;-)
Re: airberlin (D-ALPH) updated
Nice one! Thank you smile
Looks fine to me !
thank-you for the work.
I didn't understand how to install the plate.txt and what it changes.
Can you explain this to me please.
6 (edited by Homer.Simpson 2018-01-10 22:16:27)
In the 330_JARDesign folder you will find a file called plate.txt. Duplicate that to have a backup and then replace the original one with the plate.txt file comming with my livery. Then you will have the right registration and the so called SELCAL Code "painted" on registration plate under the ECAM Display in the cockpit. I think with the original plate.txt file the Version Number of your JD330 is "painted" on that. The plate.txt file unfortunately isn't changed with the livery and has to bechangend before you load the A330 in X-Plane. Once loaded it can't be changed without reloading the airbus. But you don't have to change the plate.txt at all, you can just take the original plate.txt file coming with the JD330. It's just an addition to have the correct one available and to make the livery also in the cockpit look more realistic.
This is what it looks like, with my plate.txt. (Okay it's taken from D-ABXA instead of D-ALPH)
http://jardesign.org/forum/img/m/10/t/p1c3h1ti0taaj15351d2s1kkv1mdj3.png
Your theme is very informative and meaningful  vex 3
