251
sky33 wrote:
Thank you SATCH10, but can you tell me how to do please?
Make sure that you have the latest version of ATC Chatter (1.61) .In the ATC Chatter control panel you need to tick the "External Integrations" box. That's all there is to do.
Intel i7-7700 @3.6GHz, GTX 1060 6Gb, 16Gb RAM. Saitek Pro yoke and 2nd quadrant, Saitek Multi panel, TM rudder.
X Plane 11.31, Jar A330, BSS sound pack, X LIfe, FM Car, ATC Chatter, XEnviro, Better pushback
252 (edited by sky33 2019-02-08 19:22:00)
thank you very much bro, i have the latest version.
253
Hi everyone.. why do i see a Cessna in front of the plane after they take off.  I paid for the x-life full version.
254
Thanks to Eugene. Cool plugin. I can not imagine the flight without him.
255 (edited by rafgath 2019-02-13 08:11:45)
For some reason metar is still not working for me. I have only one line in ATIS window containing Runway for departs and Trans lvl. I use X-Plane 11.32 and Active Sky XP.
256
http://jardesign.org/forum/img/m/7687/t/p1d3j09ae8d3d9ml13dok2h1e9u3.jpgXP11.31 + ActiveSkyXP. Still not working metar completely.
257
May be an explanation here  :
https://developer.x-plane.com/2019/02/x … fix-maybe/
It works as usual !
259
Please use this fix:
http://jardesign.org/forum/viewtopic.php?id=11426
260
JAR - it doesn’t change anything. Still the same issue. Xplane 11.32 + AS XP
261
Thanks for all you do. Very nice
262 (edited by cpuwolf 2019-02-16 06:41:49)
v.4_090219 constantly crashes XP with TBM-900 (tried 3 times)
by removing X-Life, everything works fine
XL: 1 : JARDesign plugin: G:\X-Plane 11\Resources\plugins\X-Life\News/news.txt file updated.
XL: 1 : JARDesign plugin: G:\X-Plane 11\Resources\plugins\X-Life\News/070718.txt file updated.
XL: 1 : X-Life plugin: Update News: 070718.txt
XL: 1 : JARDesign plugin: G:\X-Plane 11\Resources\plugins\X-Life\News/040418.txt file updated.
XL: 1 : X-Life plugin: Update News: 040418.txt
XL: 1 : JARDesign plugin: G:\X-Plane 11\Resources\plugins\X-Life\News/210318.txt file updated.
XL: 1 : X-Life plugin: Update News: 210318.txt
XL: 1 : JARDesign plugin: G:\X-Plane 11\Resources\plugins\X-Life\News/090318.txt file updated.
XL: 1 : X-Life plugin: Update News: 090318.txt
XL: 1 : JARDesign plugin: G:\X-Plane 11\Resources\plugins\X-Life\News/310118.txt file updated.
XL: 1 : X-Life plugin: Update News: 310118.txt
XL: 1 : MessageGreen: X-Life Traffic by JARDesign Ver.v.4_090219
2019-02-16 13:08:08 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:09 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:10 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:11 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:12 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:14 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:15 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:16 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:17 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
2019-02-16 13:08:18 TBM900[except.c:282]: Something reinstalled our exception handler, replaced it with 0000000000000000
263 (edited by cpuwolf 2019-02-16 06:40:54)
v.4_090219 AI(SWA3569) is stuck forever in KSNA (X-Plane 11.31)
http://jardesign.org/forum/img/m/2328/t/p1d3qggjpi1pcki2j1ictg9u69e3.jpg
264 (edited by vnub 2019-02-16 15:57:37)
i have the same issue with Zibo 737 3.33g...Xlife the luxe stops working af first and some time later it crashes Xplane.
265
I also think there is some problem with TBM-900. I always delete the entire folder of X-life when using TBM. I just did a flight using last Zibo version 3.33g and everything worked great.
266
Me too I have the same Bug ...
267
Hallo , vielleicht kannst du mir weiterhelfen .
Ich habe auf meinem Mac Mojawe aufgespielt und seitdem geht der A 330 von JARDESING nicht mehr.
ich habe mir den hotfix herunter geladen , Aber ich weiß nicht wo der jetzt genau hinkommt. Mit der Anweisung komme ich nicht klar .
Danke für deine Hilfe .
Gruss
Peter
268
JAR - Any chance to fix METAR ?
269
http://jardesign.org/forum/viewtopic.php?id=11426 <- quickfix for metar. Did you try that one?
270 (edited by andrew777 2019-02-27 16:39:59)
Hi All,
After long time not using xlife i installed xlife v4 again. I test it together with JD320 latest release.
My config: windows 10, xp 11.33 (no beta), JD320 v3.3, xlife v4
Navdata updated to airac 0219
Couple things i run into
- when everything setup in a320 i try to import fms into xlife. This is not working, nothing happens and the route stays empty. Try it again and xplane crashes.
- Because i use simbrief, i try to copy the route with sid and stars. This is not accepted in xlife
- I created a txt file with the route (EHBK SID OSGOS DCT LMA STAR EDLV). This is accepted but without sid and stars. Don’t how that works or why sid and stars are not recognized by xlife, for example LMA1W or OSGO1B
- After everything done manually, i try to send my flightplan to ATC, again xplane crashes. (I saved the logs, if needed)
Are there any things i have to repair or install additionally to get it stable?
I have run a flight with only xlife but without atc and another airplane, it keeps running without a problem
Thanks for any support or pointing in the right direction!
Andrew
271
Have you seen my last posts ? Is this fix working for you ?
272 (edited by Darko24 2019-02-28 08:35:45)
andrew777 wrote:
Hi All,
Andrew
It works OK
If you use Simbrief, create plan, open route finder it is give you better route as suggested route, then generate OFP, Then download plan for your planes type and x-life ( you can use Simbrief downloader).
In X-life you can import from your aircraft flight plan or X-life plan, I usually use import from aircraft flight plan.
X-life use only SID and STAR and your download flight plan from Simbrief know that . When plan is accepted X-life, Delivery  give you a suggested SID, when you request clearance from Delivery, to input you in flight computer. The same is with STAR you get when you report TOD in flight.
273
I have this problem but didn't figure NVidia setting into the mix. Good to know. I thought maybe I needed to update x-life but don't see anything other than this.
Ozzy Jones wrote:
With X-plane 11.30, turning ON threaded optimization in the nVidia control panel is giving me a big (5-15 FPS) performance boost.  However, as soon as I turn on x-life's traffic, my FPS drops to about 10, if the system doesn't crash altogether.  Basically seems like threaded optimization and x-life are incompatible right now -- perhaps this has been the case for a while, but as of 11.30 it means you're sacrificing more performance.
Any plans to make X-life and threaded optimization play nice together?
274
I have a problem with busy runways:
For example in LEMD (Madrid - Barajas) one plane is landing on 32R (32R/14L), and because of that ALL (4 of them) airport runways are busy... I understand that maybe this is like this because of the go arounds, but in real life I think it doesn't work like this. The ground trafic is sooooo slow because of that, and maybe i need to wait 5/10 minutes holding position on the runway.
Is this a bug? Is possible to change any parameter to change this?
Not a bug, need to wait patiently and regulate climate so as not to bathe in the sweat...
