Re: [actual for XP11] GHDeluxe v.4
Did a test using just a single monitor.  The widget worked and displayed properly and I was able to add contur image.
Returning to multi-monitor and same result large black square.  I assume the plugin doesn't know how to place the widget content at this location or something.
The equipment seems to run really slow when using the widget over the control panel.
Maybe support can comment on multi-monitor support.  For now the control panel continues to work as before and now I can have a hotkey to bring up this panel. Thank you for this.
lidlrico wrote:
Why do different paint schemes not work for ground handling?
Why? My bad smile Fixed with updated version.
Ah, thanks . Have overlooked that there is a new update. Thank you
Thanks so much for your excellent work.
Bruns wrote:
Oooh. I didn't have idea this great update is coming! Just downloaded and tested with Zibo. Only positive things to say. New widget is really cool and it was really needed! Also having set to almost every popular aircraft out from the box is great thing!
But I think in first post on supported aircraft you meant JarDesign A330, not Flight Factor... or do you have some inside info? wink
Yes, sure! Fixed. Thank you!
30 (edited by maverick-747 2018-06-25 20:42:51)
https://pp.userapi.com/c824500/v824500880/15db90/0faStDWq6W0.jpg
I have some issue with this ladder on A330, door opened but then it closes.
P.S.  This is defolt set.
The Key-Command 'CommandDriveUp' does not work for me. Here I have to go over the menu bar.
While the Key-Command 'CommandDriveAway' performs well.
Actually bit disappointed!
There is still no provision for creating two different sets per aircraft type or rather choosing depending on whether aircraft is parked at the gate or parked on a remote stand.
Only the default liveries work, the older custom liveries don't activate?
Really great update, keyboard activation is a a real step forward thanks, speed of livery selection is also highly speeded up and far, far faster.
Only thing is it all or nothing? unlike with the still available older control panel...  an idea is if you select items in blue then when they are active they turn red, so if you press individual items again they turn back to blue (or green) and the reverse animations are started when you press the drive away?
I have some issue with this ladder on A330.
This doors I must be open from plane menu.
http://jardesign.org/forum/img/m/6583/t/p1ch1hng521o11ernfd616abe833.png
Although the download link says that it is GHD_230618.zip, in the Control Widget, in Mac, it appears v.4.140618
36
the way is exist, sure. You need to have 2 copies of aircraft. Next you should take .set file first aircraft and put it with ghd.set name. Next you should take .set file second aircraft and put it with ghd.set name to second aircraft folder.
37
mac.xpl updated for true date
you may update just mac.xpl file (attached)
Set is fixed and replaced at original ZIP, or you can just take attached file and put it to
../X-Plane/Resources/plugins/GndHandling/Sets/Default/ folder
Creating two sets is one thing, but how does one tell the plugin which of the two sets to use? There should be an algorithm that when parked at a gate, the set to be used is the one fitting that scenario. How does the plugin know where I am parked, or in other words how can the user influence which set is to be used.
Other problems with the update. I don't show the widget and there was no manual in the download zip.
40
Hi, I have a problem that all the vehicles move not smoothly, very jerky. Everything else works fine.
41 (edited by m5001 2018-07-02 09:46:05)
Hi Mr. Romanov,
I bought the GHDeluxe, very beautiful and the installation is very easy and I received the code in less than 1 minute.
Thank you very much.
Thanks !!
Please my plane crash when i have the FFA320 (CEF) and GHDELUXE in the same folder plugins.
help solve this problem
44
Please contact www.support.jardesign.org or skype j.a.romanov with log.txt file just after crash happen - we will try to check this issue.
45
I do not know how to operate autogate, need help. Do not understand aircraft set for stairs, fuel, service, gpu. Cannot get or know how to operate jetways, and ground handlers.
Thanks for the new version smile
What would be really cool if there were still animated people smile
Hey! The custom liveries menu does not work for me hmm I select a livery but it does not work it just stays on the default one. I did see someone comment the same thing and the dev replied but i didn't quite get what you have to do.
48
My liveries do not work either.  I've tried copying the win.xpl and mac.xpl files like explained in previous responses but nothing is working.  Only the default liveries work.
49
Hallo Guys,
I am using X-plane 11.32 and Win 10. After downloading GHDeluxe and putting GHD into Plugins and I start X-plane, X-PLANE  crashes. Evering is all mixed up and it takes me sometime to reload x-plane. Something is going wrong so I need your help.
Ronnie
50
I have similar issues,  changing liveries does not work and when trying to add a vehicle Xplane crashes (XP11.30 non beta).
From the forums it seems quite a few people have problems with switching liveries.
Can this be fixed please ?
Thank you !
