I would like to remind on what HomerSimpson wrote some times ago:
"Hello all together,
well the A330 is released and now every day there are multiple topics poping up in the forum.
So to keep the work for Jar and Slava easy and structured, I would kindly ask all users to use a standardized bug reporting. We used that in the alpha/ beta phase and it was quite well because you clearly could see which bug was fixed, if there is a discussion about bug and so one.
So my suggestion are:
1.Search the forum before you open a new topic. Your bug might be already reported.
If your bug is already reported:
Post your findings to this existing topic.
If your bug wasn't reported before:
2. Open a new topic
3. Choose a Topic subject which describes your bug in the most shortest form and use one of the following to identify your problem in front of your topic subject:
[sys] for bugs concerning the aircraft's systems
[fpln] for bugs concerning flight plan
[vis] for bugs concerning the outside/ inside look of the 3D objects
[other] if you can't put your bug into one of these categories
4. Describe your bug precisely as possible in the write message field.
5. Attach X-Plane Log.txt and A330 bb_log.txt.
6. If possibile add sources from FCOM, POH, AMM proving JarDesign's A330 is wrong.
And last the most important point for a fast fixing of bugs is that you please post only one bug into one topic
To my mind if we all spent the time to do our bug reporting like that way, JarDesign could easily work through the reported bugs
Best Regards
Lukas"
