251
Guys, please cool it. Remember why we are here: To enjoy ourselves. AND to help each other out when things go wrong. Both your arguments have merit. There are still a lot of issues with the JAR busses but in general, if they are set up right (and how to do that is a bit of a mystery, unless one watches all the videos and reads all the posts etc.) they do work pretty well.
Because it is not game but aspires to be a real simulator of the actual bus it is not trivial to get it to work. Newer users encounter a lot of issues and I would plead to the experienced users to be patient and remember how it felt in the beginning. From my own experience, only about 1 in 10 issues were real bugs but it is hard to find out because there is so little support through the forum. However, if you Skype Evgeny he will help. And he is the best authority on the products. So I really recommend doing that if there is a big issue. Happy flights!
252 (edited by Black4956 2018-05-24 05:28:56)
okay I do understand what you mean. Anyway I was very emotional in this case. For this misbeviour I want to apologize myself. On the other hand you have to understand my overreaction. I'm a bit frustrated!  :-(
I'm still looking for a very elaborated tutorial which I could download as a pdf-file explaining step by step. Yesterday I made a very interesting experience. Using the speedbrake made everything easier to control the speed. Without the help of the speedbrake for me it simply wasn't possible to reduce the speed. This fact is completely new for me because I used Aerosoft's a320 in the past.
Unlike to the JARDESIGN a330 the speedbrake didn't have this importance.
with kind regards
253
Hi, am i the only who who has this problem?:
The fmc dont update estimating time until passing over the next waypoint
Estimating time dont considere winds?
Hello guys!
So i've been chatting with JAR on skype and we went through the steps on why TCAS does not work, we tested it on X-Life and it works as normal, however on VATSIM, it does not work but the JD320 does. He will be talking to xsquawkbox devs and will hopefully fix this issue! big_smile
255
Hi guys,
Many thanks to Alexr03 for this meeting with Jar.
it might be the same issue on Xivap.
if you got the fix, let me know, i'll try it on xivap.
concerning Estimated time for waypoints, i noticed this as well.
But i could not say if it's wrong or if it works as it should.
Alex
256
I can confirm that estimated times not work well. During the past Cross The Pond event flying the NATS I needed to use the LittleNavMap software for calculate the next reporting point times.
257
Hi JAR,
Anything on a fix for the TCAS in the 330 ? I can confirm that I cannot see or hear traffic... nothing on the ND... All previous versions worked fine... I am using the latest one.
My specs: XP11.21; IMAC 27
Thanks for ylour help
258
Rest assured an update for TCAS will be released soon; https://i.Alexr03.com/Fx527PM056tF.png
259
THANK YOU
260
Problem JARDesign A330 Warnhinweise     Noch eine Frage , wenn ich den A330 geöffnet habe erscheint unten : Framrate is too low ( 19 ) and affects the control of the airplane , please decrease rendering settings .
Ich habe xplane 11 auf Mac
261
Hoi Taximann
Du kannst im FMC unter Settings: Show FPS Low Indication oder so mit off ausblenden. Leider speichert er das nicht, so musst du dies jedesmal von neuem machen.
Ja, auch ich muss das machen (MacPro XP11)
FMC -> go to Settings: Disable fram rate low warning.
It let's you not safe this setting, so you have to re-do this every flight.
Yes, also I have to do this
Luke
262
I just bought the A330 aircraft so far great airplane  behaves fantastic,,im just wondering  if the JARD team will work on remodeling the engines they dont look realistic at all especially the edges do not look rounded, they look like many lines putted together to make a circle . specially when when you set the camera on the window view. Is that  in the future to do list ?  Thank you very much for the great work
263 (edited by dima_gurec 2018-07-09 10:08:26)
I have Version of A330 3 R4, When goes rain, on glass pink artifacts.
264
S3rg1o wrote:
zasavage wrote:
@JAR
Evgeny  , on V3.0R4 ,
I have identified that CEF plugin stops the sound win.xpl and others not to load .
Yes I did check with all my plugins , and the plugins_disable.txt is in the folder
Lawrence
Thank you for that! you've just solved my sound issues! I can confirm sounds are all on and properly working, with that CEF plugin out of the plugins folder. I've saved it aside XP and now the A330 loads perfectly!
BTW, do you or anyone know what it does? "Disabling" it, XP loads perfectly, with no errors or warnings...
This fixed the 'No Sound' problem for me as well!
Cheers,
Don Dormehl (V3 R4)
265
Just want to say thank you for the improvements! This 'Bus' is now a pleasure to fly - no more 'Hanger Queen'! The improvements in the FMS are phenomenal!
Cheers,
Don Dormehl
266
I am sorry. I do not have the time to do a log text or any other trouble shooting for this latest update on the V3 330.
On three tries to fly from Japan to Hawaii the plane did not follow the course consistently.
The Fuel prep window  would not work and when I tried to input values into it..XPlane crashed to desktop.
If I get time, I will put the plane into my xplane 11 with no add on's and send you the  log text.
I love your planes when they work.
I am using:
Mac OS 10.13.5
Imac Retina 5k,27in, late model 2015
4ghz intel core i7
32 gb 1867mhz ddr3
and Radeon R9 M395x 4096 mb
XPlane 11.25.r2
Saitek x55 Rhino Throttle
and
Saite x55 Rhino Stick
267
release 5 of version 3 just posted with improvements:
+ VATSIM/IVAO ND traffic indication fixed (need check and report is it really work well)
+ some kind of CTD fixed
Download link you can find at first post of this topic, please.
268
with the last new version all works ok but i dont see the engines or better they are empty ( no turbine inside)...help
269
did you reinstall full aircraft?
270
271
TCAS WORKS WELL !!
thank you very much.
272
m5001 wrote:
I downloaded the JD330_v3 file now, I did not find the _NavData folder.
EDIT:
Oops, in beta 5 it also did not have the folder.
A LOT of users usually delete _NavData folder with default navdata for some reason and contact support why aircraft not work. So we decide just move default navdata more deep inside.
Hello! So do I need to update the files in this folder or not?
273
ZYMazai wrote:
EDIT:
No. Not need.
274
Alex R wrote:
TCAS WORKS WELL !!
Thanks for reporting this!
275
TCAS with IVAO works fine as well for me. Thank you!
