Topic: active runway problem
X-Life seems to become confused when an airport has more than one runway. For example I am trying to get Gatwick airport running smoothly for AI traffic, now Gatwick has two runways, 08R/26L as the main one and 08L/26R as only used if really necessary. I leave the tick boxes for that runway unchecked so hoping it is recognised as being unused. The problem arises when traffic arrives at the hold short line for runway 26L from taxiway A, runway 08L/26R then immediately becomes registered as busy even though no other traffic is anywhere near it. This causes landing traffic on runway 26L to stop on the runway thus holding up waiting aircraft which then remains there and nothing ever moves. I have tried several different combinations of taxiways to try and avoid this problem but without success. It also occurs at other airports with multiple runways. If you just enter your aircraft, taxi and take off, you probably wouldn't notice but if you sit and observe the Ai traffic for 20-30 minutes it soon becomes apparent as the airport becomes a log jam. Any help on this issue would be gratefully received.
