326 (edited by dudleybrooke 2018-08-01 12:35:20)
This aircraft needs work, as soon as I try to edit a flight plan in the MCDU everything just locks up, it's just useless.  A330 is fine though.
SandyLee wrote:
Let me dream a little about a new JD320
- more stability than V3 .. i think this can be fixed with remove of SASL like the A330
- remove of the endless clicking sound when pressing r/l arrow keys in FMC where they are not valid
- Usage of Xp11 navdata, i dont like it to have x positions with different navdata .. its not so good when different part of sim uses different data (Aircraft, traffic/atc addin, external map app, ....)
- a jacket for the FO, i like it cold in my cockpit big_smile
- airport nav map on nd .. i have seen this on a real A321 video .. i think JAR has the base technique, because of FMCar
- all rotation knobs rotate right for mouse wheel up and rotate left for down .. current version is not consistent
- move switches with mouse wheel too (esp. multi position switches)
- more realistic speeds/flight physic .. i dont think that every managed decent needs Speedbrakes  "we need more drag sir"
- moveable MCDU, undockable, to second screen
- performance calculator (V Speeds, CG, ZFGW, runway length, runway condition, to shift, ...)
- default x-camera preset
- both cockpit seats filled with people for outside view .. best selectable female/male big_smile
- transparent schematic throttle display (when moving throttle) as overlay on main screen to better hit clb and flex
- better handling of following flights without reload aircraft
- better handling of in flight changes of destination
- better resume of f-pln navigation after manual HDG or DCT
- handling of TOGA, fly go around part of STAR, return to F-PLN after TOGA
327
can xp10 serial keys still be converted to xp11 serial keys? , did it for my jardesign 330 but did not for my 320. can it still be done?
328
No Sir
329
can there be a plugin built for the Logitech multi panel, radio control and multi switch devices to work with the a320 plane?
330
i have a problem with the aircraft running on xplane 11.26, all sounds are crackling and feels like slow
331
Will this aircraft ever be updated again????????
332
Facebook Posts in Jar group give hope for a new version with new
3d model and lights .. and i hope systems too
X-Life Deluxe
GHD
FMCAR
JD320
333
This is a serious problem. JAR320 can't balance automatically. When he's in the cruise phase, the balance lasts for DN4.0.
My X-plane 11 platform is 11.30B2 version. I don't know if this is due to the problem of X-plane 11 version.
When I use the nose wheel steering shaft, it adjusts the scope of my ND screen.
Please help me get the best solution. Thank you!
334
Hi Sir return on X-plane 11.26
335
Love XP11.30 and the JD320 because the FF320 ist unflyable for me for performance reason. But, JD320 is still very good.
Any solution on the balancing / auto trim issue causing the nose to trim down in cruise?
THank you guys
336
THank you guys
It is XP10.30 issue. Will be fixed with our upcoming update
337
Any idea when we can get the JD320 update I still don't have running Taxilights
AMD 1090T 3.2 GHZ
16 GB DDR3-RAM
AMD Radeon R9 390 8GB GDDR5
Windows 10 Pro 64 Bit - X-Plane 10 and 11
338
Very soon. Sorry for that
339
@dron420: Hello: Will the landing dynamics be addressed as well in the update? Meaning, when I'm about to land the nose dips toward the runway and the plane always does a hard landing.. It's not a smooth flair and touchdown like the A330. Thanks very much. I really hope the update comes soon because I love this plane.
340
Can underline this, for me much better than the overloaded FF320 with all that fancy stuff like integrated web browser what makes it unflyable on my rig. The JD320 looks better and runs much smoother. Would be a great loss if it keeps to be dead in 11.30
341
The pitch trim issue is gone in 11.30 b6, works well now without patching the aircraft itself.
342
Great! So it's easier to land now? Thanks
343
I have a problem... When climbing the aircraft levels off to prioritse speed. The aircraft should still have a positive climb when accelerating. E.g. when at FL100 it levels to reach cruise speed where it should maintain climb as well as speeding up. Any help appreciated in fixing this.
344
comes the update in this year?
345
We hope so.
346
I cant activate my a320
347
Did we muss to buy the new update?
348
It will be free
