@jagudelo
I had the same problem. It can be, that your Reg key is corrupt. Remove the "key.reg" from "X-Plane 11\Resources\plugins\X-Life" and register again. This helps me out.
@all Is there a way to make the Gates at EDDM a bit more localized? And not only at EDDM... all over the world! At EDDM terminal 2 is never ever a Western B737 parked. These Gates are Lufthansa Gates. It look's really god with all these planes, but a Western 737, a DHL Cargo plane on a passanger Gate for Lufthansa ??? Never saw these planes in real at EDDM Hmmm. All Gates are spezified to "DHL". Whats wrong there?
Last but not least, here are my points for the: "plan for the future":
As described above, the aircraft at the airports should fit in with their regional areas. At the very least, however, no completely "foreign" aircraft from anywhere in the world should park at gates that even the country does not fit. Cargo aircraft should NEVER be at the gate.
Unfortunately, aircraft often start and land in the wrong direction. The ATIS specifies a runway, Delivery says a runway exactly in the opposite direction. Sometimes even with a tailwind, that really should not happen.
For the ATC leadership itself. Let's bring some variety into the "game". Do not always climb on the same FL after TakeOff. For example, Install climbsteps.
Aircrafts should not be able to drive through "me".
Of course, ATC should not give a TakeOff clearance if the lane is not clear, or if there is a plane approaching that is so dense that the pilot can be recognized.
Well, for now it should be that way. Finally: A god plug-in!
B.R.
