ilankrt wrote:Just now I finished another test flight A320b7
Everything works fine under X-Life
1. The problem looking from left sit to left window 90º (headrest as a white oval disturbing view) remain although the 3D sit position is more frontally .....
2. This should be checked. Landing on RWY 14 with headwind 14 kt from 143º, aircraft was swinging hard (also under AP) !!!
3. Strips on cockpit windows seen from outside
Beside this disturbances I had a great flight and now awaiting the new release.....
1. I adjust the viewpoint by moving camera a bit forward to avoid looking into seats etc.
2. Have you turned off camera shake in the MCDU settings? I find it too severe and turn it off when I remember (it should really be off by default)
3. I can confirm the stripes on the cockpit window in outside view. That's a XP11 issue on all my ac.
