Topic: EGCC for the Manchester Airport 4.0 scenery
The original EGCC.dat was slightly modified to fit (some stands/gates removed and added):
http://forums.x-plane.org/index.php?/fi … r-airport/
Re: EGCC for the Manchester Airport 4.0 scenery
Can you please tell us where to drop this file???
Thank You!
Dennis
In the Airports folder in the plugin directory. Note that there is already a file there called EGCC.dat, this file is for the payware airport. Either backup it up or replace it. Note some added stands/gates needs to be modified in the gate-editor.
