Topic: Plane not loading
Hi, I recently got this addon, and I've downloaded the latest version.
I got it to work a couple of times after re-downloading but after a few new flights the game just crashes upon loading. log.txt says "--=={This application has crashed because of the plugin: 330/mac.xpl}==--"
I'm on Mac M1 Big Sur (Perhaps updating to Monterey?)
Solutions appreciated
Re: Plane not loading
Not need update Mac OS. This is not a reason.
But this may be Mac OS security issue.
JD320/330 should work well under Catalina/BigSur/Monteray. Please redownload JD320/330 and reinstall it from:
http://jardesign.org/forum/viewforum.php?id=44
Next, please follow this instruction***:
http://jardesign.org/forum/viewtopic.ph … 793#p31793
*** Or directly this steps:
1. Open MAC OS System Preferences -> Security&Privacy -> Accesibility and check X-Plane already there and X-Plane checkbox is checked.
2. Install aircraft and load aircraft: MAC OS will offer you some choice and every time:
- when you have OPEN option -> click OPEN and next click ALLOW ANYWAY at System Preferences -> Security&Privacy -> General tab
- when you have CANCEL option -> click CANCEL and next click ALLOW ANYWAY at System Preferences -> Security&Privacy -> General tab
3. So, after several clicks aircraft will load. Next use X-Plane menu and select DEVELOPER -> RELOAD AIRCRAFT
4. During second aircraft loading MAC OS will offer you some choice and every time:
5. You will see activation box. Please input your serial key and select activate.
6. Reload aircraft.
If no luck - Seems like it's some sort of special issue. Sure, you can contact me via skype j.a.romanov for direct help - we will check this issue online.
Hi, thanks for the reply. I have followed the steps mentioned and it works now, however when I try to load it in the air (3nm/10nm approach), the game still crashes. Other than that, it works perfectly fine.
Sorry for the late reply
This is X-Plane function, it can put aircraft into position, but it cant prepare Airbus (all needed modes) for flying and approach. You may takeoff and move aircraft to needed position using X-Plane map - this is easy and in this case all aircraft systems will be ready for landing.
Thanks, thought this was some sort of bug.
But for some reason I'm unable to move the plane on the map, probably need to go on the X-Plane forums for that.
You need select it first to have it amber coloured, next - you may move it.
