Topic: a330 jd. something disappointing
Good afternoon.
I don't speak Spanish, so I am using google translator.
I recently bought the JD A330 V.4 I am looking for documentation but I do not understand it well.
Nobody has or knows how to create something like this.
The autopilot leaves much to be desired, it does not take the sid well.
If I do not find anything like it, it will be money wasted.
I was advised by the tollis but I chose to risk i
Attachment icon Boeing 737-800X Visual Manual 1.2.2.en.es.pdf 1.54 mb, 173 downloads since 2021-12-03
Re: a330 jd. something disappointing
Aircraft manual already included to actual zip pack of fresh version - you may find it here:
http://jardesign.org/forum/viewtopic.ph … 119#p41119
If aircraft not follow AP - there is a big chance what it is some special problem on user side, cause most users have not this problem. The reason may be:
1. An affect of some another installed plugin. There is simple solution in this case to check - load Cessna 172, open X-Plane Menu->Plugins->Plugin Admin to disable ALL plugins, next - load JD320/330. If issue gone - one of your plugin conflict with Airbus FMGS.
2. Problem may come from hardware, from your joystick. Please check - if some of your joystick switch assigned to "Avionics OFF/ON" - it should be stay in ON position when you run JD320/330.
3. Something wrong in settings. To check this faster - please find "Output" folder inside your X-Plane folder and rename it to "OutputOld". Next - run X-Plane. In this case X-Plane will create new and clean "Output" folder with clean settings. Please calibrate your joysticks and check JD320/330 autopilot. If issue gone - some settings was a reason.
