1 (edited by thomas_99 2016-02-20 17:13:06)
Topic: EDNY Friedrichshafen
Here are Taxiroutes for EDNY Friedrichshafen regional Airport.
Scenery: http://forums.x-plane.org/index.php?app … file=22373
Map:
http://jardesign.org/forum/img/m/552/t/p1abvgp79r45lh4c1r4a1krvtjr3.jpg
Instructions:
- Install scenery
- Put both files in X-Life/Airports   and, if you have:  FM/Airports.
- Will work with X-life and FMCar.
The Scenery contains static planes, you can use the overlayeditor or WED to remove them.
WED.xml is included in the scenery.
Best regards,
Re: EDNY Friedrichshafen
any files included?
Sorry, something went wrong.
File added !
best regards...
Cool! Thank you!
Map:
Instructions:
- Install scenery
Best regards,
Thomas_99,
How do I remove static airplanes in WED, please?
Schönen Dank!
Here is a little update to the EDNY routes.
- corrected some problems that planes do not stop at holding line if runway is busy
- minor corrections to ATC routes
- added some new stands for prop planes.
http://jardesign.org/forum/img/m/552/t/p1adnj4c0g13vg1a7112jc87p170p3.jpg
laohu314: you can use the "Overlay Editor" to remove them. I've send the complete airport to the owner, so that we will get an update without static planes and with complete atc routes :-)
Thanks! I will try it tomorrow right away!
Map:
Instructions:
- Install scenery
Best regards,
Thomas_99,
Schönen Dank!
Need prepare special "no static" scenery and put it to Custom Scenery folder. "no static" scenery should include .dsf file (only) with exclusion zones for aircraft objects (only)
Exclusion zones especially for aircraft only?
Is that possible?
I know exclusion zones for objects, forests, beach etc. only.
And when I exclude all objects then I will loose not aircraft only, correct?
I recently bought something on a Web site, the service is also good.
I read what you published, I recently played a game and you want to share with you.
Our priority is fast and secure game service in the most famous games like: League of Legends, CsGo: Cs Go accounts and CsGo! We offer you elo boosting, rank boosting, leveling, coaching and skin shop, but we’re able to provide you with almost any kind of service you wish us to do.It's a interesting game: CSGO M4A4 Skins
11 (edited by laohu314 2016-10-28 15:52:14)
Is that possible?
You open the dsf and the apt.dat in WED. Rename the apt.dat to apt_no-static.dat (or whatever). Delete everything from that one. Then, put exclusions right on top of every airplane (which you can find in the dsf file) in the apt_no-static.dat. Export the apt_no-static.dat from WED when done.
Load the apt_no-static.dat before the regular apt.dat by putting it above in the .ini file and ,voilà, no more static aircraft...
This way, you can share the apt_no-static.dat with the community.
If you are doing it just for yourself then you can just change the status of every aircraft to "hidden" in the .dsf and export.
