51 (edited by joomie 2016-01-23 07:28:50)
Re: X-Life public beta-3 190116 (Win & Mac)
joomie wrote:
I can't test this plugin any more as it is using an on-line weather and it interferes with SMPV3 .
joomie wrote:
Does anybody get complete atc guidance after contacting approach (TOD has been reported to center before) until parking at the ramp start at the arrival airport?
I made a flight from LJLJ to LIPY (yes, i created the needed .dat & .txt files) and got a loop in the atc panel (see image).
This is something I always experience, when approach asks me to contact the tower on final.
http://jardesign.org/forum/img/m/436/t/p1a9loa6iv1flk1bpk1ups1kj8p1r3.png
Well, I use SMPv3 too and download online weather. And it runs.
okay, had a complete and successful flight from LFKJ to LICC (gate to gate).
the route generated by the flight planner is a bit interesting. will see, what eugeny says.
hence, forget above. i guess problem described some posts earlier occurs, if one reports being established on final very late shortly before touchdown.
by the way, LICC is an amazing freeware airport http://forums.x-plane.org/index.php?app … file=20776
Fly test from EDDM to LFBO.
All is ok during the flight and  the approach.
Cleared to land by tower at LFBO but one AI aircraft is in the same rwy (14L)
After rwy vaccated, I contact ground but "EDDL ground" is the choice...
Try to contact and crash !
add traffic during the flight please :-)
53
Well that is what I often get.
I mean the wrong contact. I am not sure, but I assume this bug appears, when one is very late with report of being established!?
54 (edited by captbullett 2016-01-23 12:38:12)
are you CTD like I am I do not think you are so I have read the Console and there is something interfering, now the SMPv3 is not utilizing the dowloaded Metadata this is why they are coming out with a plugin that will help to use NOAA and the other on-line weather data just go to X-Avation and you can read about it here; http://forums.x-pilot.com/topic/8656-an … xx-pro-v3/
B
I've been trying to make the correct .dat and .txt files for airports to work with X-Life similar to FMcar. Even if the .dat file has taxiways I can't get it to work (also not with FMcar). What's the secret? I'd love to spend some time to do this and make them available to everyone. X-life is an amazing add-on. Simply brilliant!
On my last flight from LOWI to LOWW I got a CTD when contacting LOWW approach. I posted the logs earlier.
Many, many thanks for this!
I think I should make a learning post "how to build ATC-taxiroutes" using WED. Give me a little time, please.
...Update...
Ok, here is it http://jardesign.org/forum/viewtopic.php?pid=8649#p8649
Use that topics if you want ask, and please use not just text descriptions, but drawing examples.
This application has crashed because of the plugin: X-Life
58
Please inform about situation when CTD happen.
59 (edited by alexandermontag 2016-01-23 18:32:09)
Hello. I made a flight from LFMN after EDDM, ca 3 h. As far as everything went perfectly. I 26R lands in EDDM, on the runway, then I was asked to sign if I left the runway. I did that. Then, X-plane has stopped due to an error. So it went as far as well, from takeoff to landing. You're doing a super shop. I hope that after the A330 also an A340 follows wink
Hallo. Ich machte einen Flug von LFMN nach EDDM, ca 3std. Soweit lief alles perfekt. Ich Landet in EDDM, auf der Landebahn 26R, dann wurde ich auf gefordert zu melden wenn ich die Landebahn verlassen habe. Das tat ich. Dann wurde X-Plane durch einen fehler beendet. Also es lief soweit gut, vom Start bis zur Landung. Ihr macht einen super shop. Ich hoffe das nach der A330 auch eine A340 folgt wink
I just upload hotfix 2
www.jardesign.org/x-life/download/b3hf2.zip
Please install it over current beta
+ CTD when click "Say" in the moment when ATIS shown, fixed
+ ATC not accepted Transponder On when TA/TARA mode, fixed, accept now
+ Airport Long Name at ATC panel fixed
+ minor bugs fixed
+ some route building improvements done
Thank you, dear pilots, for your testing and all reports! I accumulate all info and analyse it.
I add some airports datas to make compatible with X-Life, please check Map!!! Thanks Joomie for several airports.
Now, I just done flight EYVI-ULLI. ULLI as crazy nice!
http://jardesign.org/forum/img/m/22/t/p1a9o51s9l1cocg3gsdk159rcfq3.jpg
61 (edited by joomie 2016-01-24 11:55:21)
+ minor bugs fixed
What, if I say TOD and I'm not in contact with center. still CTD? Is it realistic or possible, that (after takeoff and when reaching TOP) approach asks the pilot to contact center?
On HF1 I did a flight today from EDDL to EGLL and like others i was getting the transponder issue not working and also i couldn't report the TOD to ATC. The last comms I had with them was when they cleared me to FL360.
Can't wait to give this new HF2 a go.
Great work guys, it's simply awesome :-)
Still getting CTD when trying to calculate a flight plan.  XL seems to require 2GB of RAM when traffic is activated with low settings.
64
this is when I was getting a CTD so where is the Log.Txt and the Bbox so, we can figure out what is going on?
B
Are you install hotfix 3?
If yes, what from-to flightplan you try to build?
And are you have both (Departure and Arrival) scenery installed.
I just upload hotfix 3
www.jardesign.org/x-life/download/b3hf3.zip
+ runway busy/vacate algorithms reworked
+ taxispeeds on runway reworked
+ crossing runway algorithm reworked
I reupload some airports datas. Please delete ALL files at /Airports/ folder to allow plugin renew them.
67 (edited by captbullett 2016-01-24 21:54:17)
Just downloaded Hotfix #3 , real weather is on with SMPv3 real time, and 10.42r1 is the XP version my rendering settings are in the screen shot and the Pre-set was set to Med. I re-set Number of object, number of roads and airport details to 'default' and the number of cars  was set to '0' just, for the purpose of testing.
your friend ,
Ok no more CTD grate so the QNH is not working I am being told that;
Error Message Voice and txt message as follows; see the screen shot #2
Добрый день,
Просто скачал исправлении # 3 , реальная погода на с SMPv3 режиме реального времени, и 10.42r1 это версия XP настройки рендеринга мои находятся в скриншоте и предварительного набора был установлен на мед. Я повторно установить номер объекта , количество дорог и деталей аэропорта до " по умолчанию" и числа автомобилей был установлен в '0 ' только для целей тестирования.
ваш друг ,
Брайан
Attachment icon bbox_log.txt 102 b, 262 downloads since 2016-01-24
Attachment icon Screen Shot #2 2016-01-24 at 4.46.14 PM .jpg 70.66 kb, 135 downloads since 2016-01-24
Attachment icon Screen Shot 2016-01-24 at 4.29.38 PM.jpg 99.24 kb, 135 downloads since 2016-01-24
68
I have QNH problems too, sometimes. In this case I just set QNH 1 down or 1 up.
Thank-you
B
70 (edited by captbullett 2016-01-25 21:03:26)
Ok, for those that are testing that run Mac and that all of Us we need to check and if you have the Apple App called XQuartz  or 11X   you need to up-date it most of us do not check things like this and it helps runs the main graphics;
https://support.apple.com/en-us/HT201341
71
Yes, using Hotfix 3 and trying to create plan between EDDM and EGLL.  Sceneries installed for both.
72
see if the ATC gives you this flight plan;
EDDM SID INPUD Y102 UPALA UL610 BATTY UL608 DENUT UL610 LAM STAR EGLL
73 (edited by captbullett 2016-01-25 23:05:10)
this link is to video at You-Tube so you can see the way the QNH from ATC will not get approved for take-off. and you only need one of the log.txt they are the same.
your friend
link the type is hard to read but here is what the log is telling you;
> Pilot: MUNICH Delivery, JAR123, Stand 205A, A320, with information Tango, QNH1027, request clearance
> ATC: JAR123, MUNICH Delivery, Wrong QNH
https://youtu.be/7yoeSxkp4xY
Добрый день,
эта связь в видео на You Tube так - вы можете увидеть то, как QNH от УВД не будут утвержденный для взлета . и вам нужно только один из log.txt они то же самое.
ваш друг
Брайан
связать тип трудно читать, но вот то, что журнал говорю вам ;
> Пилот: МЮНХЕН Доставка , JAR123 , стенд 205а , A320 , с информацией танго, QNH1027 , запрос оформления
> УВД : JAR123 , Мюнхен Доставка , Неправильный QNH
Attachment icon bbox_log.txt 102 b, 245 downloads since 2016-01-25
74
your friend
Добрый день,
ваш друг
Брайан
I fix the QNH issue by clicking ATIS on the ATC panel, then setting the correct QNH (in Europe it has to be mBar/hPa). Then I can get further. The wrong ATIS information or wrong QNH comes up every time something changes (using real weather) so it is a bit of a nuisance but I guess it's got to be that way.
75 (edited by captbullett 2016-01-26 02:04:00)
No, and I hate to use that word the fix was to change the weather setting to //* set weather uniformly for the whole world// then set the QNH at the bottom of the page where it says 'baro pres at sea level ' make sure you are set to that # in the aircraft this is just for testing the plugin so, I want to get the #'s to match. and as soon as all the #'s were the same it work this information is going to help to narrow where the issue is. and i will send a log.txt along with screen shots.
your friend,
B
The #2 Screen Shot shows the approval of the route from ATC after the change in the weather from real weather setting.
A) top line of the ATC I am cleared Heathrow runway 26R via INPUIN Dep. Altitude 7000 sqw. 4454
Before, that I keep getting a QNH error message while connected to the X-plane 'Real Weather' plugin and it is documented in the XP log.txt.
Добрый день,
Нет, и я не хочу использовать это слово исправление было , чтобы изменить настройку погоды для // * , установленной погоды равномерно на весь мир // затем установить QNH внизу страницы , где он говорит " Baro прес на уровне моря ' убедитесь, что вы настроены на то # в самолете это только для тестирования плагина так , я хочу , чтобы получить # ' ы , чтобы соответствовать. и как только все # ' ы были такими же, она работает эта информация поможет сузить , где проблема . и я пошлю BBox.txt и log.txt вместе с снимков экрана .
ваш друг,
В
# 2 Screen Shot показывает утверждение маршрута от УВД после изменения в погоде из реальной обстановке погоды.
А) верхняя строка УВД Я очищенную Хитроу взлетно-посадочной полосы 26R с помощью INPUIN Деп . Высота над уровнем моря 7000 SQW . 4454
До , что я получаю сообщение об ошибке QNH при подключении к X-Plane плагин реальную погоду , и это зафиксировано в log.txt XP .
your friend
Добрый день,
ваш друг
Брайан
Attachment icon Screen Shot 2016-01-25 at 6.37.05 PM.png 143.44 kb, 154 downloads since 2016-01-25
