76 (edited by everstalker 2016-01-14 20:38:07)
Re: ver 2.6 beta 4 WIN/MAC 64 bit
after Departure EDFH RWY21 SID RUDU7S the corner lost from the Waypoint
but the display was correct before take off
Just a facts About "aircraft not follow flightplan" issue:
I get several reports about success solution for this issue - uninstall Gizmo.
Usually - enough to delete affected plugins like this way http://www.jardesign.org/ticket/kb/faq.php?id=38
But for several cases, when this procedure was not help, users try to delete Gizmo with luck for a320/330.
give it a way to compatibel with Gizmo in the future?
79 (edited by tiger6k 2016-01-15 17:39:28)
The VOR approach to KLAS is still drawing some odd lines.
(KPDX) CASCD2 PAWLI YERIN LIDAT BTY SUNST3  (KLAS)  VOR Runway 25L
http://jardesign.org/forum/img/m/661/t/p1a935p0rf1fhf1m551bt567e1ukm3.png
This is the ILS approach which looks fine:
http://jardesign.org/forum/img/m/661/t/p1a935s93q3l028fjo1ogd1tlg3.png
Yes, with easy way. If some plugin (what really should not work now, cause its functions not used) always load in memory BEFORE aircraft, change X-Plane paramerers, affect other plugins work, collect users data, need just delete it, cause (IMHO) this plugin just control you. But right and safety way - when you control plugin. I dont know about Gizmo exact, but plugin like SeaTraffic and some other - a320/330 killers in 90% cases.
81 (edited by captbullett 2016-01-16 14:35:32)
Gizmo runs SMPv3 so, it is hard to get rid of Gizmo also the DC-3 I use let's see what else, that's just off the top of my head so yes Gizmo while, not needed for Jar Needed for one of the big Plugins used in XP so ow do we work with it in harmony. and i talk to Gizmo before, and they say not Gizmo but SASL issue and I tend to believe that is the case I do not have issues with Gizmo but I do believe other aircraft SASL code is the issue and it is causing bugs, which I can't go int to at this level it is an engineering level issue.
I am still mystified that I still can't arm the spoilers or adjust the airbrakes manually on the A320neo? or adjust the flaps manually either. Am I missing something as they work perfectly on the A330? I do have the Saitek X52 set attached.
My only way around it is to have a key input for full airbrake and I have to hit the button on landing...  but I need to arm the brakes!
SD@X-PlaneReviews
83
Use keyboard buttons 3 and 4 to retract/ arm and extend the speed brakes/ ground spoilers.
Use keyboard buttons 1 and 2 to retract and extend the flaps.
84 (edited by ivota 2016-01-18 21:40:38)
I did a few test.
Problem with BRAKES. I dont have an idea!!
(sometimes Before TAXING, also sometimes After LANDING)
ivota wrote:
I did a few test.
You can contact me via skype to discuss this.
Has anyone noticed that the Autogate bells no longer work with this latest beta? The gates dock and undock correctly but the bells (which were previously working) no longer seem to work.
Cheers Mike
They work here.  I know the ground handling plugin they have caused some sound issues on some aircraft...did you apply the patch for that?  I think that may be specific to the A330...anyhow if you have it and didn't patch it, that may be your problem.
http://jardesign.org/forum/viewtopic.php?pid=6074#p6074
88 (edited by crisk73 2016-01-21 17:32:23)
Hi, CLB, CRZ and DES speeds in managed mode do not change upon changing CI in v2.6.
Working fine in v2.5, while it appears to be broken in all 2.6 betas. Is it a known bug or it's only me? Thanks.
http://jardesign.org/forum/img/m/814/t/p1a9duv1tjism1jbq1avd1h8n1h55.jpg
http://jardesign.org/forum/img/m/814/t/p1a9duv1tjedu1koj10paqkq5tp4.jpg
http://jardesign.org/forum/img/m/814/t/p1a9duv1tiibnn2ko797au2r3.jpg
shanemontoya wrote:
Hi JAR,
Thanks for the update. Hand-flying of this model is quite awesome and feels great.
One thing to mention is that: when in selected mode (HDG) the active flight plan doesn't turn into dashed line.
http://jardesign.org/forum/img/m/410/t/p1a8o3nrmie7jgrmk2v15b11iu93.png
The ND should draw the active fpln in dashed green as the pic shown below.
http://jardesign.org/forum/img/m/410/t/p1a8o3nrmi1tf4e0811ol7mt74d4.jpg
Will it get fixed in the future? Many thanks.
Shane
Would like to get this behavior either.
90 (edited by mruane 2016-01-22 08:52:28)
Thanks gpb500 I will apply the patch and observe the effects.
Update: Well I applied the patch you linked to but it did not resolve the issue of no bells on the Autogates.
Cheers Mike
SD@X-PlaneReviews
You can assign a joystick axis for the speedbrakes. I use Saitek X52 pro.
To arm spoilers you can assign a joystick button or key. the command is named "spoilers up one step" or similar.
SD@X-PlaneReviews
If you read my notes I have already done that and that is the way I fly now...   But you can't set the airbrakes to arm?  But you can on the A330?
93 (edited by joomie 2016-01-21 07:13:29)
I read your message.
Flying the A320 I can press my joystick
button and the spoilers get armed. There is a status information
on ECAM saying "SPLRS ARMED" and the artificial copilot confirms that by saying "spoilers armed" or if i disarm: "spoilers disarmed".
The single easiest way to get the spoilers set, is to use the up one notch and down one notch in the expanded menu of the keyboard assignments. This way you will go through the entire range of the spoilers I use a hat switch for it on my X52, and it works just fine
95
I'll try that as I have the spoilers set that way on the throttle...  Thanks
96
That's what I meant :-)
v2.6B4 Can only select one display mode button (CSTR, NDB, VOR, APRT) for ND at a time. I like to select CSTR, VOR and APRT for approach and landing but each time i select one it deselects the other.
98 (edited by Homer.Simpson 2016-01-22 20:22:19)
That's correct Airbus behavior...so not a bug.
Good to know, thanks. I've reported this as a bug before, because in the final release you could've select multiple info to display on the ND.
ups i reported that as well, on the a320 it works bugged then
