Topic: How to use/create liveries
http://i.piccy.info/i9/3a8acaf137d582c9750f32768d874895/1447326522/57766/948989/banner_800.jpghttp://i.piccy.info/a3/2015-11-12-11-08/i9-8999798/800x254-r/i.gif
How to create livery for GHD:
1.Download paintkit here: http://jardesign.org/forum/viewtopic.php?id=1315
2.Create a folder in ..X-Plane 10\Resources\plugins\GndHandling\Liveries\ with your livery name.
3.Paint .png files and place it to just created folder ..X-Plane 10\Resources\plugins\GndHandling\Liveries\MyLiveryName\
4.Be sure, what every .png file have the same name what have painted Car. Example - you should use Catering.png for catering car.
5.If some cars in your Livery pack should have default livery, please copy/paste .png file for it from ..X-PLANE 10/Resources/plugins/GndHandling/Liveries/Default/ folder
http://jardesign.org/forum/img/m/22/t/p1a3tnpcerubv1vcs1hi71gsqeeq3.jpg
Just start X-plane, go to airport you want, and call GHD, there has been added menu with liveries choose, one you want for your airport and plugin will save this information for the next time.
If you want share this Liveries for other users, please ZIP your livery folder and post it as described here
http://jardesign.org/forum/viewtopic.php?id=1469
2 (edited by flightime56 2016-01-27 09:41:14)
Re: How to use/create liveries
Hi Slava
I wanted to create a "Gate Gourmet" set of liveries with one set for KEF (Keflavik) and one for MAN (Manchester)
http://jardesign.org/forum/img/m/30/t/p1aa158hoeoih9264mell9qai3.jpg
I created the new Catering.png and Neoplan.png's which I know work, because before we had the livery option I used them then directly by swapping them over in GHD.
Then I duplicated the default livery set and renamed them as above and deposited them in the folders overwriting the older files.
But when activated in X-Plane I get a warning and grey trucks?
And the Log.txt error : Failed to find resource '../../Liveries/Gate', referenced from file '/Users/stephendutton/Desktop/X-Plane 10 2015/Resources/plugins/GndHandling/Cars/Catering/'.
Ahhh fixed it!   I'll leave it up here so users know...  the livery title must have no breaks between letters to work.
Thanks SD
How to create liveries, I hope these screeenshoots help you the most. And also show how can it is better while you start to use it some good way are define in these hirewriters prices hope it is better and you will never feel low after using it.
