Re: ver 2.5 beta 1 WIN/MAC 64 bit
reports from here. Mac OS X 10.10.5, X -plane 10.36, Flight from LFPO to LFBO.
- at startup doors are closed, so flight attendant welcomes passaengers despite plane is C&D.
- Flaps sounds are missing
- ATC does not work (tried to get ATC from both LFPO and LFBO without success)
- Strange behavior on managed DES before APPR Phase, the plane goes to -5V/S suddenly causing overspeed and AP off
- Another strange behavior before landing, FPS goes from 30/40 to less than 20 letting the plane going 1fps by 1fps (the effect on screen smile)
- during cruise in flight, strange acceleration from the engine noise (the place was at 320 but the noise of engines increase just like if FADEC ask for)
- F/O announced STD Bar despite not pushing STD bar.
That's all folks wink
Please update your Ground Handling plugin from here
http://jardesign.org/forum/viewtopic.php?id=1295
I cannot try, encounter: "a320 error activation aircraft“. I wrote yesterday early morning to JAR (____@mail.ru), no reaction.
jiggyb2 wrote:
He likes to post preview pics on the Facebook group though, that's the best place to see progress.
Facebook is not the best place, because who is not on that site can't see cockpit progress.
dron420 wrote:
You are right. Cockpit is still in development.
Any chance to see photos in another way?
30
Not good idea to publish private emails cause of spam. Thank you a lot.
To get support, please send mail using support email from official webpage.
Thanks. This is OK for flaps sounds but not ATC.
On Windows 10 all seems ok. Only 320 NM range not selectable.
XP10.36, Win10x64, A320 2.5b1
Just noticed that when the aircraft is loaded  - cold and dark, no power, no one on-board; there is a flight attendant's announcement already in progress?
For info.
this fixed, get it
Sorry, you are right, it was late, this was not mindful, I will improve myself.
36 (edited by rogerwolfe57 2015-09-15 02:14:30)
Noticed that there is a noticeable 3 to 4 per second side to side shimmy or rocking in aircraft with this beta which did not occur before.  Using latest rc of xp on both.
37
Just a small glitch, noticed its not in the other versions just this version. The co pilots range knob when set to 10nm is way below 10nm smile
http://jardesign.org/forum/img/m/1390/t/p19v8inq0fpedecgdv11nnh1qr3.png
Hopefully easily fixed.
Also noticed i'm getting to TOC around 20nm earlier than planed all the time.
Thank you J.A.Romanov, for the update. Your aircraft is beautiful.
fixed
40
some remarks :
-would it be possible to control the illumination (light) of the FCU with the 2 knobs below the FCU as in real airplanes ?
-when fire tests are made, possible that the two warnings (below the eng 1 and 2 selctors) also illuminates ?
-that once the chrono selector on the FCU "on" , countdown appear on the ND ?
-when mode "constraints" on the ND selected or not, we see the constraints equal if "on" or not
Thanks for all this beautiful works
Alexandre
41
CTD KDFW-KSAT app KSAT FL120
SLLP-SPIM
Crash to desktop with no log.txt warnings.
1- After starting descent all went well till i used the first airbrake position to mantain a correct speed, then the pressure problem happened again: my screen started to become blank with no reason, I only opened airbrakes. Luckly I was at FL 130 and I reached FL100 quite fast and all was back to normal.
2- I tried that flight two times and all went the same way: turning to final on SPIM and using manual controls to mantain glide slope and localizer all was ok, then I engaged autopilot and LOC button and suddenly crash to desktop.
3- why it is not possible to select the female voice for the FO but this menu item it is still available in the MCDU menu?
Hi to all, i`ll be back smile
First that i must say - aircraft flies excellent!!! Make few visual approaches with good stabilized landings, amazing.
But i`m have few notices :
1) Green path line goes behind compass rose on ND (on A330 this issue fixed)
http://i.piccy.info/i9/014766efdf62a7e41fd81bc3245fcfb5/1442426211/131196/950691/nd1.pnghttp://i.piccy.info/a3/2015-09-16-17-56/i9-8747793/482x456-r/i.gif
2) Old notice about strange behaviour of aircraft in climb to calculated CRZ FL, aircraft reach lower FL than CRZ FL very, very lazy.
http://i.piccy.info/i9/df667387a7ecb97629bf5e854b358cb7/1442426283/43213/950691/clb_800.jpghttp://i.piccy.info/a3/2015-09-16-17-58/i9-8747803/800x351-r/i.gif
3) The End.
44 (edited by thomas_99 2015-09-16 18:50:53)
With A320 + xplane 10.40RC1 i noticed 2 little graphics problems:
http://jardesign.org/forum/img/m/552/t/p19vbnqn1e1h391d46106mj051gad3.png  http://jardesign.org/forum/img/m/552/t/p19vbnr6hm9k417d3ah0kopga8d.png
best regards....
45
JAR 2.5b1, XP 10.36, Win10x64
Better and better esp. the new FBW now feels and performs like the RW A320 videos!
I don't think the new FBW  is an improvement. It's just as stiff as the FBW of your A330. If you initiate a small roll command and return the side stick back to normal, you can feel and see the FBW counter your input. It seems that the FBW simply counter acts the roll command too much. The real FBW controller works in a much smoother way. It will stop turning when the stick is at neutral but it will not stop immediately and overshoot in the other direction as your v2.5b1 does.
As mentioned above this roll behavior can also be seen on your A330 which in my opinion is wrong too.
Furthermore the pitch command in Flare mode is very sensitive. A small nose up command on the side stick will raise the aircrafts nose rapidly. This does not happen during final approach where the pitch command seems to be much less sensitive.
During flare mode the FBW will only command a slight and increasing nose down command to cause the PF to flare, but you know about this already:-) Pitch sensitivity should not increase in flare mode.
+1
48 (edited by tngarner 2015-09-22 03:11:42)
First great improvement.  Plane flies really well.
It seems that you fixed the issue I was having with STARs going into a few places.
The only issue I am having is that the FMS will only fly over waypoints. Most waypoints are fly by and the appropriate procedure is to fly by (anticipate the turn). So the plane does two to there turns to get back on course, instead of just  one.
This is probably not an issue for many but I fly on an online service that is really picky and I cannot fly this plane on there yet. Some of us have and the controller just gets irritated with us. Be awesome if this could get fixed.
Thanks!!
49 (edited by rodrigoef 2015-09-21 00:52:32)
Win 10 64 bits:
Problems with descent phase that did not occour in previous versions: The plane starts the descent at a very low V/S and suddenly change to a deeply V/S. Impossible to achieve in managed descent and generating overspeed in free descent.
50 (edited by firesindaco 2015-09-21 00:44:31)
The PFD It began aligned.(Image) - A problem
