Re: XP11.50 JD330 v.4.1
Luke173 wrote:
many thanks for the fast 11.5x version!
though I get very low framerate inside the cockpit, 10fps and lower, on the outside it's all fine. It's a behaviour I only see with other planes when they use librain.
It's the same for both types, 332 and 332 FPS boost.
(I have the bare installation of XP, with GroundHandling missing, but it makes no difference if it's there)
My set up is a MacMini 10.14.6 with an eGPU, log is attached. -> ah, how can I attach a log file? it seems to only let me add images.
Thanks! much aprechiated
Luke
I had the exact same problem! But after updating to version 11.50b2, my FPS came back to normal. Try to do the same.
Hello and thank you for this new update that works perfectly on my X-Plane 11.41 ...
The only problem I encounter is that when I finish my flight and want to close X-Plane 11.41 it blocks my closing (X-plane 11 does not respond and runs in a loop)
I tried with other planes and it works correctly ...
This is just my concern when using the JD330
Good flight
Ouistiti06
53 (edited by ouistiti06 2020-04-10 07:47:25)
Hello and just report my problem after updating the JD330.
During my flight I lose the flight level on the FMC and display (NEW CRZ FL) I return to the flight level I validate and 5 minutes after it loses the flight level again and puts me back (NEW CRZ FL). And this throughout the flight.
An idea ?
Thanks, I just saw this known issue: XPD-10619 EGPU massive FPS loss with OpenGL Drawing. must be the case here
55 (edited by DLH067U 2020-04-10 10:47:10)
An idea ?
Same here.
  • Loss of FL
I can also report that sound is very bad with sound3d. Any news from bss upgrade?
@J.A.Romanov why dont you fix your windshield effects if you bring out a new version of the A330? Thats an issue about more than 1 year. Thanks.
58
Hi, I updated to the last version and I do not have rain effect on the shields. I tried with different weather engines but still the same and yes the option is turned on.
59 (edited by kicaj 2020-04-12 08:15:04)
Jak można naprawić pogodę z Active sky bo nie działą
A330 is not working with Active Sky, turns real weather to Customized. Deactivated shake camera and turbulence from menu didn't work, is there any other fix?
61
This version seems to have a memory leak sad Flight started over 60fps a gradual decline during flight after 5 hours down to 28 fps and falling
62 (edited by luyijie12 2020-04-12 13:07:34)
I put on autopilot, but the plane didn't follow the route.
hello, with this new version, push back truck is not visible but push back is working
64
I do have the same issue.
I did 2 long hauls over the weekend and did not had that problem. Smooth from beginning to end :-)
Cor
Hello.  I tried the latest version today and had issues with it, not sure what went wrong. The aircraft does not follow AutoPilot after takeoff, it stays in takeoff pitch and hdg or just follows any random direction, speed keeps on reducing and then aircraft starts swinging sideways and stalls to crash. I tried clean install 3 times and exactly the same thing happened all the time.
67
330 crashed
68
Had done two mid-range flights and everything was fine. Have the v4.0.5 installed. ASXP runs, too. FPS in the high 30 fps. Departing from CYVR and the first leg was displayed as an about 5nm off-track course but corrected by itself later during the flight.
One thing left: According to the official charts of KEWR I had to be @18,000 over FQM, SWEET alt 7000. When I put in the new altitutes into the MCDU it didn't change the T/D automatically. I had to do the descent manually to the published altitutes. Not a real problem but strange :-/
However, since updating to 11.5b3 I am more in the A330 than FF A350. So I can really enjoy the vulkan performance boost on my rig.
Happy landings!
I too had a successful flight , A330 followed the descent path and matched all waypoint altitudes spot on in managed descent mode.  this new update feels so much better. Engine spool up times are more realistic...and cockpit and exterior looks so crisp with Vulkan. Thanks again JAR team keep up the good work.
Did Anyone managed to make a flight with Active Sky real weather live mode? I deactivated Turbulence and shake camera from A330 menu settings but still change real weather to customized. Looks there is an issue with Active sky as default X-Plane real weather works.
71
Is this new A330 Update VR optimised now?
72
I would like to know how to close this screen that is in the bottom left corner of the screen.
73
Mine does the same. Seems like it is X-Enviro that doesn't work so well with it. When I disable X-Enviro, that screen disappears. I went back to the previous version until Jar gives us some detail about this...
74
You got it. JarDesign products run better with less or no other plugins
ddezulier alias diaboloxpfr on X-Plane.org forum
VID 566478
VAT 1400805
I was flying today from RKSI to RCTP and during short finals, I had a RAT OUT warning message on the ECAM. Both the Navigation displays went off for few seconds and then were back on. ELEC GEN 1& 2 and ANTI ICE 1 & 2 had FAULT light illuminated.
I don't have failures on, so not sure why did this happen.
Any inputs on this would be appreciated.
I am using X Plane 11.50b4 and JAR v4 for Vulkan as well.
