Re: v.3.2 beta public tests
Franz007 wrote:
How much "The fuel consumption is clearly wrong" you find for actual beta-version for you, please? Sure, please measure it in zero-wind condition.
I did not test the latest beta but read all of the update-notices. And you never mentionned anything about improved fuel-burning values. So i am pretty sure they are still wrong. I sent you last year all the informations based on real performance tables. You promised me to look at it. So can you please answer the follwing question: did you change something to these values? If yes i will test it.
Yes, we done this several times since you contact me. Sure, LR change their engines parameters several time too.. Every time when this happen - all engine parameters are gone a little. As result - every X-Plane beta or version may give as different value. but for me - it look like Ok on test stage. Please inform me.
OK, thanks for the informations. So i will take a look into the newest version.
please follow release topic
http://jardesign.org/forum/viewtopic.php?id=11620
Thank a lot for all testers!!!
