151
Re: JD320 Airliner ver 3.3 r1,2,3 WIN/MAC 64 bit (X-Plane 11.30)
You should train windows/mac voice recognition, its a service of your OS
http://jardesign.org/a320/download/copilot/Manual.pdf
or maybe you are scottish, then watch this video: big_smile
https://www.youtube.com/watch?v=MNuFcIRlwdc
big_smile big_smile big_smile big_smile
X-Life Deluxe
GHD
FMCAR
JD320
152
Hello! I am reporting a bug in the MCDU the moment I delete the discontinuity of the route is not possible. Does anyone have this problem?
153
Some Discontinuities cannot be deleted by default (a feature, not a bug). Notably any disco after a "MANUAL" entry generated by the FMGS, can only be deleted after the "MANUAL" entry is deleted. Furthermore, discos inserted by the FMGS at no-SID departures also cannot be deleted. Lastly, discontinuities are not a catastrophe. Simply fly the FP to the disco, then do a DIR TO, or fly "vectors" to the next valid waypoint in the FP or whatever ATC tell you to do. If you don't have ATC then you decide what to do.
154
Hi developers,
Autopilot on STAR (LEBL MATE1T for 25R) ILS approach. It starts to turn in far to early and as a consequence is to high for the ILS approach and does not establish.
In earlier versions I didn't have this problem.
Thanks for your help.
iMac 27" End 2013, 3,5 Intel i7, 32GB DDR3, GTX780M 4096MB, Mojave 10.14.3
X-Plane 11.32, A320 latest and A330 latest
155
Just to make sure, is the latest version 3.3r3? thats the one I have, or there is a r4?
156
I am having no success in creating a support ticket at JarDesign Support. I fill out the form and submit it but no ticket number is generated. I did it 8 times.  I need assistance with activation. I am upgrading JARDesign Airbus A320 Neo V2.7 $59.95, Serial Number FX-W7VRPL-P7HY4L-AR7HEH-PZFPVT to the JARDesign-A320 V3.4 update.
Can you assist me, please?
Rthomas81@nycap.rr.com
157
Hi Sir your plane’s for X-plane 10?
If yes you have buy for X-plane 11
158
Hi gyus, Am I the only one having issues with ap flying the route.
Let's say that the route is not being follower accurately. It most of the time overfly the waypoint even though I havent set any overfly setting. Airbus actually should rather start turning before the waypoint.
Anyone else with this issue?
Also if the turn is quite severe...meaning more than 100° sometimes it just doesn't manage to turn and it just go straight, forcing me to manually select the heading to put the plane back on track.
Never had these issues with 2.7 now I'm on 3.4b2
159
Low FPS on high airport
160 (edited by mrmacfixit 2019-02-24 01:22:29)
How does one enter the Gross Weight in the FMC?
I have tried converting the GW from KG to LBS but as there are only two spaces and a decimal place, that didn't work
entering any number into the fields produces an error like enter as /xx.xx
If I enter /56.3 (for example) the field remains empty but there is no error message.
XP 11.30 with what I believe to be the latest non-beta version of the aircraft
EDIT:  Never mind.  Operator error.  I completely forgot about the second page of the INIT screen.  problem solved
P
161
Not good idea to publish your serial. It was just deactivated, cause someone another was use it (license was broken)
Support portal placed here
www.support.jardesign.org
162
Eugeny,
Can you tell me please, does A320 v3.3r3 work with XPlane 11.32r2? I installed this update with no problems but I could not enter airways into the MCDU. When I restarted the program I got a SASL error and XP crashed, twice. Which version of XPlane do you recommend for both v3.3r3 and the A320 Beta v3.4b3?
Steve Haines
163
I want to follow up my previous post to say all seems to be solved. I first updated my Navigraph set including all JAR aircraft. I then removed a couple of suspect plugins, restarted and was able to load both versions 3.3r3 and the new beta version 3.4b3. I must report that I was still unable to load airways into the MCDU with v333. However I was able to do so with v34b3 and not only that, I was able to do a complete flight including managed approach and autolanding with absolutely no errors or interruptions at all. Perfect! And to top that off all of the BSS sounds worked perfectly including my favorite "Spirit" attendant announcement. So All is well with JAR. Thanks for the upgrades! —SH
164
Guten Abend.Ich hab beim A320 folgendes Problem im Zusammenhang mit dem GHD Plugin.Es funktioniert an diesem Flieger nicht mehr.Gibt es da eventuell einen fix?!
165
I have just purchased and installed the latest A330 from your link at the top of this thread.
However, when I start Xplane 11.30 using my Mac, after selecting the A330, Plane 11 crashes to desktop.
Do you have any idea why this is happening?
Post your log.txt and OS crash report on the X-Plane.org site and a link to them here. Without seeing at least the log.txt nobody can help.
167 (edited by aleplane 2019-03-14 20:57:33)
I keep having problems to follow the route. The plane ALWAYS overshoot the turn and it has to correct every time. If then two way points are too close it results in being unable to follow the route and start circling in the attempt to catch the missed waypoint.
In the previous versions i never had any issue. What when wrong with the latest versions???
For some reasons I can't attach the file with the example
168
I have same problem all the time sad
169
Hi Sir for now resolve it with direct-to
170
hi guys, does it work with xplane11. 26? or just works above 11.30?
171
Why isn’t idle taxi possible?
172
Has anyone noticed the lighting knobs now rotate counterintuitively? The ECAM brightness knobs turn counterclockwise when I scroll up and clockwise when I scroll down. Don't recall that before, is it a bug or am I going crazy?
173
yup .... I think they have always been backwards
174
Does this version (3.3) work with xp 11.32r2?
175
It should
