Re: v.3.1 beta 1, 2, 3 public beta-tests
it is possible to change the copilot to an headset and Xplane by default to the speakers ?
Hello there, I'm doing my first fly test with this new feature for A330. So far I had no problems with it. Everything worked fine from the installation to the take off and the cruise altitude. The only thing I miss and I think it was nice to have is the cockpit door to open/close like the A320.
Thank you!
munich07 wrote:
Does the voice control of the A330 only work under Win10 ?
Udo
voice control is not "330" voice control, but function of OS (Windows or MacOS)
If you have it worked with your OS - it may be used with copilot
ok thanks, I have WIN7 Prof in German, only German language recognition. I can not use it like that. Only from Win10
Thanks best regards
Udo
Ok, we will continue with r1 here http://jardesign.org/forum/viewtopic.php?id=11342
Thank a lot for all your help and test info.
As we get X-Plane 11.30r1, we should post this JS330 version as release candidate.
