Topic: v.3.1 beta 1, 2, 3 public beta-tests
Intro: As you know may be, we work on JD340 new project. One of important part of aircraft procedures is Checklists / Anounces. Sure, this already work with some way at our JD320/330, but I am not glad 100% with this. So, for JD340 we should prepare some more interesting thing. it is animated copilot, as I dreamed. This one. We just build this plugin and include it as free update to beta version of JD330 - we absolutely need to test it with "live" aircraft to understand is it good way or not. If it will be Ok, we will include it to our 340 in future.
http://jardesign.org/forum/img/m/22/t/p1cqq97hvo12gl1mr4rvjard18ne3.jpg
http://jardesign.org/forum/img/m/22/t/p1crc775edmnr1q7l1bd1c1k1i8j3.jpg
This is next public version of a330 for X-Plane 11. Please take part in this beta-tests if you really want be beta-tester. If you want fly-ready product - please just wait.
Main improvement - new Checklist/Events/SOP/, based on instant CoPilot plugin
beta 1 features:
+ animated 3d CoPilot model
+ can recognize and execute command
+ can speak
+ can read checklists
+ can operate with Events (flight parameters detection)
+ man and woman copilot model (woman only included this time)
+ scripts based (possible to edit/change Procedures/Text/etc)
+ some aircrafts bugs fixed
- some procedures was not tested well (will fix with next beta)
beta 2:
+ some procedures improved
+ public beta published
beta 3:
+ some kind of crashes fixed
+ fmgs improved (Maximum FL indication, Second flight ready w/o reload, click sound repair)
Additional req:
You should have:
- microphone or
- headset (preferable)
You may install aircraft at separate folder and use both - old and new version.
Download link: http://jardesign.org/a330/download/inst … 1beta3.zip
You need (absolutely) to have microphone or headset to try this beta and take part.
You need (absolutely) read and follow setup info (two next post).
Please avoid publish message like "Crash on loading" or like this tithout any details. This will really not helpful and not need on beta test stage. Please understand this.
In the case of wrong voice recognition setup crash on loading stage may happen. Please be ready to contact JAR via skype j.a.romanov to demonstrate how this going and make real fix for this by our crew.
Please install Ground Handling plugin to be well-compatible with XP11
  - be sure, that you use X-Plane 11.20-11.26
  - copy unziped "JD330_v3" folder to ..\X-Plane 10\Aircraft\ folder
a330 use NavData from
Please note what this time we have beta of JD330 ("beta" - product for testing and may not work well, hare errors and so on). If you need release, need stable version, please wait.
- please post your log.txt if Crash happen.
Thank you!!!!
Re: v.3.1 beta 1, 2, 3 public beta-tests
Copilot can recognize your speech. To make this possible you need setup your computer and microphone.
------------------------------------------- MAC ---------------------------------------------------------
For MAC users:
Open Settings and check Speech and Recognition tabs:
http://jardesign.org/forum/img/m/22/t/p1cqo3qi51161h3s21r471qkcibg3.jpg
http://jardesign.org/forum/img/m/22/t/p1cqo3quefspi1aic1q961s2l1hgi6.jpg
-------------------------------------------- WIN --------------------------------------------------------
For Windows 10 users:
Please be sure what US English language pack is already installed and English selected as Windows display language
http://jardesign.org/forum/img/m/22/t/p1cricjd4v13bheu8ukc194p1fkd3.jpg
Please select English language for Recognition, run voice preview, setup microphone.
http://jardesign.org/forum/img/m/22/t/p1crc7ba7817u11hjml0a8fb11su7.jpg
Next turn recognition On
http://jardesign.org/forum/img/m/22/t/p1crhrfbeqjesioo15k4s78sfe3.jpg
If you will get this error, you need setup English as user interface language (Windows display language) and English as your recognition language (language you speak with your device) and reload computer.
http://jardesign.org/forum/img/m/22/t/p1cric8pam1j13rmn6c1d0h193t3.jpg
Please use this basic manual if need:
https://www.windowscentral.com/how-set- … windows-10
Please use new Menu to setup CoPilot speech Volume, Rate (speed of speaking), Select voice.
You may speak with CoPilot via voice or select commands via Menu:
http://jardesign.org/forum/img/m/22/t/p1cqo5s57m1gjc187e8gi1510159e3.jpg
If you prefer voice control, you need setup special joystick (sure, keyboard may be used too) button to jd/CommandRec.
http://jardesign.org/forum/img/m/22/t/p1cqo5v17k1v8eam1m0i3ju2v86.jpg
You may look at CoPilot, hold this joystick button and say something like "Hello!" Typical pattern - press the button, say the text, release the button.
Speech will be recognize by Windows/Mac speech recognition system. Copilot will understand your command. If you need to know what command may be used (actual commands list of phrases) - please open A330 -> CoPilot -> Commands
Additional voice commands:
"Abort" - CoPilot will break current execution flow (break checklist execution, as example)
"Skip"   - CoPilot will skip current execution line (not expect User voice/procedure entering more)
How this going at Real Life:
Before Start
https://youtu.be/MUftFbvJ0Mw?t=2m25s
Before Start below the line
https://youtu.be/8e4t3L4_2Wo?t=9m12s
After Start
https://youtu.be/MUftFbvJ0Mw?t=5m7s
https://youtu.be/Z0ZrsffA3y0
https://youtu.be/WYKOv-Qwx8w?t=2s
Before Takeoff
https://youtu.be/j9p5AORcY8o?t=6m2s
Before Takeoff below the line
https://youtu.be/PwdFBzO2ZQo?t=2m29s
https://youtu.be/-_vWrcNf5XA?t=5m21s
https://youtu.be/j9p5AORcY8o?t=10m56s
Final Approach
https://youtu.be/ZqWtFhxRb3s?t=7m23s
Landing CheckList
https://youtu.be/ZqWtFhxRb3s?t=8m55s
After Landing
https://youtu.be/j9p5AORcY8o?t=53m29s
Script system description.. (not need to know for regular users)
The CoPilot plugin script system has two entities - events and commands.
EVENTS (.txt files at ../copilot_main/custom/events/ folder)
Event text file describe the list of conditions under which an event occurs, the list of actions that the pilot will execute when an event occurs, conditions for resetting event.
Example: PositiveClimb.txt - CoPilot will look at list of datarefs and will say "Positive Climb!" if aircraft have takeoff flight phase, airbone at leasr 25 ft, have positive acceleration and vertical speed more than 500 FT/MIN
#EVENT CONDITIONS
if:sim/custom/xap/fly_phase==1
and:sim/cockpit2/gauges/indicators/radio_altimeter_height_ft_pilot>25
and:sim/cockpit2/gauges/indicators/airspeed_acceleration_kts_sec_pilot>0
and:sim/cockpit2/gauges/indicators/vvi_fpm_pilot>500
and:sim/custom/xap/fctr/mode<=1
#RESET CONDITIOND
reset:sim/custom/xap/fly_phase!=1
#EXECUTE
say:Positive Climb!
COMMANDS (.txt files at ../copilot_main/custom/events/ folder)
Command text file describe the list of voice input phrases to activate this command, the list of actions that the pilot will execute when this command will recognize.
Example: If user say Hello - CoPilot will answer "Hello, World!"
#VOICE INPUT FROM USER
input:Hello!
#EXECUTE
say:Hello, World!
EXECUTE FLOW Every string (executed one-by-one) do some job:
say:
say:Hello! - CoPilot should say "Hello!", next line of the flow will be executed immediately after the beginning of the speech.
saywait:
say:Hello! - CoPilot should say "Hello!", next line of the thread will be executed after the end of the speech.
pos:
pos:LgUp - The pilot will take smooth a pose stored in the ../custom/positions/LgUp.txt file.
posfast:
posfast:LgDn - The pilot will take a pose stored in the ../custom/positions/LgDn.txt file immediately
pause:
pause:1.5 - CoPilot will just wait (do nothing) 1.5 seconds.
drf:
drf:jd/fo/_planshet=0 - Will set "jd/fo/_planshet" dataref value to 0. Float/Integer/Double datarefs type supported. Array datarefs supported.
waitdrf:
waitdrf:sim/flightmodel/engine/ENGN_N1_[0]>20 - CoPilot will wait until "sim/flightmodel/engine/ENGN_N1_[0]" dataref value will be more than 20 (N1 of engine 1)
execute:
execute:Checklist/BeforeStart
Clear current execution flow and begin to execute script from ../custom/execute/checklist/BeforeStart.txt
waitanswer:
waitanswer:ANY - Copilot will wait untill any text was saying and recognize
waitanswer:Check - Copilot will wait untill "Check" was saying and recognize
waitanswer:Check
waitanswer:Checked - Copilot will wait untill "Check" or "Checked" was saying and recognize
var:
var:MYOWNVARIABLE=1.9 - Variable (double) will created with name "MYOWNVARIABLE" and value 1.9 Just after this, any scripts may use this variable and it value.
varinput:
varinput:PacksValue
waitanswer:PACKS OFF=0.5
waitanswer:PACKS ON=1 - Copilot will wait answer and varialble "PacksValue" will set to 0.5 is "PACKS OFF" answer will come and 1.0 if "PACKS ON" will come from user microphone
break:
break: - current execute flow will erase until event will happen or command will come
cmdonce:
cmdonce:sim/flight_controls/speed_brakes_up_one - will execute "X-Plane command" "sim/flight_controls/speed_brakes_up_one"
cmdbegin:
cmdonce:sim/some_command - will start to execute "X-Plane command" "sim/some_command"
cmdend:
cmdend:sim/some_command - will end to execute "X-Plane command" "sim/some_command"
if:
and:
or:
elseif:
else:
endif:
Example with notes:
var:MYTMPVARIABLE=sim/custom/exampledataref
if:sim/custom/xap/engines/startsel==0
or:sim/custom/xap/engines/mswitch==1
do something (if "sim/custom/xap/engines/startsel" dataref equal 0 or "sim/custom/xap/engines/mswitch" dataref equal 1)
elseif:sim/custom/xap/engines/startsel==1
and:MYTMPVARIABLE==1
do another (if "sim/custom/xap/engines/startsel" dataref equal 1 and "MYTMPVARIABLE" variable equal 1)
endif:
reserved by JAR
This is an amazing idea!
Can the system be updated by users to support other languages?
8 (edited by laohu314 2018-10-31 03:22:29)
Just tried it out. It is absolutely genius! It works pretty well even without a microphone on my iMac but I would highly recommend one anyway. I love that it can be customized. I am aiming at not using FlyWithLua scripts at all anymore with this plane.
And I will definitely get the A340. Can’t wait!
As you know, Airbus procedures based on English - SOP, Checklists - all use English only. And for this aircraft - English only can be used. For other aircrafts (future task) - we will look what we can do.
I tryed with different microphones too. Standart MAC microphone work well too for me. Sure, best thing is headset, you are right, cause in this case mic not get engines and other aircraft sounds.
I use X-plane 11.30b1 and W10 … When launching XP with A330 Copilot aircraft appeared on screen and then CTD …so i have not got the possibility to enter serial number ...
Currently it is not possible to add a file to the post … (log.txt , fmgs.dmp…)
Here are last lines of log.txt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/hdg_ind
FMGS: 0 : Cant Find Dataref: jd/330/spd_cnst
FMGS: 0 : Cant Find Dataref: sim/custom/xap/spd_lim/red250_alt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/spd_lim/spd250_alt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/spd_lim/spd250_spd
FMGS: 0 : Cant Find Dataref: sim/330/menu
FMGS: 0 : Navdata info:
FMGS: 0 : Provider N
FMGS: 0 : Cycle 1811
FMGS: 0 : Period 11OCT-07NOV
FMGS: 0 : inPath Custom Data/GNS430/navdata/
FMGS: 0 : procPath Custom Data/GNS430/navdata/Proc/
FMGS: 0 : Provider A
FMGS: 0 : Cycle 1410
FMGS: 0 : Period 18SEP-15OCT
FMGS: 0 : inPath D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copil\plugins/fmgs/navdata/
FMGS: 0 : procPath D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copil\plugins/fmgs/navdata/Proc/
FMGS: 0 : !!! Error: Cant read Waypoints file
FMGS: 0 : !!! Error: Cant read Navaids file
FMGS: 0 : MessageGreen: Systems Created!
JD SPEECH Plugin: Get MSG: contextpath>D:\Desktop\X-Plane 11\Aircraft\JD330XP11-Copil\plugins\copilot_main\
FMGS: 0 : JARDesign FMGS  plugin ver.V3R6-230818 detect crash.
FMGS: 0 : Memory dump saved to fmgs.dmp file
FMGS: 0 : Please send this log.txt file and fmgs.dmp file (from X-Plane folder) to support@jardesign.org !
12 (edited by annette-kuehnelt 2018-10-31 10:06:01)
Hi Jar,
same happens for me, as well. I am using XP 11.26 official release version, Win 10, .Net 2010 installed and actual working java. Not able/ permission to attach fmgs.dmp file here.
Best wishes
better way - just call me skype j.a.romanov - we will check what happen on your side, please
Hi Jar,
Best wishes
Using iMac mic is a bad solution. I am using a head set and it works perfectly. In my last recording I forgot to activate my microphone. Now it works fluently. While using certain audio sources at the same time (aircraft engines, X-Life ATC, X-ATC-Chatter, microphone, co-pilot and Sound MAXX) it is important do adjust them all for having good cockpit sound....
Agree completely, I just didn't want to discourage people who don't have a headset from trying this out. It is absolutely phenomenal.
17 (edited by chris.palfreyman 2018-11-02 16:15:33)
I just completed my first flight with Lynda and overall I'm very impressed, I will post something to the FB page later.
I found the set up to be very easy, just two buttons needed to make it work.
I would suggest that you recommend users to have a printed .PDF file with all commands and responses. I have a one sheet Airbus checklist and this made it very easy to issue commands and to predict the responses.
Small issues:
1. The read-back got stuck in a loop repeating commands in two checklists, after start and before take off.  I don't know why but it exited the loop after a few annoying minutes. :-) NOTE: THE LOOP HAPPENS BECAUSE THE F/O NEVER COMPLETES THE FLIGHT CONTROL CHECK. THERE WAS NO RUDDER CHECK....
2. I found the read-back text hard to read. Perhaps this could be put in a window or have a different colour background.
3. There's quite a delay between issuing a command and a response. This makes it seem like the command hasn't been heard when it had.
4. I did load the aircraft into 11.30 Beta afterwards just too see. The manipulators are not working properly, for example it was not possible to put the IRS's into NAV mode.
Great work guys though, this shows huge promise!
Kindest regards, Chris
Hello! My X-Plane 11 crashes after appearing activation window of A330 with copilot
Here is my Log.txt
https://mega.nz/#!bdEFjYBB!foAqhEvdbQKo … WucODAKw74
This beta has been tested and very satisfied.
asianfanfics
Here is my Log.txt
Please setup your Speech Recognition as described at:
Please be sure what you have English language pack installed.
If no luck - please contact skype j.a.romanov - we will check&fix this
21 (edited by Dvilssaw 2018-11-02 15:30:05)
Hi JAR,
working fine so far!
Just to make you aware:
As soon as I turn on the WXR i noticed this grey box appearing in the ND; if i switch it off, its gone again. So repeatable.
Pic attached
http://jardesign.org/forum/img/m/3594/t/p1cragm7gb1gra1nnagvo1f8t54m3.jpg
Dvilssaw wrote:
Hi JAR,
Pic attached
I will look at this! Thanks, Understand!
Hi another time! I try to make speech recognition like in the pictures that are published by you higher, but look, I have problem: I can't click on most of windows(((Can you help me? My language is Russian
Send my log, no résult, speech,ok,
SoundSetPath=E:\X-Plane 11\Aircraft\JD330XP11\plugins\sound3d\
VolumePath=E:\X-Plane 11\Aircraft\JD330XP11\plugins\sound3d\volume.txt
3Dsound Engine by JARDesign
2Dsound Engine by JARDesign v.1.0
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/ths_angle
FMGS: 0 : Cant Find Dataref: jd/fmgs/dist_to_arr
FMGS: 0 : Cant Find Dataref: jd/fadec/airspd_dial_ind
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/vmax_knots_mach
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/flt_nbr
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fplan/dep_apt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fplan/arr_apt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fuel/extra_fuel
FMGS: 0 : Cant Find Dataref: jd/330/neartod
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/ils
FMGS: 0 : Cant Find Dataref: sim/custom/xap/adirs/knob_ent
FMGS: 0 : Cant Find Dataref: sim/custom/xap/adirs/align_in_min
FMGS: 0 : Cant Find Dataref: jd/tcas/snd
FMGS: 0 : Cant Find Dataref: jd/tcas/ra_snd
FMGS: 0 : Cant Find Dataref: sim/custom/xap/atc/abv_blw
FMGS: 0 : Cant Find Dataref: sim/custom/xap/atc/ta_tara
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fma/cat_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fma/dual_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fma/dh_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/alt/dh_alt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/alt/mda_alt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/decelerate
FMGS: 0 : Cant Find Dataref: sim/traffic/ICAOPLAN
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fuel/block_fuel
FMGS: 0 : Cant Find Dataref: sim/custom/xap/weight/zfwcg
FMGS: 0 : Cant Find Dataref: sim/custom/xap/snd/fo_test
FMGS: 0 : Cant Find Dataref: sim/custom/xap/acp/buzzer
FMGS: 0 : Cant Find Dataref: sim/custom/xap/snd/sys_vol
FMGS: 0 : Cant Find Dataref: sim/custom/xap/snd/fo_vol
FMGS: 0 : Cant Find Dataref: sim/custom/xap/itow/on_off
FMGS: 0 : Cant Find Dataref: sim/330/joy_precise
FMGS: 0 : Cant Find Dataref: sim/custom/xap/menu/shake_on
FMGS: 0 : Cant Find Dataref: sim/330/fcu_old
FMGS: 0 : Cant Find Dataref: sim/330/nofpsmess
FMGS: 0 : Cant Find Dataref: sim/330/norain
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/p_f_l_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/p_f_r_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/p_c_l_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/p_c_r_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/p_b_l_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/p_b_r_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/c_f_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/c_b_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/bulk_kn
FMGS: 0 : Cant Find Dataref: sim/custom/xap/doors/one_door_open
FMGS: 0 : Cant Find Dataref: sim/custom/xap/groundserv/load_on
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/snd
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/vappr_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/vls_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/land_conf
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/wind_dest_deg
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/wind_dest_knt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/temp_at_dest
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/arr_inhg
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/baro_ishpa
FMGS: 0 : Cant Find Dataref: sim/custom/xap/elec/acess_shed
FMGS: 0 : Cant Find Dataref: sim/custom/xap/lght_nd
FMGS: 0 : Cant Find Dataref: sim/custom/ias_econ
FMGS: 0 : Cant Find Dataref: sim/custom/mah_econ
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/spdmanaged
FMGS: 0 : Cant Find Dataref: sim/custom/xap/engns/thr_lvr_zone
FMGS: 0 : Cant Find Dataref: jd/fadec/thr_lvr_zone
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/lat_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/lat_wait
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/vert_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/vert_wait
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/common_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/hdg_pull_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/hdg_push_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/vvi_push_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/vvi_pull_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/spd_push_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/spd_pull_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/trk_dial
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/appr_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/loc_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fly_phase
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/athr_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/athr_sub
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/thr_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/d_point
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/hdgtrk/hdg_dash
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/hdgtrk/hdg_ballon
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/alt100x
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/alt1000x
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/100_1000
FMGS: 0 : Cant Find Dataref: sim/custom/need_vs
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/alt_pull_do
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/alt_push_do
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/fpa_set_mult10
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/fd
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/ap1
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/ap2
FMGS: 0 : Cant Find Dataref: sim/custom/xap/indicators/autoland
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/vvi_dash_view
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/v1_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/v2_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/vr_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/anim/rev_l
FMGS: 0 : Cant Find Dataref: sim/custom/xap/anim/rev_r
FMGS: 0 : Cant Find Dataref: sim/custom/xap/disp/sys/mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fctr/mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/alt_push_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/alt_pull_bat
FMGS: 0 : Cant Find Dataref: sim/custom/xap/final_app
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/trans_alt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/trans_fl
FMGS: 0 : Cant Find Dataref: sim/custom/xap/alt/acc_alt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/alt/eng_out_acc
FMGS: 0 : Cant Find Dataref: sim/custom/xap/alt/thr_red_alt
FMGS: 0 : Cant Find Dataref: sim/custom/xap/engines/flex_t
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/to_shift
FMGS: 0 : Cant Find Dataref: sim/custom/xap/mcdu/flaps_pos_mcdu
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/vs1_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/vgrdot_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/vf1_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/vsg1_knots
FMGS: 0 : Cant Find Dataref: sim/custom/xap/reload/cg
FMGS: 0 : Cant Find Dataref: sim/custom/xap/radio/nav_but
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/alt_crzft
FMGS: 0 : Cant Find Dataref: sim/custom/vdev
FMGS: 0 : Cant Find Dataref: sim/custom/yoyo_on
FMGS: 0 : Cant Find Dataref: sim/custom/xap/pfd/moredrag
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/alt_cstft
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/alt_cstft_min
FMGS: 0 : Cant Find Dataref: sim/custom/xap/ap/alt_cstft_max
FMGS: 0 : Cant Find Dataref: sim/custom/terr_on_nd
FMGS: 0 : Cant Find Dataref: sim/custom/xap/fcu/nd_mode
FMGS: 0 : Cant Find Dataref: sim/custom/xap/trk_beta
FMGS: 0 : Cant Find Dataref: sim/custom/xap/nd/efis_opt_pb
FMGS: 0 : inPath E:\X-Plane 11\Aircraft\JD330XP11\plugins/fmgs/navdata/
FMGS: 0 : procPath E:\X-Plane 11\Aircraft\JD330XP11\plugins/fmgs/navdata/Proc/
JD SPEECH Plugin: Get MSG: contextpath>E:\X-Plane 11\Aircraft\JD330XP11\plugins\copilot_main\
ну конечно - наберите мне на скай j.a.romanov - поразбираемся что там не получилось
