26 (edited by captbullett 2015-05-21 14:52:14)
when I start I have the "start at ramp" checked this way I do not CTD and do not have issues  but i will now investigate. //* running 10.36r1 XP//
1) starting at KLAX ramp start and will spin up engines from cold and dark. [removed ground equipment]
NOTE: yes I can confirm, that the " displays", go dark after the move.
2) move to another gate at airport .
NOTE: will move to PANC, moved to PANC and no CTD but the displays are dark and inoperable and the engines are not running. but if I go into setting and uncheck "Allow for random failures" I will retry the process again. and see if the issue processed or if the issue was due to the "Allow for random failures".
B) the issue is still there after unchecking the "Allow for random failures".
http://jardesign.org/forum/misc.php?act … tr=49t1045
c) since, there is no CTD the log.txt does not show any issue to give any indication of an issue. so I agree with the findings...
3) move to another airport W/engines running.
cessna729 wrote:
Win7-64, XP10.35, v1.1b5.2, If you try and move the aircraft with the engines running using XP Location --> Select Global Airport --> and pick a different ramp start location or a Rwy some of the the displays go blank.
http://jardesign.org/forum/misc.php?action=pun_attachment&item=556&download=0
Not sure if this is an intentional "future" and or a "bug"? i.e. in real life you can't " instantaneously transport" an aircraft to different  location like in Star Trek
cessna729.
flight from KONT to KSJC.
CTD before Take Off
Attachment icon X-Plane_2015-05-21-085056_iMac-di-Alessandro.crash 69.98 kb, 239 downloads since 2015-05-21
Today two times a CTD.
First time EDDF-EDDM taxi to rwy.
Second time EDDF-EDDM proceed SID.
It's boring with the CTDs.
CDT on X-plane loading
CDT on Takeoff
Attachment icon X-Plane_2015-05-22-192920_Mac-Pro.crash 78.82 kb, 234 downloads since 2015-05-22
Attachment icon X-Plane_2015-05-22-195335_Mac-Pro.crash 83.7 kb, 256 downloads since 2015-05-22
30 (edited by TDPlane 2015-05-23 07:33:56)
At take off from KRDU05L on my way to KJFK, right after the callout "V1" ... CTD on OS X
PS
I had two successful flights yesterday and the day before !
Attachment icon bbox_log.txt 119 b, 251 downloads since 2015-05-23
Attachment icon X-Plane_2015-05-22-152751_iMacIVYBridge.crash.zip 16.58 kb, 259 downloads since 2015-05-22
And again. Third try to fly EDDF-EDDM. All okay, much vatism online traffic in EDDF.
Short after starting descend, adios...;-(((
And, by the way, Your antispam program bugs me like the CTDs. Is it really necessary, that i have to do the captcha for every single task? One time, if i press the submit button, it is enough, or?
Thanks for report. Sorry, but have a lot of dirt spam without capcha.
@JAR, when gets the 'actual bugs' get their attention back to be fixed? After this SASL issue? Just interested! No pushing or something smile The visual aspects will be recovered when slava is done with cargo loaders if I understood it right.
Just interested in the planning
Folks
please forgive my ignorance, new user.
I download the latest beta 1.1b5.2
it asks me to activate, which i do, then when I restart X-plane 10 and try to load the A330 I immediately CTD when loading the plane.
Not sure what 'clean install' means, as I delete the old A330 folder in my Aircraft directory and copy the new A330
Running Mac OSX Yosemite
thank you !
Had a nice flight from LSZH to KEWR. MCDU lost flightpath over the atlantic and automatically switched to next waypoint (T/D), which is weird. Then is was unable to add or delete anything into the flightplan, neither I could clear the FPL-Discontinuity on approach. I was assigned ILS04L approach. Weird.
But no crash!
36
Downloaded the file and all I did was add a b to the end of the file name so as to distinguish it from the working 330. I have tried 4 times to run it and eacg time it crashes the sim. I have attached my log file where it idicates SASl is the issue.
37 (edited by Luke173 2015-05-23 19:07:18)
First try with b5.2, crash while setting the Autobrakes to MAX prior Take Off.
Mac 10.9.5, XP 10.36
Flight plan would have been EHAM-LSZH.. Crash just after Push Back.
Again a try to fly EDDM-EDDF. CTD after start.
Crash on X-Plane 10.36r1
Description:
Crashed after activation and aircraft reload..
System Info:
Windows 10  10122 x64
CPU: Intel I7-3970X 5GHz
MB: ASrock X79 Extreme9
RAM: 16GB Corsair Dominator Platinum 2400
Graka: ASUS GTX TITAN Black
GFX-Driver: 352.84
SASL ERROR: Error loading panel: not enough memory
40 (edited by WoDi 2015-05-27 14:46:45)
I can´t believe it!
Now the 330 (1.1 b5.2) crashed again!
SASL INFO: loading    ground
SASL INFO: loading    icerain
SASL INFO: loading    radio
SASL INFO: loading    phase
SASL INFO: loading    view
SASL INFO: loading    light
No idea.
Dieter
41
WoDi wrote:
I can´t believe it!
No idea.
Dieter
try to put it to ../aircraft/a330/ folder?
also, a reason may be a new 10.36 or some installed plugins what eat memory well
good day,
try to re-start computer and then load XP ..
WoDi wrote:
I can´t believe it!
No idea.
Dieter
I did answer your post 41, sorry Eugeny, where is my thread?
I did rename to A330 folder and my RAM is 32 GB, I think enough.
Dieter
44
Dieter
32Gb or 8Gb does not matter in this case, course SASL can address 2GB only (upper memory). This 2GB may be busy by other plugins, that always loaded before aircraft.
I really don't know where is thread.. What was in it?
45
The aswer to your post 41.
This: I did rename to A330 folder and my RAM is 32 GB, I think enough.
It can not be a memory problem. Some minutes befor the A330 starts very well, without crash and other problems.
Dieter
Had a very successful flight yesterday from GCTS to LSZH on this release. My XP 10.35 64-Bit. I did the flight on IVAO.
I still see some misalignment between the AirFMC and the MCDU in the A330. When changing the FPlan, the Insert button disapears on AirFMC. Same as when being on PERF page. The header is missing (e.g. DES)
No issue this time for the A330 to follow the green line.
Only issue was at departure airport, MCDU has no runway at GCTS :-(
Please, inform me about misalignment between the AirFMC and the MCDU. Be cool to have 2 picture - what show iPad and what show MCDU at this moment (when some wrong). I can't check myself, course not use iPad (just broken now).
48
Let me try to do this tonight.
49 (edited by captbullett 2015-05-29 16:17:45)
here is the change in the tracking and it happens when you do not have enough way points in your Flight Plan on a long flight over 2,000 NM and you Range Knob is set at 320NM and then switched to 10NM or is just change during the flight any one of these conditions will cause the "off set of the tracking in the MCDU and the AirFMC I did a post in the forum in the XP forums but not here.
here is a couple of screen shots that you wanted.
50
Hi I've been away for a couple of weeks. I take it that this is the latest beta version ?
