401
saul.public wrote:
Using hot fix 4. Went to LOWI and started plugin. You can see double up of aircraft in same position.
http://jardesign.org/forum/img/m/2253/t/p1ad70qiq71tb2t5g19vfn81121k3.png
http://jardesign.org/forum/img/m/2253/t/p1ad70qiqhbl23ul51us51v814.png
This has nothing to do with hot fix 4. I saw it in earlier beta versions happening also in LOWW and EDDM.
Some airport add-ons includes pseudo-aircrafts at parking lots that were designated for X-Life traffic...
This can be easily corrected JAR must only know where this happens....
402
as I wrote you on YouTube, 320dpi resolution is far too low.
Sorry but the videos are unclear...
To see details we need to make videos of 720 - 1040 dpi, so we can enlarge them.
I have done everything to change the settings but every time I post I get the lower settings so if you know how to get the right settings please tell me i am on a mac and changing  the settings is different  thanks for your help as I do want too get it right for everyone.
letec wrote:
For me, still unusable. Crash nr.5 and nr.6. Crash nr.5 just after take-off and crash nr.6 on the ramp during start the engines.
Best Regards
If this possible, please contact me skype j.a.romanov - will check this direct on your computer.
404 (edited by pic 2016-03-07 10:16:07)
OK, Great flight from a to b...LFMN-LIRF.
HotFix 4
Rotate MD-88
Deleted SMP, gizmo and used designer clouds available at org dl..so much better equally nice, better on system
Used all JAR plug-ins...fm car, etc
Only 1 x-life issue:
FM car at LIRF drives on the medium instead of the taxi way--no biggie, just a tweak smile
Log attached..no BBC needed
LOVE this plug-in!!
Mad Dog 88
405
I depends on some parameters:
1 at what resolution are you running X-Plane on your Mac (iMac?) For example, I am used  to run X-Plane at the Highest resolution, - Preferences/display/ "Best for display" (2560x1440)
2 Which recording software are you using. You must have a software able to handle this high resolution recording of your screen. I am using iShowU HD pro (not cheap but capable to make an HD high resolution captured video)
3 How du you prepare your video. Using iMovie you can edit your video (cut ,title, text, music, transition, maps etc.) and after you finished send it at high resolution directly to YouTube. Then you will get HD video quality at high resolution as 1040dpi.
4 there is a possibility to capture flight directly from X-Plane. I tried it once but it hadn't the needed quality nor sound output...
406 (edited by Sloboda 2016-03-07 16:00:13)
many many planes don't roll on center af runways
Not center:
http://jardesign.org/forum/img/m/1506/t/p1ad8h22egdsj1o9o1t2p1qqv1sff4.jpg
Center on the same runway:
http://jardesign.org/forum/img/m/1506/t/p1ad8h5e7a1va7daatis123da327.jpg
2 planes will cross on 2 runways. One of them landing, other one take off.
http://jardesign.org/forum/img/m/1506/t/p1ad8habq6pm21ealv2b1v66vdv9.jpg
Some planes wait at same place. Not just on the point on the photo. On several points.
http://jardesign.org/forum/img/m/1506/t/p1ad8hia63t721vkg0s14lmeskc.jpg
And they takeoff together...
http://jardesign.org/forum/img/m/1506/t/p1ad8hk3om1knh1qn0otii3n19fcf.jpg
Many planes enter on ruway via intermediate in/out. I really would planes enter at extremitie and can out from intermediate in/out.
http://jardesign.org/forum/img/m/1506/t/p1ad8i30k2vlf6qfl11js117hhh.jpg
Thank you bye
407 (edited by ilankrt 2016-03-07 14:40:54)
Thank you bye
About what airport are we talking?
There are often more  free airports for one location. Some of them are well designed and some has incorrect runways and taxi ways. Problem is to identify the last ones and take care about corrections.
You should send more information and data to identify the causes....
408
just finish flight from LICC-LFBO with A320, all perfect from delivery to shutdown on LFBO. About me this version is good.
Thank you bye
You are right, sorry, i have completly forgot to give OACI. I'm on LFPO (Paris Orly)
I give my LFPO.dat and LFPO.txt, like that, you have all informations.
I really "love" this work and would like contribute to create airports but i have just little problems but i have several questions without answers in the 2 topics of X-Life. I think i just need few informations to can finish my work.
Thank you for interest. That's cool.
Bye
410 (edited by captbullett 2016-03-07 16:26:05)
good day,
for the first one I run at the highest Display value (2560x1440) this is a no brainer and I do not see why you would think as a developer I would run any thing different.
as for the second question I am using Quick Time and yes it is good enough to run the HD that you are talking about.
I will not use a third party software just to record video as it is a way to hack the computer , you use  iShowU HD pro that is your choice but I am not in the business of film making and 58 $ for the software just not going to happen when I have QT.
I have not edited the Movie so maybe this step is what I need to do with iMovie . I will try the next time but I do not like the iMovie set-up this is why i do not edit my movies and just up load straight to the You-tube .
and again you are the only one that seems to pick everything apart when it comes to the work that people do. You are never satisfied so I will take this with a grain of salt.
thank-you for your feed back
Ps, the movies were to show the traffic flow and not so, much  anything else so it captured the detail I needed as you know XP does not have sound. i am surprised you did not complain about that.
411
Thank you bye
Bye
Can I ask you provide link to scenery what you use
http://jardesign.org/forum/viewforum.php?id=33
412
Hotfix 4.  Still getting CTD when creating plan from EIDW to EGLL.
413 (edited by captbullett 2016-03-07 17:24:26)
the log.txt stops with it saying the steam up-dated so this is not a complete log or the steam was up-dating and this was the cause of the CTD this can happen because you have to re-load to have the up-date take effect so it shuts down and you think you have a CTD when all you have is an up-date by your steam-library at least this is what I am seeing. and make sure you have all your up-dates on the PC ... 10 Windows and you know the drill.
XL: 122 : JARDesign plugin: C:\SteamLibrary\steamapps\common\X-Plane 10\Resources\plugins\X-Life\Metar/EGLL.TXT file updated.
414
Hi i hope this is the right forum i saw general discussion. I was wondering if jar designs might think about making the Dornier 328 jet i love the 148 that you have made and would love to keep my fleet with jar designs
415 (edited by Sloboda 2016-03-07 20:40:56)
Bye
Sure, http://xpfr.org/?body=scene_accueil&sc=106
It is on a base of the aerosoft scenery but better, more nice. Better look, taxi lines and jetways. And Aerosoft LFPO is very ugly, the taxi lines are really not align with jetways
I have make changes in the dsf for remove statics planes.
416
why we can't make a flight plan when the airport is not validate ???
I have make the LFPO (Paris Orly) Taxi Routes but i can't make flight since this airport 'cause this problem.
x-Life always say alternate airport is not valide. Like if i make a custom flight plan.
I think that's can degrade the enjoy for X-Life, it's too bad so it's very very good and interesting for every X-Planers. This problem create too much limits of X-Life.
You are wrong, XL may work with any airport what have Custom-build .dat & .txt files in /Airports/ folder
I'm sorry, i think i had an error in my apt.dat because now, that's work.
Thank you.
417
EIDW to EDDM.  No issues.  Two planes ahead of me at the holding point at EIDW and had to wait until the took off.  This is the first time that has happened.  On previous occasions, I had to taxi through planes in front of me.
418
Don't think that's the problem.  Did a flight shortly afterwards from EIDW to EDDM with no issues.  Just tired EIDW/EGLL again and got CTD.
419
then a log.txt is needed with the good route and the CTD route this is the CTD that we are tracking and is very hard to catch so all the data we can get from you is a must for us to help.
420 (edited by Acei 2016-03-08 00:42:02)
Here you go Brian.
There was no route generated.  Just a CTD.  I checked the Xlife folder and there isn't one there for EIDW/EGLL.
The correct route should be:
EIDW SID DEXEN UY124 AMPIT L15 HON STAR EGLL.
I'll check EGLL to EIDW and see if that works.
Ken.
EDIT - tried EGLL/EIDW and it works fine.
421
Have downloaded the Hot fix 4 and have tried several times from airport EDDM and EDDH to test out the hot fix. However, after I start Xlife, every time I attempt to start traffic, I get the message it is loading, but then after a few seconds,  I get CTD. I have my log file attached.
contact me skype j.a.romanov, please - will check online
423 (edited by ilankrt 2016-03-08 11:48:16)
Test flight beta v.8 fix 3  (see thread 386)
Just finished editing a video about the approach phase:
https://youtu.be/b_Iurb3jVvg
Note:
At 10.10 minuts video, the A330 is flying a hazard maneuver that will never occur in a real world flight.
I let the aircraft intentionally be on AP and LOC to show the wrong approach route that brought the aircraft
directly towards the hills at 300 feet over terrain (!). Then I had to disable AP and correct course to runway.
From this moment the A330 got in a oscillation although tailwind was weak (5 kt). This was my fault as I didn't
deploy timely flaps 3-4. You can hear the alert "too low flaps":-( (the A330 voice console me "next time will be a better landing)
The video shows also ATC treating the approach false as ILS....
424
Good day
About Gate Editor
1. X-Life On
http://jardesign.org/forum/img/m/622/t/p1adb8i4adjc49us1brmegpir8b.jpg
2. Open Gate Editor
http://jardesign.org/forum/img/m/622/t/p1adb8ie09stu1f9i1b151dfnov7d.jpg
3. Change gate size, click "Save .txt", Off XL then ON XL
http://jardesign.org/forum/img/m/622/t/p1adb890371bho1coa1057lum3h77.jpg
4. Open Gate editor.
http://jardesign.org/forum/img/m/622/t/p1adb8gb6d1047rv2o1ili1fu29.jpg
LOWG.TXT file changed
425 (edited by captbullett 2016-03-08 14:32:46)
Acei wrote:
Here you go Brian.
Ken.
thank-you JAR will now compile this to help track the CTD  and doing the reverse Flight Plan, and post the Log.txt please , (good or bad) is a SOP that I do also  five * on the work.
B.
