1 (edited by BerlinFlyer 2016-02-17 07:01:03)
Topic: iTow does not work with all planes
The iTow plugin does not work correct with planes of Peter Hager (A 320, A 320neo and A321 tested) and with RW Designs A 330-300.
That means in detail, you can push back ahead, but you can do no turns. The truck turns, the plane stops.
What is to do ?
With Regards
Olaf
Re: iTow does not work with all planes
I hope the reason for the silence bases not on the competition between JARDesign's and RW Design's A 330 or JARDesign's and Peter Hager's A 320.
Whit regards
Olaf
I don't have all details but the basics are relatively simple. There are two kinds of service, one which is very limited, as you have only access to the content that is stored inside the airplane, and full Internet access, which uses a satellite receiver, connected to a small network inside the airplane, coupled with a billing system.
college essay writing service
