You don´t need a link, just download the full package from x-life site and extract it. Copy xpl files in your x-life folder
JARDesign Group Board → Updates & General Discussion → X-Life public beta-6, 7, 8, 9 (Win & Mac)
I would like to use the route that X-Life is offering (presently I don't know if their are same) to let everything to be
original X-Life. I am using the JAR A330 (X-Life transfers its flight plan directly to the FMC), on my iMAC27.
Start point EDDH parking lot 18 (FollowMe car isn't appearing ?!) I am preparing the aircraft from cold and dark (it takes
me 15-20 minuts incl. programing the FMC) Then I can already see aircraft traffic (sometimes collision with other aircraft on taxi ways).
In 4 hours I will start another test flight.
Captbullett I wrote you in the thread about SMP3 have a look
Concerning SMP3 it is obviously that there is a strong conflict with X-Life !!
Last time starting X-Plane with X-Life and SMP3 not only X-Plane stocked but also OSX every 20 seconds !
Then I unchecked SMP3 from administrator list and everything was fine.
After a while I checked SMP3 on and actualized METAR - no crash..
This is totally crazy..................... !
sound good to me lets use // * http://onlineflightplanner.org /// so we can download the plan via the widget and also get the same data from the PDF that will be provided it will give the fuel and the load data also and other data to help match the current data ...
this is a big help if then we all send a bbox.txt before we close the X-Plane down to JAR this will help him also send the log.txt
thank-you for your help,
Brianthis is the route I will be using and set as a control if it is a good route I must test it one time first to see if it works !
EDDH SID WSN UN125 EEL STAR EHAMilankrt wrote:I would like to propose to take the very short flight from EDDH to EHAM as common test flight route
@Eugeny
watching the scene LIPZ - > CTD (after about 15 min), see log
How is everyone today, I am testing the ;
today using the A330 and I want to make sure that it is a good route for a control test route, and I do not see why not but one never knows until we try it out and then I what a return route so we do a down n' back for testing.
So, this is my thought that if we all are running the same route if any issues show up they will be easer to track if we are all using the same flight plan.
thank-you for you help,
Ps, this is the return flight plan the was generated by //* http://onlineflightplanner.org ///
EHAM SID ANDIK UN873 GRONY UM105 EEL UN125 WSN UL23 HAM STAR EDDH
Now these two routes should be the control route after I test them it is work in progress right now.
Well,
flying from EDDH to EHAM on route: EDDH SID WSN UN125 EEL STAR EHAM with an A320neo on an iMac 27ret, i7(4) without any trouble or problems with x-life beta8 hf2.
I´m also a developer and i can understand the f...ing problem, CTDs and no CTDs -> where is the bug?
edit:
one bug i had found, i landed an runway 09 and it´s not an ils approach, it´s a VOR approach
and the approach was very windy ;-)
Hi There,
did a testflight with the 320neo from EDDH to EHAM too but not that good result for me.
I got an CDT while descending arround 7000 feet after EEL.
Attached the log of the Flight. Hope it helps kill those anoying bugs
this is what the HF2 is for to track the data and so my train of thought is for everyone to use the same route so there is a common thread then we can see how each X-Life acts on the same route and shake -out the bug!
Well,
good day,
just started XP and CTD , version 10.45r1 this is the data that we are trying to collect now. and this CTD was due to the FMC not the X-Life plugin.
Just made a flight from LPPT to LPFR (2 airports I made the ATC routes). First thing, is that I could not create the flight plan from the xx-life plugin. When I clicked generate FP, nothing happened. I had to create the flight plan manually, so I put there: LPPT SID TROIA A5 ODEMI STAR LPFR.
So the ATC gave me the clearence without the SID from Lisbon. When I was on holding point of rwy 03 at Lisbon, I saw an aircraft from x-life simply passing over my aircraft ![]()
The rest of the flight was ok, without any problems until arrived on the gates.
Curiosity, I had a flight behind me that parked side by side with me ![]()
Besides the bugs and some other things not like real life (At least for now),,,,,,,,,,,,, I had a pleasure making this flight.
good day,
bbox.and log.txt or your post just does not help !
now I have got every thing straight I found a free EHAM at the .org that works and does not CTD the XP app
so the EDDH to EHAM it on for the test route and the followMeCar will work if you remove the old txt and dat file in the Airport file, and let the FMC reload after you install the scenery pack.
this is a very good scenery pack and looks as good as the pay-ware.
Can we not use our own airports at all anymore with the latest X-Life Deluxe version?
I am getting the message that my new KBOS is not an approved airport and the gates editor doesn't open.
That's disappointing. While we beta test on the "approved" airports it would be kind of nice to be able to test our own airports as well.
Test flight completed Hamburg Amsterdam. No CTD and ATC went well. I set my cruise level too low because I thought it was much shorter than the actual distance but X-life behaved properly.
Two slight issues:
On departure Runway 05 from Hamburg I was asked to hold short for an arriving plane. I was never told to position and hold even long after the plane had vacated the runway. As soon as crossed the hold line (which I should not do) I was told to position and hold and the flight continued normally.
Secondly, I reached top of descent just before EEL. I reported TOD and was given my STAR. This was EEL1A which on the charts begins at EEL. But when I entered this into the FMC the flight path was 10 miles south of my current position (just before EEL) and I was off course. The autopilot turned to intercept the new path but then did not intercept correctly so I had to fly the approach in heading mode and then manually. I was flying the JAR A320 NEO latest beta. I guess the STAR issue is a problem with the A320 rather than X-Life.
Overall very good flight. I have pasted the logs anyway because sometimes successful flight data can also be useful. I will report other CTDs if I have them.
Where do I get the file bbox ?!
good day,
captbullettPM1970 wrote:Hi
it is in the //* Main aircraft folder/A320Nev2/bbox
or the //* Main aircraft folder/A330/bbox.txt
and you will find it right below the airfoil folder if your file system is in order .
So much,
captbullett wrote:good day,
have you up-dated to the latest version 8 with HotFix 2
thank-you,
Здравствуй,
вы обновлялся до последней версии 8 с HotFix 2
Спасибо,
why ATC don't work on flightplans where the airports don't have ATC routes ??? ATC need the ATCroutes of airports for work ?????
When i try to make a flightplan with a destination who don't have ATCroutes, X-L say "the alternate airport is wrong".
Hello, noeone for answer me ?
http://jardesign.org/forum/viewtopic.php?pid=9702#p9702
Thank you for help, i really would like to start to create ATCroutes
thank-you,
captbullettЗдравствуй,
Спасибо,
Yes of course updated.
In the file log.txt errors have been found associated with objects from the OpenSceneryX library. The contents of one of the folders in the screenshot. The OpenSceneryX library updated.
"Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/a320/frontier/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/a320/frontier/object.obj
Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj
Failed to open D:\Games/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj: the file cannot be opened.
X-Life Object load error: D:\Games\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj"
Test flight EDDH - EHAM, using JAR A330
EDDH taxi, ground trafic, ATC No problem (I set SMP3 to default) 30fps
During flight FL 240, clouds and 22 fps
Descent I go clearance to RWY 24! ATC bug: Clear ILS 24 but it is a VOR appr
From now on ATC is giving order for ILS - not usable
Result: appr manually, reciving abbort landing........
Frame rate sink near EHAM to 11fps
Go Around re-program FMC for ILS RWY36 - no ATIS and lot of aircraft on taxi
Hi..just use the same destination for that. So, if you go from LIRF to LFMN, just use LFMN again for your alternate airport.
Sloboda wrote:Hello,
Thank you. It's exactly what i do. That don't work.
ATC just match with airports where there are ATC routes. 27 airports in the world .... TOP !
And like i say in my other posts... But nobody answer... We can't try to make ATCroutes 'cause the airports must be validate.
How can we learn to create if we can't test.
Perhaps i will know a day in the future if someone would answer me...
Thanks for the info. I don't have neither of these 2 aircraft...
it is in the //* Main aircraft folder/A320Nev2/bboxor the //* Main aircraft folder/A330/bbox.txt
So much,
BrianPM1970 wrote:Hi
