Topic: LIRF Rome
By Vatech, for freeware (5 star) Rome airport.
http://forums.x-plane.org/index.php?app … file=18700
When you start FMCar and/or X-Life next time, LIRF files will be autodownloaded to your /Airports/ folder
JARDesign Group Board → Custom ATC routes for XP Airports → LIRF Rome
Hi there, and thank you for those files.
I'd suggest a review of them, since I have discovered a recurrent bug.
After have been instructed by the ATC to taxi to the Holding Point RWY 25 via BA1, the Follow Me Car always stops at the BB1, way before the point that I am supposed to reach.
Thank you!
Hi there, and thank you for this files.
Thank you!
Hi Michael!
Can you do a screenshot from x-plane and show me exactly in what place of the BB1 FMCar stops?
Thanks in advance.
Hi vatech,
I'll share the screenshot with you as soon as possible.
Meanwhile, do you have a any idea if it is possible to zoom in the map? That would be a great feature.. (I know that is not up to you I am just asking if you know it..)
Hi vatech,
About zooming the map. At this moment no opportunity for scaling the map, but I was asking the JAR create this feature too. May be in future this function will be added to plugin, or just will be increased the map size.
Now about screenshot. I don't need a screenshot of FMCar map. Just turn a free camera view, place it to the taxiway where you have problem and make a screenshot (also you can draw the arrow in mspaint for marking the place on taxiway in screenshot for me, where FMCar stops). I have some Idea why this trouble present, but with screenshot it will be easy to detect and correct it.
Thanks for understanding.
!!! UPDATED !!!
Michael, please try attached file, probably it resolve the problem. Copy with the replacement to the "X-Plane 10 \ Resources \ plugins \ X-Life \ Airports \" (If you using FM Car, also copy with the replacement to the "X-Plane 10\Resources\plugins\FM\Airports\") where X-PLANE 10 it's your X-Plane folder.
Reattached to first post too. Thanks vatech!
Ok, I'll try this file and I'll let you know.
It will be not to bad to let me know.
!!! WARNING !!!
After reconstruction of X-PLANE.ORG website, all links to content was changed, so a new link to LIRF is: http://forums.x-plane.org/index.php?/fi … i-airport/
