176 (edited by Sloboda 2016-02-25 07:24:05)
All planes arriving for landing are B747 and fligh by side then suddenly, the plane change and it fligh in line...
And when take-off it's more WEIRD ! See the pictures. You have 2 planes one in one (with the 747....)
177
seems like you use default X-Plane 10 traffic together with x-life
178
Dewald wrote:
I truly want this to work for me, but alas.
XP crashes as soon as my aircraft takes off.
log attached.
PS! This happens with more than just the MD80.
As I read at log:
X-Life:Curl=Failed writing received data to disk/application
May be you need check your antivirus settings. For some reason plugin cant wright data to HDD.
179
When an airport have statics planes, there are some airplanes AI in statics airplanes.
So i really don't know WED but, is it possible unable static planes when X-Life run ? If not, we should review the airports in WED for remove the statics.
1.Some sceneries have .dsf files for "non static"
2.Import/Export scenery and delete static
3.Make a non-static scenery with exclusion zones only.
180
p_delray wrote:
Is there a tutorial on how to use the ramp tool?
http://jardesign.org/forum/viewtopic.php?pid=8650#p8650 (close to the end)
181
MikeMJD wrote:
Hi Jar.
Just purchased deluxe. worked OK before. now I enter code for deluxe and CTD twice?
will check online! my skype j.a.romanov
182
screetch82 wrote:
X-Life plugin by JARDesign Ver.beta 7 200216
OpenSceneryXpath find
JARDesign plugin: E:\X-Plane 10\Resources\plugins\X-Life\Metar/EDDC.TXT file updated.
Failed to open E:\X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
X-Life Object load error: E:\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj
SkyMaxx Pro: Memory Check: 62720 KB GPU, 18331120 KB CPU
0:02:18.016 D/HID: Hardware REMOVED Saitek Pro Flight Quadrant
0:02:18.016 I/JOY: UNREGISTER Joystick device: Saitek Pro Flight Quadrant - VID:1699PID:3117
0:02:19.362 D/HID: Hardware ADDED(06a3, 0c2d) - Saitek Pro Flight Quadrant at path \\?\hid#vid_06a3&pid_0c2d#6&11374596&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
0:02:19.362 I/JOY: REGISTER Joystick device: Saitek Pro Flight Quadrant - VID:1699PID:3117, this is a familiar device.
0:02:19.362 D/HID:     BUTTON Added Index: 0 (0009, 0001) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 1 (0009, 0002) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 2 (0009, 0003) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 3 (0009, 0004) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 4 (0009, 0005) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 5 (0009, 0006) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 6 (0009, 0007) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 7 (0009, 0008) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 8 (0009, 0009) for handle: 0x06585c30
0:02:19.362 D/HID:     AXIS Added Index: 0 (0001, 0032) for handle: 0x06585c30. Min/Max 0 - 255
0:02:19.362 D/HID:     AXIS Added Index: 1 (0001, 0031) for handle: 0x06585c30. Min/Max 0 - 255
0:02:19.362 D/HID:     AXIS Added Index: 2 (0001, 0030) for handle: 0x06585c30. Min/Max 0 - 255
0:02:19.362 D/HID: END HARDWARE
SkyMaxx Pro: Memory Check: 118464 KB GPU, 18139032 KB CPU
I see some strange:
Please post full log or contact me skype j.a.romanov
183
MikeMJD wrote:
Hi Jar.
How i can buy Deluxe ?????
184
Thanks JAR --- You were correct --- My real time anti virus caused the crash.
Now my second problem --- I want to buy the Deluxe version, but don't know how.
The X-Life website does not permit.
Dewald
185
I will just keep reporting stuff I bump into: just to help iron out the bugs... :-)
In the log.txt I saw the following errors:
Error 1
Failed to open D:\X-Plane 10.45 beta//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
X-Life Object load error: D:\X-Plane 10.45 beta\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj
Failed to open D:\X-Plane 10.45 beta//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj: the file cannot be opened.
X-Life Object load error: D:\X-Plane 10.45 beta\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/object.obj
I checked: there are no objects in the lit and unlit folder -> the object is directly placed in the citation folder. From the library.txt:
EXPORT opensceneryx/objects/aircraft/jets/corporate/citation_x.obj objects/aircraft/jets/corporate/citation_x/object.obj
Error 2
Failed to open D:\X-Plane 10.45 beta//Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/a320/frontier/object.obj: the file cannot be opened.
X-Life Object load error: D:\X-Plane 10.45 beta\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/heavy/a320/frontier/object.obj
Here it is the otherway around: the obj files are in sub folders. From library.txt:
EXPORT opensceneryx/objects/aircraft/jets/heavy/a320/frontier/cougar.obj objects/aircraft/jets/heavy/a320/frontier/cougar/object.obj
Cheers,
Matthijs
186
Dewald
Only one way - click SUPPORT at website and will see an info.
187
How do you stop using default X-plane traffic?
188
MikeMJD wrote:
Hi Jar.
Hi Jar fixed and working.
My beta registration was the problem.
Mike
hmm
189
Just post beta 8. Olny bugfix this time.
190
Found a bug in beta 8, radar map.
Button + and - operates incorrectly, "+" zooming out, "-" zooming in. Should be + to zoom in and - to zoom out (like google maps).
191 (edited by Acei 2016-02-25 18:26:05)
Flight from LFMN to LICC.  Only problem was when I started taxiing there was a 737 already at the holding point of the runway.  I arrived well behind it, but got clearance to line up before it and had to taxi through it.  I can understand that this could happen if two planes start taxiing around the same time, but this one was already sitting at the holding point when I started the short taxi.
http://jardesign.org/forum/img/m/683/t/p1accin5rqnvop6e1ltv14gu1p9p3.jpg
BTW, was using Beta 8.
192
CTD while watching the scene.... nothing done...
CurFlow: AUTOGEN: North NewFlow: AUTOGEN: West
0:03:15.361 I/ATC: Changing XEDDM CabState from 0 to 1
0:03:15.361 I/ATC: All departures are done at XEDDM. Advancing...
0:03:15.361 I/ATC: Changing XEDDM CabState from 1 to 2
0:03:15.361 I/ATC: All arrivals are done at XEDDM. Advancing...
0:03:15.361 I/ATC: Changing XEDDM CabState from 2 to 0
0:03:15.361 I/ATC: Airport flow changed at EDDS!
0:03:15.361 I/ATC: Changing EDDS CabState from 0 to 1
0:03:15.361 I/ATC: All departures are done at EDDS. Advancing...
0:03:15.361 I/ATC: Changing EDDS CabState from 1 to 2
0:03:15.361 I/ATC: All arrivals are done at EDDS. Advancing...
0:03:15.361 I/ATC: Changing EDDS CabState from 2 to 0
0:03:15.361 I/ATC: Airport flow changed at XED6B!
0:03:15.361 I/ATC: Changing XED6B CabState from 0 to 1
0:03:15.361 I/ATC: All departures are done at XED6B. Advancing...
0:03:15.361 I/ATC: Changing XED6B CabState from 1 to 2
0:03:15.361 I/ATC: All arrivals are done at XED6B. Advancing...
0:03:15.361 I/ATC: Changing XED6B CabState from 2 to 0
X-Life plugin by JARDesign Ver.beta 8 250216
JARDesign plugin: D:\Spiele\X-Plane 10\Resources\plugins\X-Life\Metar/EDNY.TXT file updated.
0:15:14.867 E/SCN: Failed to find resource 'Citation_X_C-GCUL.png', referenced from file 'D:\Spiele/X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/lit/'.
best regards
193 (edited by captbullett 2016-02-25 18:02:54)
so this just fixes XPL file so the widget works for X-Life 'AGGREE' right ?
B.
Just post beta 8. Olny bugfix this time. To upgrage beta7 - beta8 nedd replace .xpl files only
194
hI,
New test flight wiht beta8 but same problem, i ont have option in proximity of TOD, i've last information from approach to reach my crz altitude and stop
I've set STD and i was at 4NM to TOD but no option.
In attach 2 screen, one to show that i was at 4nm to TOD, connect with CENTER but without any options, other to show that i i click on last icon i receive the message that the traffic is off.
Thank in advance
195 (edited by captbullett 2016-02-25 18:32:45)
So, the timing is off how do we fix this it is in the XPL file and the code right so JAR needs the bbox.txt  so he can debug it I think but you might wait a min. or so to see if the aircraft will move before moving forward this might get the timing back on track.
B.
196 (edited by SirOTheOne 2016-02-25 18:45:38)
Hi Eugeny,
flying with beta8 from EDDC to LOWL, after approach while taxing -> CTD, see log.
with beta7 i had no problems with my machine and config
197
not Zoom, but increase/decrease Range
198
Rather unhappy that I am being so ignored both here and in support email. I sent an email almost a week ago to support with no answer and now my post here, number 166, with a large screenshot of the problem is being ignored. Why?
199
No info - no idea. Be useful use at least log. And some description of situation.
200
Hmm.. seems like all have CTD with beta 8, but i have not. May be I am just unluckie.
