151 (edited by PM1970 2016-02-24 11:53:19)
Once again big_smile
A bug detected when 2 aircrafts taxiing on parallel taxiways in opposite directions... One of them simply stopped as seen on this screenshot.
Also in this airport (YSSY) there are some strange things happen, for instance, sometimes, an aircraft should cross rwy 07, but even if there isn't a landing in this runway (but exists a landing in 34R) he just stops before crossing runway 07, waiting for the land of rwy 34R that has nothing to do with 07, they does not even cross.
I had a airplane that has lined up on rwy 07, then he just stayed there waiting for a land in rwy 34R, after the landing in 34R he continued lined up on 07 wainting for a land in... 07. And the aircraft that was approaching this runway just landed on 07 even with the other one lined up on 07.
http://jardesign.org/forum/img/m/2219/t/p1ac9gso671npgbrh1t0lbt6117h3.jpg
152
Video I made of my test flight with the A330,  X-Life version beta 7 and FollowMe car.
(I reported already about one error I found)
https://youtu.be/vYgP0Wv1C_U
If you want to read about my experience:
http://ilankrt1.blogspot.co.il
153 (edited by MH1212 2016-02-24 14:28:38)
I was working with the Gates Editor when I noticed that the start positions are off. Somehow the plugin rounds the actual lat/lon coordinates but also displaces them?? I zip the dat and txt file where you can see that the coordinates differ.
http://jardesign.org/forum/img/m/2216/t/p1ac9qs8fmtf31ies1ee8hrt1ajd3.jpg
http://jardesign.org/forum/img/m/2216/t/p1ac9qsr651oah6dce8i3cue007.jpg
The strange thing is that the AI plane is actually located in the right spot (purple arrow vs green arrow): see next image... So it is only a problem with the Gate Editor??
NB: with another airport the arrows were located at exactly the right spot!
154
What scenery you use? Have you a link to download and try it?
155
Thanks! Interesting story and video!
156
Thanks for report. Yes, if 2 parallels taxiway have a short distance centerline-centerline - one of aircraft may stopped and wait a time. Seems like danger-analyze algorithm not perfect.
157
Concerning the question about the QNH demand there is a bug. The first demand for QNH getting clearance from Delivery is understandable.  The second one occurs during flight while contacting Approach. I got a an error massage saying "wrong ATIS information (I flew at FL 237 and my QNH was STD). Only After I changed STD to QNH 1015, I got the massage "identified  expect ..." as you can see on the attached  images
The correct dialog must be:
APPROACH: SA001 contact MUNICH Approach on 123.625
SA001: readback
SA001: MUNICH Approach, SA001, FL237, descending to FL170, information Whiskey on board
APPROACH: SA001, MUNICH, radar contact, expect NAPS1A arrival, ILS approach runway 26L, DESCENT FL 110 (for example - over 10.000 feet),
SA001: readback
Additional instruction
APPROACH: descent 5000 feet, QNH 1015, transition level FL 50
SA001: readback
This was a test flight  from LOWW to EDDM with ver. b.-7. Beside this bug everything functioned well.
One question to JAR team: How many aircraft are pre installed when using X-Life the first time?
Need just read ATIS before you contact Approach.
No preinstalled aircraft inside X-Life plugin, but all - from OpenSceneryX now.
158
PM1970 wrote:
Hi once again
Making a flight from EDDM to EGLL, 5nm from T/D I changed to CENTER (not realistic though) and said reaching T/D. The simulator crashed.  I use FSRealWX to inject weather on X-Plane 10. The last lines from my LOG:
thanks! i work on code improvements to avoid CTDs
159
BIG QUESTION !
I think perhaps i have not all understand...
X-Life is an ATC ??? for me, no...
Or just manage traffic like WorldTraffic ???
Thank you very much for help me.
160
It is just a Prefab Airport: 00C. I produced just one to test X-Life... I am working on some updates which include ATC routes. I uploaded the custum scenery (test) folder as well as the dat and txt files from the X-Life Airports folder. If you need more info, please let me know! Happy to help testing!
Cheers,
Matthijs
161 (edited by captbullett 2016-02-24 16:49:32)
So, can we do this, re-try and when it CTD do not close XP but send bbox.txt and full log.txt so we can get the full picture, the Real Weather is not at issue here. The autogen ATC is doing something and to figure out what JAR needs the box.txt and the full log.txt
Thank-you for your help,
ps, use the 'edit' button to bring up the 'choose file' so you can up-load the bbox.txt file and the log.txt file with-out a long string of txt on the post ... thank-you
B.
PM1970 wrote:
Hi once again
2:53:56.451 I/ATC: Airport flow changed at EBAW!
CurFlow: AUTOGEN: North NewFlow: AUTOGEN: West
2:53:56.451 I/ATC: Changing EBAW CabState from 0 to 1
2:53:56.451 I/ATC: All departures are done at EBAW. Advancing...
2:53:56.451 I/ATC: Changing EBAW CabState from 1 to 2
2:53:56.451 I/ATC: All arrivals are done at EBAW. Advancing...
2:53:56.451 I/ATC: Changing EBAW CabState from 2 to 0
2:53:56.959 I/ATC: Airport flow changed at EHSE!
2:53:56.959 I/ATC: Changing EHSE CabState from 0 to 1
2:53:56.959 I/ATC: All departures are done at EHSE. Advancing...
2:53:56.959 I/ATC: Changing EHSE CabState from 1 to 2
2:53:56.959 I/ATC: All arrivals are done at EHSE. Advancing...
2:53:56.959 I/ATC: Changing EHSE CabState from 2 to 0
2:53:57.687 I/ATC: Airport flow changed at EBWE!
2:53:57.687 I/ATC: Changing EBWE CabState from 0 to 1
2:53:57.687 I/ATC: All departures are done at EBWE. Advancing...
2:53:57.687 I/ATC: Changing EBWE CabState from 1 to 2
2:53:57.687 I/ATC: All arrivals are done at EBWE. Advancing...
2:53:57.687 I/ATC: Changing EBWE CabState from 2 to 0
2:54:00.211 I/ATC: Airport flow changed at EBFN!
2:54:00.211 I/ATC: Changing EBFN CabState from 0 to 1
2:54:00.211 I/ATC: All departures are done at EBFN. Advancing...
2:54:00.211 I/ATC: Changing EBFN CabState from 1 to 2
2:54:00.211 I/ATC: All arrivals are done at EBFN. Advancing...
2:54:00.211 I/ATC: Changing EBFN CabState from 2 to 0
JARDesign plugin: C:\X-Plane 10\Resources\plugins\X-Life\Metar/EDDM.TXT file updated.
JARDesign plugin: C:\X-Plane 10\Resources\plugins\X-Life\Metar/EGLL.TXT file updated.
162
BIG QUESTION !
X-Life is a traffic.
ATC is Deluxe option for this plugin
163 (edited by captbullett 2016-02-24 17:03:31)
X-Life not only adds aircraft to the airport that you start your flight at but, it adds ATC and the route you will fly to the ATC. So, you will be given instructions by ATC on how to start the aircraft, when to move the aircraft when to taxi the aircraft, and most important when to line-up on the runway to take-off.
After, that you are handed off to the next level of ATC to go on your way to your destination when you approach the TOD you will be asked to contact the ATC again for the next leg of your flight-plan and so-on.
Nevertheless, this is the most advanced ATC to come to any flight simulator that I have seen in over eighteen years and the level of detail is very good as you must follow the instruction very closely for it too work right any help one can give I will be glad to try.
your friend,
BIG QUESTION !
164
Cheers,
Matthijs
Soory, i am not understand.. Where this scenery posted? Or it just inprogress now? And what its ICAO - code?
165 (edited by MH1212 2016-02-24 19:52:45)
OK, I attached files to my post twice now, but for some reasons they disappear... Hope it works this time
166
Why do I get the message "you should turn on traffic before" when selecting the flight plan button even though I already have X-Life traffic on?
See screenshot of message and panel showing X-Life is on.
http://i260.photobucket.com/albums/ii22/Warbirds_photos/traffic_zpspb3if6tx.jpg
167
Is there a tutorial on how to use the ramp tool?
168
Another bug, aircraft JAL-212 going to UWLW a B767-300 taxiing but no image is displayed, just the tag of aircfrat.
169 (edited by Sloboda 2016-02-24 19:01:45)
very sorry but X-Life is really unusable for me.
I have try to install it again.
2 starts, 2 crashes of X-Plane. At the moment i send the flight plan: CRASH
Each time i try to use X-Life, it crash my X-Plane for a reason or an other.
170 (edited by Dewald 2016-02-24 19:56:05)
I truly want this to work for me, but alas.
XP crashes as soon as my aircraft takes off.
log attached.
PS! This happens with more than just the MD80.
171
Hi Jar.
Just purchased deluxe. worked OK before. now I enter code for deluxe and CTD twice?
Mike
hmm
172
BIG QUESTION !
Sorry JA, but i have see it's not for sale for the moment.
When i click on Purchase (contribute), i return on same page. I can't donate.
I'll wait a version work in my X-Plane... See others posts...
173
X-Life plugin by JARDesign Ver.beta 7 200216
OpenSceneryXpath find
JARDesign plugin: E:\X-Plane 10\Resources\plugins\X-Life\Metar/EDDC.TXT file updated.
Failed to open E:\X-Plane 10//Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj: the file cannot be opened.
X-Life Object load error: E:\X-Plane 10\/Custom Scenery/OpenSceneryX/objects/aircraft/jets/corporate/citation_x/unlit/object.obj
SkyMaxx Pro: Memory Check: 62720 KB GPU, 18331120 KB CPU
0:02:18.016 D/HID: Hardware REMOVED Saitek Pro Flight Quadrant
0:02:18.016 I/JOY: UNREGISTER Joystick device: Saitek Pro Flight Quadrant - VID:1699PID:3117
0:02:19.362 D/HID: Hardware ADDED(06a3, 0c2d) - Saitek Pro Flight Quadrant at path \\?\hid#vid_06a3&pid_0c2d#6&11374596&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
0:02:19.362 I/JOY: REGISTER Joystick device: Saitek Pro Flight Quadrant - VID:1699PID:3117, this is a familiar device.
0:02:19.362 D/HID:     BUTTON Added Index: 0 (0009, 0001) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 1 (0009, 0002) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 2 (0009, 0003) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 3 (0009, 0004) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 4 (0009, 0005) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 5 (0009, 0006) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 6 (0009, 0007) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 7 (0009, 0008) for handle: 0x06585c30
0:02:19.362 D/HID:     BUTTON Added Index: 8 (0009, 0009) for handle: 0x06585c30
0:02:19.362 D/HID:     AXIS Added Index: 0 (0001, 0032) for handle: 0x06585c30. Min/Max 0 - 255
0:02:19.362 D/HID:     AXIS Added Index: 1 (0001, 0031) for handle: 0x06585c30. Min/Max 0 - 255
0:02:19.362 D/HID:     AXIS Added Index: 2 (0001, 0030) for handle: 0x06585c30. Min/Max 0 - 255
0:02:19.362 D/HID: END HARDWARE
SkyMaxx Pro: Memory Check: 118464 KB GPU, 18139032 KB CPU
174
Hello, i'm really very very happy. I have my X-Life's working this morning. Don't know why but it work !
Could someone tell me how i can buy, pay for have Deluxe Beta ???
Thank you very much.
175 (edited by Sloboda 2016-02-25 07:10:14)
When an airport have statics planes, there are some airplanes AI in statics airplanes.
So i really don't know WED but, is it possible unable static planes when X-Life run ? If not, we should review the airports in WED for remove the statics.
