126 (edited by captbullett 2016-02-22 15:17:20)
you do not need video you need to send bbox.txt and log.txt this is the only things that JAR needs to get the data to de-bug the issues everything else is just waisting time.
Thank-you for your help,
zippy77777 wrote:
Other test with flight from egll to eddl but same problem, after last istruction from approach stop comunications.
Attach screen where i click on approach (i was to TOD) but no istruction available.
how did you get 2.6b4p on dash?
Yes, i've the last b4 Sir.
Nex time i'll make a video from take off and in the proximity to TOD to explain better whats happend. Thanks far all
Are you sure you have reached TOC? The "Report TOD" message in the ATC panel doesn't appear until you have reached cruise level according to filed flight plan
128 (edited by laohu314 2016-02-22 15:36:10)
Here is my latest experience:
LOWI to LOWW. CTD when I reported TOD, maybe because Baro was at wrong value but this needs to be fixed because Baro is at STD at cruise level so not easy to change. What is the real life procedure here?
Also, the FPLN was a bit kinky, see pictures. I did a DIR to the end of SID to avoid the first kink. It looks like the FPLN tries to steal the plane over valleys but even doing so it is slightly off (see map pic)
http://jardesign.org/forum/img/m/1944/t/p1ac4pq9h9107a13sper5sq0v477.png
http://jardesign.org/forum/img/m/1944/t/p1ac4ppgck414km6l6s1lb71gd13.png
http://jardesign.org/forum/img/m/1944/t/p1ac4ppsrubcf9uh1a49186qptm5.png
Sure 100%, in one case i've wait to overpass the TOD but if click on center no any option, however i remember that with an older version after take off tha approach pass me to center controll while now i raimain ever with approach controll
130 (edited by dadez77 2016-02-22 16:29:55)
Thanks captbullet, i'll send log and bbox..
bye
thanks for log! yes, i see an error. was wrong metar reading in case when wind is VRB. Will fix this.
132
ans also, if "Yes, I reach CRZ Alt", need be sure what you measure ALT with proper baro 1013 STD. Cause, may be your alt was not real equal CRZ Alt.
133
Well, while testing this plugin Deluxe version, I notice that the FP created by the plugin said that my altitude couldn't be even, but in this side of the World (Between Australia and New Zealand) the Flight Levels are Odd.
Several tricks that I saw creating the ATC routes, because the crossing rwys.
134 (edited by PM1970 2016-02-22 20:52:49)
Hi once again big_smile
Another issue that I saw right now. I just took off from Sydney YSSY, I saw after take off that there was an airplane arriving at 2000 feet. Now that I'm at FL350 and too far away from Sydney, this aircraft that was approaching Sydney seems to start following me, and he continues at 2000 feet on the middle of ocean, saying destination as YSSY. Another issue that is unrealistic, there is an aircraft going to NZAA (I'm going to NZCH) and he is constantly changing altitude... around FL330 and FL290
135
In this flight that I'm doing, the radar whos me a strange target. *LPAZ. What is that ?! And it changes of position from north to south suddently...
136
Tried LOWS to LOWW. The flight plan that was generated is a mile long and doesn't get imported into the FMGS. I also didn't manage to copy it from the flight plan window...
Can anyone try to reproduce?
If nobody gets the same problem I'll upload logs etc.
137 (edited by laohu314 2016-02-22 22:35:28)
Just CTD'd at LOWI when starting traffic in XL...
Same problem with metar read?
138
I flight only with  a320 and after passed the TA I pull the qnh knob so i'm sure to use the standard pressure
139 (edited by p_delray 2016-02-23 11:43:59)
Just got this but a bit confused. Does it only work with a handful of european airports so far? I tried several of the freeware airports on the list but it crashes X-Plane when try to turn on X-Life. The only airport it does work with  is Inbruk.
Also I build small airports for X-Plane and want to know how I can make X-Life work with my aiirports?
And,, how do I get the paid deluxe version,,cannot find a link or place to purchase?
Mr R,
Couldn't attach to pm, so here it is...
OK, downloaded again..all went great but when I put my name into the flight plan (instead of keeping USER123, and clicked Send to AC then ctd. So, I restarted xplane and kept the USER123 in flight plan...sent to ac, then atc all went well. takeoff from eddm to LOWI...EVERYTHING works, then I input STAR for LOWI then ctd.
Log attached
danke!
Grazi!
Concerning the question about the QNH demand there is a bug. The first demand for QNH getting clearance from Delivery is understandable.  The second one occurs during flight while contacting Approach. I got a an error massage saying "wrong ATIS information (I flew at FL 237 and my QNH was STD). Only After I changed STD to QNH 1015, I got the massage "identified  expect ..." as you can see on the attached  images
The correct dialog must be:
APPROACH: SA001 contact MUNICH Approach on 123.625
SA001: readback
SA001: MUNICH Approach, SA001, FL237, descending to FL170, information Whiskey on board
APPROACH: SA001, MUNICH, radar contact, expect NAPS1A arrival, ILS approach runway 26L, DESCENT FL 110 (for example - over 10.000 feet),
SA001: readback
Additional instruction
APPROACH: descent 5000 feet, QNH 1015, transition level FL 50
SA001: readback
This was a test flight  from LOWW to EDDM with ver. b.-7. Beside this bug everything functioned well.
One question to JAR team: How many aircraft are pre installed when using X-Life the first time?
142
Missing my uploaded images!
143
Yes there is a bug in the metar update function, this will cause CTD when the airport have no metar data on the server which x-life use. I just tell the problem to Mr. JAR, I think he will fix it in the next beta.
144 (edited by captbullett 2016-02-23 15:21:23)
Most of the CTD's are because, you have not followed the instructions.  Since, you should be within 10nm of TOD to contact ATC to get your instructions. then you will be very busy making adjustments but if you need more time you have the pause at TOD in the MCDU you can activate. Now I have never used it so, I don't know how well it works but it is there.
hope this helps you out,
Your friend,
145 (edited by captbullett 2016-02-23 16:32:04)
If this is so then any XP app using Real Weather would be CTD and there would be an outcry from the .org... and I have not seen any try to delete the Metar .txt and wind.txt and then let it re-download.
Ps, I just deleted the two .txt files and then downloaded the fresh Real Weather Metar Data with no issues so I hope this info will help anyone with issues that is using B7.
B
146
yep, this done. I will publish this beta soon
nubbix wrote:
Just tried x-life and when I pressed the "turn traffic on" x-plane crashed?
From Log.txt
X-Life plugin by JARDesign Ver.beta 7 200216
OpenSceneryXpath find
scenery_class: CANT OPEN FILE
JARDesign plugin: F:\X-Plane Games\X-Plane10_Heli\Resources\plugins\X-Life\Metar/ENGM.TXT file updated.
this error may happen if plugin cant open apt.dat file. May be not compatible scenery was used?
Hi, thanks the issue was located to a converted scenery, guess that is not something that is compatible.
But I did try several of tdg's airport and it worked there, problem is that there is no visible airplanes what so ever.
Flight plan do not work too.
So my question is: Do x-life only work on x-life approved airports? Since every airport in Norway made by tdg is tested and no traffic is present. I see at the map link no airports are approved in Norway.
PS.. Love this idea, hope it will work for every airport, since Norway is populated mainly by tdg airports, I hope x-life will be adaptable.
148
If ATC-taxiroutes prepared well by scenery autor - will work Ok. If not - only one thing may happen - custom-builded .dat file.
I've noticed that the landing airplanes sometimes don't actually land until more than half way down the runway.  Often this mean they can't slow down fast enough, and miss the last turnoff the runway.
Also, when landing, planes always taxi to the end of the runway, even if they are able to exit at an earlier taxiway.  Is this intended, or a bug?
150 (edited by PM1970 2016-02-24 01:36:53)
Hi once again
Making a flight from EDDM to EGLL, 5nm from T/D I changed to CENTER (not realistic though) and said reaching T/D. The simulator crashed.  I use FSRealWX to inject weather on X-Plane 10. The last lines from my LOG:
2:53:56.451 I/ATC: Airport flow changed at EBAW!
CurFlow: AUTOGEN: North NewFlow: AUTOGEN: West
2:53:56.451 I/ATC: Changing EBAW CabState from 0 to 1
2:53:56.451 I/ATC: All departures are done at EBAW. Advancing...
2:53:56.451 I/ATC: Changing EBAW CabState from 1 to 2
2:53:56.451 I/ATC: All arrivals are done at EBAW. Advancing...
2:53:56.451 I/ATC: Changing EBAW CabState from 2 to 0
2:53:56.959 I/ATC: Airport flow changed at EHSE!
2:53:56.959 I/ATC: Changing EHSE CabState from 0 to 1
2:53:56.959 I/ATC: All departures are done at EHSE. Advancing...
2:53:56.959 I/ATC: Changing EHSE CabState from 1 to 2
2:53:56.959 I/ATC: All arrivals are done at EHSE. Advancing...
2:53:56.959 I/ATC: Changing EHSE CabState from 2 to 0
2:53:57.687 I/ATC: Airport flow changed at EBWE!
2:53:57.687 I/ATC: Changing EBWE CabState from 0 to 1
2:53:57.687 I/ATC: All departures are done at EBWE. Advancing...
2:53:57.687 I/ATC: Changing EBWE CabState from 1 to 2
2:53:57.687 I/ATC: All arrivals are done at EBWE. Advancing...
2:53:57.687 I/ATC: Changing EBWE CabState from 2 to 0
2:54:00.211 I/ATC: Airport flow changed at EBFN!
2:54:00.211 I/ATC: Changing EBFN CabState from 0 to 1
2:54:00.211 I/ATC: All departures are done at EBFN. Advancing...
2:54:00.211 I/ATC: Changing EBFN CabState from 1 to 2
2:54:00.211 I/ATC: All arrivals are done at EBFN. Advancing...
2:54:00.211 I/ATC: Changing EBFN CabState from 2 to 0
JARDesign plugin: C:\X-Plane 10\Resources\plugins\X-Life\Metar/EDDM.TXT file updated.
JARDesign plugin: C:\X-Plane 10\Resources\plugins\X-Life\Metar/EGLL.TXT file updated.
