pic wrote:
Hi Mr. R,
Major problem with latest version (7).  When I click on the settings in xlife menu (little gear icon), the sim goes to single digit frame rate (I have a 980ti).  Also, could not send flight plan to a320 fms. Log attached for your viewing smile
are you use a320 by JARDesign?
102 (edited by TKurzweg 2016-02-21 07:55:12)
Hello x-life crew, today I have my first crash after hours of fly with x-life. Don't know why !
Flight with A320neo from EDDT to EDDM. SkyMaxxPro and FSGRW plugin for x-plane.
was just x-plane crash with
104 (edited by thomas_99 2016-02-21 09:17:53)
And again, CTD.
Flight from EDNY to LOWI, last messages:
---+++--- Pilot: Contact INNSBRUCK Approach 123,625, TH123
---+++--- Pilot: INNSBRUCK Approach ,TH123, FL110, descending to FL120, information Romeo on board
---+++--- ATC: TH123, INNSBRUCK Approach, Wrong ATIS Information
Click on ATIS, CRASH.
http://jardesign.org/forum/img/m/552/t/p1ac1hpu4cqoo1bvn6co1glf163a3.jpg
Log included.
That was my 2. crash at same state, arrival airport, wrong atis information, click on atis, crash.
I think there is a problem. If we use a third party ATC software, X-Life and the ATC are in conflict and don't say the thing.
Essentially for the take-off and landing runway.
It could be very interesting we can ask to x-life to change take-off runway after it give it to us or at the start when we set flightplan in X-Life. And ask him to change landing runway after he give it to us during the flight.So we could be synchro with ATC.
Yes sir. Latest RC, not beta.  I was able to reload the plugin with a new DL, everything worked EXCEPT sending flight plan to the fms. Then I took the ac from LFMN to LICC, and upon final ctd. Log again attached  I absolutely LOVE this plugin and hope to get it working for all again wink Thank you
pic wrote:
Hi Mr. R,
107
Oh another thing Mr R., In addition to the new ctd and new file I just posted with your answers above, I forgot to mention that when the agreement pops up, it covers the NEWS, and when you try to click the Read and or accept agreement it continually opens a new window to the splash page of the xlife site.  I was able to overcome this by making my xplane into a Window, (thru xplane settings) then adjusting the window so the NEWS shows, then I click off the NEWS then the agreement works fine.
Also, the ATC window comes on so close to the top, it is virtually impossible to move it to a more convenient location, the xlife menu does this as well
Thanks again...
108
Traffic at airports on the schedule or just generated by the plugin?
Other test with flight from egll to eddl but same problem, after last istruction from approach stop comunications.
Attach screen where i click on approach (i was to TOD) but no istruction available.
how did you get 2.6b4p on dash?
110
twinrix wrote:
I was able to agree to the license by just clicking like mad on it, sooner or later it works. Now how do i activate the Deluxe features? Im confused here...
no deluxe features, its more of a donation :-)
111
no way to integrate any other ATC now. this should not work
pic wrote:
Hi Mr. R,
But are you have ATC-taxiroutes for LICC?
113
generated now
114
http://airbus320neo.com/updates/
115
Thanks again...
thanks, understand
116
Flight LFMN to EDDH :
At start  at LFMN when take off on the 04 runways it is always the 04L that it is used
is it not possible to take off from the 04R or (in upcoming betas) to ask ATC an other runway (for landing it would be great also)
PS : in real life 04L is at the moment closed
Thanks a lot
117
still says 2.6b3
118
Yep, thats what i am talking of. Would love to donate to use the deluxe features again smile
119
Just tried x-life and when I pressed the "turn traffic on" x-plane crashed?
From Log.txt
X-Life plugin by JARDesign Ver.beta 7 200216
OpenSceneryXpath find
OPEN scenery_packs.ini FILE OK
scenery_class: CANT OPEN FILE
JARDesign plugin: F:\X-Plane Games\X-Plane10_Heli\Resources\plugins\X-Life\Metar/ENGM.TXT file updated.
--=={This application has crashed because of the plugin: X-Life}==--
120
Will this plugin work with SkyMaxx Pro? I just experienced a crash and it said that SkyMaxx Pro stopped working because of xlife. I just want to see if anyone else has experienced this?
121
I used SMP and x-life. No problem here.
122
I also use SkyMaxx Pro v3 without any problems. No crashes at all.
Yes, i've the last b4 Sir.
Nex time i'll make a video from take off and in the proximity to TOD to explain better whats happend. Thanks far all
124
From Log.txt
this error may happen if plugin cant open apt.dat file. May be not compatible scenery was used?
125
I think X-Life is a great new plugin and I hope it will develop further! I am already impressed by how the beta works right now!
I have installed X-Life on XP10.42 and XP10.45r2 and both seem to work. I have a couple of questions / remarks:
- I received the error "impossible to create ground route". After a lot of trial and error I discovered that was solved by reversing the part of the atc route where the ramp start was placed (switch from and to node). It was hard to find + the layout was valid according to WED. Is it possible that X-Life is too strict when dealing with this?
- When AI planes land they always seems to taxi to the end of the runway even if there are exits halfway (with atc routes of course). Is this a limitation of X-Life or is something wrong with my atc layout?
- When X-Life starts there are 3 lines indicating traffic: 2 Arriving (Arr) and 1 Departure (Dep) at my airport. The departure never happens -> suddenly this line is gone (so 1 have 1 blank line on the list: the 2 Arr lines are still there).  The plane just sits on the ramp. The arrivals are executed: status Fly etc. What happens here?
- Is there a separate log file of X-Life to check what decisions are made or what errors are found? I can't find much info in the log file of X-Plane + you can only read the full log after closing XP.
- I read in the forum that ATC in combination with mountains is not functional (which I fully understand). You are probably aware of this but there is information available about terrain height: Digital Elevation Model files (DEM) which are freely available on the internet. But even then it is a complex issue :-)
Hope this helps! Keep up the good work!
Cheers,
Matthijs
