Just post beta 7. main goal - ATIS improvements and any Weather engine may use with
+ Possible to use with ANY weather plugin
+ wrong Holding Short reports fixes
+ add a321 support (for future)
Hi JAR
I just installed clean beta7 -> the licence agreement don´t work (like beta6 without hotfix)
config: 10.42, Mac OS X 10.11.3
Now it works - you have to update xplane to 10.42 without any changes and then it will work with the licence agreement -> suspicious - in beta6 it was the same problem
Last words was
> ATC: BAW2121, Climb to FL 35000
> Pilot: Climbing to FL35000, BAW2121
Yes it stop, while you are nor report TOD
Can i make some particolar test for help you?
You should just contact Center when close TOD and report TOD. Will be Ok.
I've tried but i don't have any option to click  for confirm that Im st TOD
first small bug for beta7:
Planes crossing on runway...
http://jardesign.org/forum/img/m/552/t/p1abvc0kbj13lj1e91qifnn02tm3.jpg
- plane from the right has just landed
- plane is taking off, status taxiing
   - plane from the right stopps before runway
- plane takes off, status flying
- immediatly the plane from the right begins to taxi.
=> looks a little bit curious. Better to hold the runway busy some seconds afer plane takeoff :-)
Thank you so much JAR for this X-Life, its awesome. :-)
A couple of things I would like to mention, is that when I press CLR and then discontinuity and do a temporary insert. After a little time this becomes permanent without me inserting it and telling it to be. Is this correct? It goes green automatically.
Secondly, when ATC says to me, wrong ATIS information on arrival, (I'm still above trans alt) how do I change it? Do I have to press STD then change it and then change back to STD or do I just wait until I am below TRANS ALT?
Cheers once again JAR :-)
82 (edited by TKurzweg 2016-02-20 17:19:54)
Is it possible to send my A321 complete fleet, 24 airlines (sharklets / winglets) for using / testing in X-Life after PM to me ?
Ok...here is the link:
https://www.dropbox.com/s/dsyv7d7usnc013m/a321.zip?dl=0
You need latest X-Life Beta 7 with A321 in the aircraft / OSX folder !
Copy all airlines in the .zip to a new created folder named a321 in X-Plane 10 / Custom Scenery / OpenSceneryX / under ...objects / aircraft / jets / heavy
That's all and have fun with the A321 in X-Life..."You'll never fly alone !"
83
Where is it possible to have the payware version for the deluxe edition ?
With the beta 7 I can't click on the green read me for the license .
Thanks a lot
Thanks a lot
First of all, check your PM. To be clear - no direct way like BUY NOW work this time, but it is possible to click webpage menu and will see a solution.
need read ATIS and contact Approach again.
sorry, not sure what understand quest about disco
Other test with flight from egll to eddl but same problem, after last istruction from approach stop comunications.
Attach screen where i click on approach (i was to TOD) but no istruction available.
I was able to agree to the license by just clicking like mad on it, sooner or later it works. Now how do i activate the Deluxe features? Im confused here...
Beta 7 on Mac OS does let read license and no accept button (was fixed in beta 6, but problem back in beta 7)
89 (edited by Sloboda 2016-02-20 18:30:53)
just install ====> just uninstall.
First open: can't agree licence => x-plane crash
second open: i can agree => i active traffic: x-plane crash
third open: i click on option, allright. I click on Gate edit, nothing happen, i active traffic on: x-plane crash
fourth: x-life go to rubbish-bin.
90 (edited by Sloboda 2016-02-20 18:42:20)
The problem is because my opensceneryx folder is named library_opensceneryx.
I always make like that with my custom sceneries and librairies for always have a good scenery_pack.
I never had problems with other plugins.
Perhaps you could make correction in code or you could ad an option for set path...
Bye
What happen what happen whan you click read license?
Thanks, Sloboda. May be yes.
To have TOD report button you need reach CRZ FL, what was sended to ATC
Thanks for issue! I just fix it, but you need redownload distributive from official product page.
95 (edited by dadez77 2016-02-20 21:47:00)
I was at Cruise level from lot of time
96
Hello. Sorry for my English. Launched traffic at Sheremetyevo airport, to observe how to work the plugin. Found that in the signed information to the aircraft and information about the airport, but a flight number, airport information lost the first digit. In the image below highlighted with a marker.
Здравствуйте. Извините за мой английский. Запустил траффик в аэропорту Шереметьево, понаблюдать как будет работать плагин. Обнаружил, что в информации подписанной к самолетам и информации о аэропорте, а именно номер рейса, в информации аэропорта теряется первая цифра. На скрине выделил маркером.
http://jardesign.org/forum/img/m/2023/t/p1ac09ta4k1tepbra1h65dah197g3.png
http://jardesign.org/forum/img/m/2023/t/p1ac09ta4l1s813ej1ge014s87kg4.png
На моделе А380 полоса справа
http://jardesign.org/forum/img/m/2023/t/p1ac0dctib4ak15ah1a34djl1ur63.png
Hi Mr. R,
Major problem with latest version (7).  When I click on the settings in xlife menu (little gear icon), the sim goes to single digit frame rate (I have a 980ti).  Also, could not send flight plan to a320 fms. Log attached for your viewing smile
How to add an airport to use for control?
Как самому добавить аэропорт, в котором будет работать контроль?
Learning video and samples http://jardesign.org/forum/viewtopic.php?id=1670
Thanks for other issues
