Topic: FMCar v2.4r1 For Win 7/8 MAC OS (X-Plane 10.42 ready)
FMCar v2.4r1
Whats New:
+ X-Life traffic plugin compatible
+ Add update notifications
+ Some bug fixed
Now you can add your own custom airport description file like apt.dat file. To do this, Please use
"Airports" folder in your ...X-PLANE 10/Resources/plugins/FM/ and put your custom apt.dat file there with NAME.dat filename. As example, you can download EDDL.dat (file for Dusseldorf airport) and put it to ...X-PLANE 10/Resources/plugins/FM/Airports/ folder
If you own an old version of FMCar and not have serial key, please contact support email and just send a copy of conformation email from shop where you get it.
Download here:
www.jardesign.org/fmcar/download/FMCar_2.4r1.zip
Re: FMCar v2.4r1 For Win 7/8 MAC OS (X-Plane 10.42 ready)
This version fixed problem when no FM car appear after selecting target point from list first time after plugin loaded. Other fixes - improve stable work on MAC.
3 (edited by A350Pilot 2016-01-09 17:06:06)
FMCar didn't work anyway.
Here is my Configuration:
XP10 V10.42r1 64Bit Global Scenery incl. BuiltIn Aerosoft Airports
FMCar 2.4r1 with your delivered EDDL.dat
Installed Plugins
Plugin Admin, DataRefEditor, FMCar, XPUIPC, EFASS XPSM, Tug Master, SASL and GroundHandling
Placed my Aircraft on V40 in EDDL. When XP10 starts up, a Message appears that shows up FMCar 2.4r1. Some Seconds later the Message appears that there is no FMCar available in EDDL. FMCar is registered today with the Serial you provided me per Mail.
The Activation Code, delivered per Mail was accepted and the Plugin is activated. Why it does not work?
If you need further Information, please let me know. Unfortunately i have no Equipment to Skype. So i need Help via the Forum or via Mail. Thank you.
X-Plane since V10
Please try it in default KSEA first. May be a reason what you have not Custom EDDL scenery installed.
Thx for your fast Response.
Tried the following:
Terminate XP10
Delete all the Files in XP10\Resources\plugins\FM\Airports\
Start XP10
The following Files were generated automatically. See attached Pic.
Tested EDDH, EDDM, EGLL. Those Airports are working.
EDDL didn't work.
Other Airports i will try tomorrow.
Do you have any Solution for EDDL?
Is the provided EDDL.dat in the Installation Folder not containing the Taxi Routes?
X-Plane since V10
http://jardesign.org/forum/img/m/22/t/p1a8k29lau8i10a125p123r1im3.jpg
Tried this Morning with an empty Folder for EDDL. It works now.
Did you mentioned anywhere, that it is absolutely enough, to put an empty Folder in XP10\Custom Scenery?
I am no XP Developer. So, from where should i know that?
Thx for your Help.
X-Plane since V10
all .dat files may work with some but exact airport scenery
if you use .dat with some another scenery, routes may be placed wrong
that mean that FMCar will not follow taxilines what you see visual
--=={This application has crashed because of the plugin: FM Car}==--
cool report! really useful!!! smile
What is support email? Please assist with the email
www.support.jardesign.org
no email, but www.support.jardesign.org work well
14 (edited by johnliem 2016-03-04 08:20:21)
I just bought the follow me 04-03-2016 , and I read that I can add the APT.dat , and I put it to X-PLANE 10/Resources/plugins/FM/Airports/ folder as it mention above, but when I open XP, it says that FM car not available.
as I bought today it must be FMCar v2.4r1 version right, but could you tell me why it still not working, by tha way the APT.dat
I edit the name to in this case WARR.dat.
you must register the product.
16 (edited by jeanjacquespetit 2016-10-17 14:08:53)
EFASS PLUGIN AND FMCAR
i found an issue about a problem of FMC CAR.The logo "MAP" in green on the left side of the screen was inactive to open the map, and i had to activate the map through the X-PLANE plugin manager.
The problem was a conflict with the EFASS plugin.
JJ
Follow me plugin has incompatibility with the last Carenado´s aircrafts, it kill aircraft´s sounds.
