Topic: X-Life public beta-6, 7, 8, 9 (Win & Mac)
Spend a time to create product webpage - http://x-life.jardesign.org
Please visit and download actual version. It will be beta 9.
-----What New?---------------------------------------->
Beta 9 100316 (actual)
+ bugs fixed
Beta 8 250216 (old)
+ bugs fixed
Beta 7 200216 (old)
+ Possible to use with ANY weather plugin
+ wrong Holding Short reports fixes
+ add a321 support (for future)
Beta 6 160216 (old)
+ add arrival and departure info for unregistred version
+ add notification when pilot request FMCar, but this plugin not installed
+ fix a lot of code bugs (but not all may be) based on your reports
Beta 5 090216 (old)
+ improve Radar/Map
+ add/fixed Import/Export functions at Fpln panel
+ improve ATC panel autohide
+ Improve markers drawing
Beta 4 010216 (old)
+ add GoAround ATC pattern
+ add Screen-side menu
+ possibility to turn traffic Off with side-menu
+ improve aircraft markers info
+ improve ATC panel auto-hide
Beta 3 (old)
+ Add ATIS info for Departure/Arrival airports to ATC panel
+ Add ability to start descend when pilot ready (ATC phrase)
+ Tune climb angles (takeoff phase) for AI aircrafts
+ Add cruise flight level checking by ATC (0-180-360 rules)
+ Add dark map background
+ SQUACK code by ATC fixed
+ Add transponder mode ATC check (when you on runway / leave runway)
+ Follow Me car route fixed (stop FMCar before runway)
+ add screen warning messages for different situations
+ add ATC voice (need improve, but work now). Can be turned On/Off via X-Plane menu
+ add data checking after entered at FlightPlan panel
+ add visual indication of runway vacation direction after landing
+ add lights for AI aircrafts
+ add more sceneries/airports
+ improve ATC voice phraseology
Beta 2 030116 (old)
+ add Windows version
+ unlock airports for beta-tests
+ panels "out of screen" fixed
+ perfomance improve
FUTURE TASKS:
Requested features (not released jet)
- Add ATC requests what ATC not get readback from pilot
- rework towing/engine start phase for AI aircrafts
- add Alt/FL ATC clearance with constrains (take in account)
- add true radio freq from reallife
- increase airtraffic generation density
- add crossing RW for user
- separate/mark runways for departure/arrival when need
- ATC vectoring along flightplan
For users who take part in tests and send me reports (or post it here) for beta 1-5, i will send own serials via PM. Please check your PM 17 febr. Please send me PM if I forget you (sorry).
You can use this version with airports what are always have custom ATC-routed description. Please use this map https://www.google.com/maps/d/edit?mid= … sp=sharing
If you click on every of this airport - you will find a link for this sceneries.
So, is you are X-Plane scenery developer, you may use this version to check how good your WED atc-taxi-routes work with real traffic plugin. X-Life may read apt.dat files well, direct from Custom scenery folder. Also you can export apt.dat using WED to ../X-Life/Airports/ folder. In this case, X-Life will ignore apt.dat in Custom scenery and will read your XXXX.dat (XXXX - ICAO airport code) from ../X-Life/Airports/. Sure, you need do one more thing before testing - use X-Plane menu / Plugins / X-Life / Gates editor to set parameters for EVERY gate (batch edit supported). If you need some examples of propertly builded airports ATC-taxiroutes, you may just import any of this (http://jardesign.org/forum/viewforum.php?id=33) using WED and look into. Please use this guide for details http://jardesign.org/forum/viewtopic.php?id=1670
-------HOW TO USE / Example flight ------------------------>
If you use FMCar, please update your version - it will be compatible with X-Life (useful to request ATC for FMCar and ATC will call FMCar for you and supply it with needed Ground Route).
Download link for FMCar ver 2.4r1 MAC OS / Windows - http://jardesign.org/forum/viewtopic.php?id=1633
If you have CTD (with Windows), please post here files from X-Plane folder
1. log.txt
2. x-life.dmp
Damp file include memory / functions stack dump what can understand as where from problem come. In ideal situation - what string in c++ code have error.
If the same happen on MAC, please post mac crash report and log.txt
I could not get it working with my first modified airport.
Also the traffic is working well, FMCar is working, I got the Message
"airport is not x-life compatible".
What's missing here ?  tested  Beta5 + Beta6, same behaviour (screenshots Beta5)
http://jardesign.org/forum/img/m/552/t/p1ablujhmlcdp110d14ctc1mjl14.jpg
http://jardesign.org/forum/img/m/552/t/p1ablujq8f6ap1ovsifs1lccobr7.jpg
Are you have EDNY.dat at /Airports/ folder?
EDNY.dat is a copy of apt.dat
4 (edited by alessandro61 2016-02-17 07:15:17)
Hello Jar
I don't understand how to read fist license to use the plugin.
Alessandro
Ok, thanks, problem solved!
Alessandro
6 (edited by Wangenheim 2016-02-17 08:20:51)
Предложение|Feature Request (sorry for russian, it's hard to me explain that in english)
Как уже раньше предлагал, очень хорошо было бы и для проекта и для меня как пользователя приблизить траффик к реальности, а именно:
1. Ограничить список авиакомпаний работающих в конкретном аэропорту
    Вариант реализации: взять X-CSL библиотеку моделей самолетов (модели используются в IVAO, разрабатываются парнями с X-Airways, бесплатна), в этой библиотеке модели структурированный по моделям самолетов и операторам. Далее в файлы настройки аэропорта X-Life (например для Минска - UMMS.txt) прописать доступных операторов. При генерации трафика использовать эти модели с соотв. операторам ливреями. Таким же образом можно прописать самолеты для операторов (например для Белавиа это 737, Этихад - 320 и т.д.)
2. Расписание полетов, заранее предопределенные операторы, самолеты, маршруты.
    Этот пункт в большей части устраняет некоторые разногласия из 1ого пункта. Для малой авиации не имеет смысла.
Блок схема:
Если есть расписание для аэропорта - используем его (*), для малой авиации, военных и вертолетов - пропускаем;
Если есть список операторов с самолетами - *;
Если есть просто список операторов - *;
Если ничего подобного нет или нет описанных выше моделей - использовать текущий алгоритм.
Евгений JAR, как вы на такое смотрите?
Я конечно смотрел X-Airways библиотеки, там есть одна особенность - "ноль" оси Z не на кончике носа самолета - это требует расчета индивидуального смещения, что сильно усложняет все геометрические расчеты. Поэтому я не стал с ней (пока) заморачиваться. Начал я с OpenSceneryX, она более-менее подходит и от нах есть "добро" на использование.
По рассписаниям и авиакомпаниям - да, это future task.
Sorry for Russian lang!
8 (edited by thomas_99 2016-02-17 10:24:17)
Do I really need this ?? why ?? I have the apt.dat in "custom_scenery\EDNY\", and
x-life and FMCar will find and use this file. I'm 100% sure about that, because if I change the ATC Routes and
export apt.dat in scenery folder, I can see the changes I've made.
the only problem is pressing the "GENERATE" button in "flight plan" will generate an
"dep airport not x-life compatible" instead of a flight plan.
X-Life traffic itself is working. Planes flying, taxying and so on.
But I will try in the eavening to copy apt.dat to EDNY.dat in "X-life/Airports" folder.
Really nor, but for this development stage it is a way to guarantee what airport is really ready. Else, plugin should check apt.dat to determinate if all needed data present inside. I will fix this for next stage.
Крутатенюшка!
11 (edited by dadez77 2016-02-17 13:07:17)
sorry for my, sure, stupid question.
I've install the last beta 6, but where is the botton to click fo agree the readme? If I click on READ LICENSE is open the jar forum page, form the menu i have activate the traffic but i cant find nothing abount "agree terms" or filed to insert my code license.
I've only this screen without other
12 (edited by marvel_master 2016-02-17 14:17:33)
which log files or files do you need for this:
" + fix a lot of code bugs (but not all may be) based on your reports "
Log.txt only
After click Read License a webpage with text should be open with your www browser. After this, AGREE button should appear near READ button. Is not it?
But in beta 6 i don't have no more the gates editor? Is It possible?
I just forget it, sorry. Please change .xpl files - will work
no, when click on it open the browser with forum discussion page
just re-start the XP app and the widget will work it was hanging on me also.
So I re-started the X-Plane app and it then worked and I could click on the "Agree" button.
no, I've installed again the plugin but now if i click nothing happens....strange, i'll tru to restart the pc
20 (edited by SirOTheOne 2016-02-17 16:16:43)
Dear JAR,
after starting x-plane with new x-life beta 6 -> crashed, see log.txt
it´s a great plugin, but doesn´t work at my current machine
And with the AGREE procedure there is also a problem on mac
To fix the problem i've reboot the pc and set explorer as default browser (usualy uswe chrome), now i've problem with serial, because the system not accept my email, i use the same used in all past activations, i've tried, however, th mail used here for register in forum but same error
Howdy,
I had the same problem. It was that I was using the beta xplane 45. So, I tried it with normal release up to date xplane and no problems.
What happens is when you start xplane and you are finally in your ac, the xlife window pops up. Click the READ ME, your browser should open up. Give it a read and then quit your browser which gives you back xplane. There should be additional click spots now that say agree or no agree. Click agree if ya want and presto, your serial number should be entered next and the rest is history.
I hope this solved it for you.Good luck!
di luigi
pic wrote:
Howdy,
di luigi
Thanks...now the agree question is ok...now i've problem with serial because after that entered and specify my email appear a message because my email address is not registered...
Hello JAR,
with x-plane 10.42 the plugin (beta 6) and the license agreement works.
Thanks to pic, it works
25 (edited by dadez77 2016-02-17 18:10:58)
in attach my error during the registration for delux when enter my email-
thanks in advance
