Topic: X-plane crashs because Ground Handin
I just boight Ground Handin.
I tried to active the product, and when I inserted serial number and clicked apply X-plane crashed.
Now when I reopen X-plane, it crashes, right at the end of loading. The message in Log.txt is the follow:
--=={This application has crashed because of the plugin: Ground Handing}==--
No more message are available in whole log.txt
The only way to start x-plane is move Ground Handin outside the plugin directory.
I'm using X-Plane 10.42r1 (64-bit build 104200)
