Topic: A330 FMC doesn't recognize certain Fixes
Hi all,
i'm wondering why doesn't the A330 FMC recognize certain Fixes (D301P, D331H near LIRF for example). The FMC will generate 'Unknown point type' whereas the default X-plane FMC will recognize it just fine.
I'm new to flight sims, hence the naivety.
FYI, i'm using X-Plane 10 HD Mesh Scenery v3 from alpilotx.
Thank you.
Re: A330 FMC doesn't recognize certain Fixes
I had this problem until I updated my AIRAC cycle. Trying buying the latest navdatapro cycle and see if it still happens.
3 (edited by Zeke*Earl 2016-01-28 15:30:20)
I see. The problem is an outdated AIRAC cycle. Noted with thanks, Nicco54.
...updating the AIRAC cycle did the trick. Thank you once again:)
