I am experiencing an issue with Flaps deployment whilst in Approach Mode. Its a bit complicated to explain so I will try my best:
When I select Approach Mode in a Managed Descent, the speed starts to decay to 210knots as expected. I then deploy Flaps 1 and the speed decays further but I expected the target speed indicators to display the target for Flaps 2 once I reach the Flaps 1 target speed, which they no longer do in this release. To get the speed to reduce below the Flaps 1 target I need to select Flaps 2 much earlier than my airspeed allows resulting in a Speed not Ok message. After that message the new target speed indicators appear and I can reduce speed using speed brakes. The remaining flap deployment schedule works as expected.
In Open Descent mode the flap deployment is normal and works as expected.
Has no one else has noticed this?
Cheers Mike
