Topic: ver 2.6 beta 2 WIN/MAC 64 bit
First beta, please use it if you really want take part in beta-tests
v.2.6 MCDU internal structure and internal data transfer code have huge difference compare with 2.5 and become like a330 now. For this reason a number of issue may happen for this beta stage.
beta 2 Change list (from beta1 stage)
+ADIRS alignment fixed
+color of CSTR at FPLN page change to magenta
+airport,vor,etc ND drawing fixed
+reading light fixed
+navData folder changed to ../X-PLANE 10/Custom Data/GNS430/navdata/ (not overwrite by installer)
+transponder automode changed to intruders show only
+FA voice selector deleted
+"CR/VR" legs drawing fixed for SID/STAR
+"VD" legs drawing fixed for SID/STAR
+some minor text displacements for MCDU
So, this is the next 320 MCDU/ND improvements - reworked flightplan path (add TMPY FPLN, GA FPLN, ND), new SASL v2.4 implemented (should fix CTD when exit X-Plane), add Saitek Throttle Quadrant support (for LG, Flaps, GSpoilers control)
——————————HOW TO INSTALL:——————————————
Download link http://jardesign.org/a320/download/inst … V2.6b2.zip
- be sure, that you use X-Plane 10.41 (64 bit only)
If your activations are over (activation error) - use contact official support http://www.jardesign.org/ticket/kb/faq.php?cid=1
——————————IMPORTANT NAVDATA NOTES:————————————
FMS NAVDATA Update:
v.2.6b2 use NavData from
../X-PLANE 10/Custom Data/GNS430/navdata/ folder
if not find there - will try to read it from
..X:/X-PLANE 10/Resources/GNS430/navdata/
- “a320/330 Native format” or (the same in fact)
and put new cycle to ..X-PLANE 10/Custom Data/GNS430/navdata/ folder
—————— "BETA" is version for Beta-testers!!! ———————————
This is beta version for X-Plane 10 64 bit. "Beta" mean what some may work wrong. Please report about wrong thing, but only thing what changed in this beta - Flightplan part, MCDU work, ND work
Please not discuss things what are not in "whats new" list. Please post your opinion direct here. When you post some, please follow some rules like this http://jardesign.org/forum/viewtopic.php?id=861
Of particular importance will be issues:
- Drawing (wrong, sure) SID/STARS on the Nav display (please attach a screenshot of true drawing from documents and wrong drawing from your ND, specify the SID/STAR, approach, runway, name of the airport, AIRAC cycle and provider)
- Displacement of characters on the MCDU screen (attach screenshots please)
