Topic: SET files not working after saving in notepad
Hi, whenever I open the set file in notepad and then save it, it gets somehow reformated and GHD will not read it in X-Plane. This way I wanted to add the custom datarefs but I can't because when I save the file it will not work. Should I save it in a special way in the notepad? I tried all possible encoding.
Below are 2 pictures of the working set file and then of the one that is resaved but is not working and also the actual set files
Thanks! Other than that the plugin is absolutely amazing !
